Have had a Denon AVR-X4700H (as a preamp) for a bit over a week now and have the following observations.
HDMI video mode testing through the AVR-X4700H 8K input (display is a Samsung 75" Q70, Capable of 4K 60Hz, 2560x1440 120Hz, VRR - no eARC):
Due to AVR-X4700H's singular HDMI 2.1 input, your display will need to do any HDMI 2.1 source switching and output uncompressed audio to the AVR via eARC. (I mention this due to XBOX, Playstation, PC, etc.)
Multichannel audio testing:
HDMI testing with an RTX 2080 Super video card was problematic due to previously mentioned electrical noise. Used laptop with Intel UHD 620 graphics for HDMI.
Some sample music files here: 2L High Resolution Music Samples
It is disappointing to confirm that there is only DTS network streamed multichannel audio. However, the good news is that 7.1-channel 24-bit/192kHz PCM does seem to work well over HDMI. With the foobar2000 conversion to PCM, playing multichannel DSD is great.
Not sure what to say about testing with the RTX 2080 Super video card. Other equipment, such as directly connecting the Samsung Q70 and PC, doesn't exhibit this issue. During my testing I did not think to connect the PC to the Samsung Q70 and use ARC to the AVR for audio. I will contemplate if this test is worth the effort.
(Edited to improve formatting)
- 2560 x 1440 (1440P) input is only supported at 60Hz, even tested with the "8K input" configured to either Standard, Enhanced or 8K Enhanced.
- Using a Gigabyte GeForce RTX 2080 SUPER WINDFORCE OC 8G video card as the HDMI input, intrusive electrical noise came through the AVR into the amplifiers even when volume at minimum
- When running games on the 2080 Super, there was unacceptable noise from the video card into the audio system (AVR volume setting had no impact on the noise)
- This noise was not encountered from the same PC's motherboard analog sound output jacks
- This issue was not encountered with HDMI came from a laptop
- Testing with an XBOX One S and XBOX One X:
- 4k HDR Blurays with 7.1, ATMOS, etc. work fine
- No option for 1440P resolution, at either 60Hz or 120Hz (Both available when connected directly to Q70)
- 1920x1080 120Hz does work with the AVR
- Variable Refresh Rate is unavailable (Available when connected directly to Q70)
- Network audio streamed from Plex DLNA server
- Successfully streamed the following over the network (Used HEOS on tablet to select tracks)
- 2-channel 24-bit/192kHz FLAC, displays "192kHz" status
- 2-channel DSD 64 / 2.8MHz, displayed "DSD 2.8" status
- 2-channel DSD 128 / 5.6MHz, displayed "DSD 5.6" status
- 5.1 channel "DTS Coherent Acoustics". AVR display indicates "DTS", surround audio is heard and the appropriate channel indicators illuminate
- All equipment was connected to the same AC power bar, however only the power amplifiers and PC use a grounded plug.
- 2-channel 24-bit/96kHz FLAC (PCM ripped from DVD-Video PCM "DAD" discs)
- 2-channel 24-bit/176.4Khz PCM converted from any DSD format
- 5.1-channel 24-bit/176.4Khz PCM converted from DSD 64 (2.8 MHz)
- As the AVR-X4700H's maximum sample rate input is 192kHz, the closest "natural" PCM rate is 176kHz.
- 5.1-channel 24/88k from DVD-Audio files (Ripped with DVD-Audio Explorer)
- 4-channel 24/96k from DVD-Audio files (Ripped with DVD-Audio Explorer)
- DTS 5.1 Auro 3D (Demo)
- Dolby TrueHD 7.1 ATMOS
- DTS-HD MA 7.1
- DTS:X / DTS 5.1
- DTS-HD MA 5.1 IMAX
