Yes correct..i plan to use neurochrome bufferDo you mean 1ET400A, alone?
Eval2 is the front-end for 1ET400A. Total power will be the same. That means the Eval2 is indeed mono version of Eval1Any updates about the eval2 board. Are they more powerful then the eval1? Or only a mono version of the eval1.
ThanksEval2 is the front-end for 1ET400A. Total power will be the same. That means the Eval2 is indeed mono version of Eval1
What fuse do you recommend ?This really needs an IEC module with a fuse holder. I checked the Hypex PS datasheet and the soldered on board fuse is 12A slow blow? If running on 240VAC a lot of damage can occur before that blows!
So EVAL2 has 1 channel and EVAL1 has 2 channels. Great.
(? 10A or 8A slow blow ?
Thanks wineds.
Main main voltage is 220-240VAC.
It's weird that HYPEX, being in Europe (240VAC), use 12A slow blow fuse
Right. Worst case board protection. The system assembler should provide appropriate protection for their use case, as necessary. 5A on-board would mean it could not be used in countries with lower mains voltage. Their alternative would be to sell mains specific models.I guess Hypex are building power supplies for the world. The on board soldered 12A fuse is intended as a last ditch fail safe which should never blow if an additional lower rated fuse is fitted to the build.
I'm not sure how important this is but as some may be aware on this site, I've been unable to get my Purifi amp built to work.
Thinking I must have made a wiring error on the aux cable, I ordered the new wiring kit from Ghent for the Purifi.
In looking at the aux cable carefully, I have found, I wired my cable exactly the same as Ghent, and both cables exhibit continuity at each any every connection.
Ditto the main power cable.
Looking at the cable leading from the mains voltage plug to J2 is another matter. Note the picture. The original IEC cable set which came with the 300mm Ghent NC 400 case is on the left and the new cable I just received is on the right. View attachment 90755
There exists only one way to plug into J2. With the original cable my set up looks like this:
Will this make a difference? Anyone know whether this is the root cause of my problem? Would it be fixable just by substituting the new cable or have I damaged the SMPS? Or am I just barking up the wrong tree?
Would appreciate the input. Ghent has the exact same wiring diagram for the plug for the new Purifi Case as he had for the 300mm NC 400 case, and Hypex did not even indicate which pin was which on J2 in their documentation, so I don;t see how I could have known. The thing only plugs in one way. Would be nice to know if I've maybe stumbled upon something after all these months.
My multimeter registered 129V out of the HV+,HV- terminals when I measured, and the voltage was constant. Also I hear a soft click when I turn it on.The power plug you are showing has nothing to do with the problem you are facing.
Do you have any voltage at (J1)?
For example, any voltage variation?
Thanks
For the EVAL1, VAUX should be UNregulated.Sounds good, could you please measure all other voltages as below??
Between pin 1 & pin 4 at (J1), you should get 15VDC
At (J5) between pin 1 & pin 3, you should get +22V or +12 based on the regulators AND between pin 2 & pin 3 you should get -22V or -12 based on the regulators.
The soft click seems OK as far as you have steady voltage.
Thanks
I've done that. First thing I did was move the pins on J6 and J7 to positions 2-3 from default positions 1-2. Also put the jumper on J2 to st it to 115v.For the EVAL1, VAUX should be UNregulated.
