I have a question on the heat sinks on the bottom of the Eval 1 and the SMPS. Do you unscrew them, place them under the EVAL 1 and rebolt the whole thing to the chasis, or are they meant to not be unbolted and rather have separate screws be placed into the holes on the bottom of the heat sink, or should i just bolt the completely open holes to the bottom of the case. And do I need any stand offs b/c it seems like the head sink should directly contact the floor of the case to augment the heat sink effect? Is that correct?
I don't see that Purifi supplied any screws or other hardware, so if I need additional screws or bolts or standoffs, what should I order? And where?
I know these questions seem ridiculously basic, but I'm down to the nitty-gritty here, and basic is where the rubber meets the road.
