Ya that scares the hell out of me and my solution so far has been just using pro amps with level controls so I use them to set as my max volume in case JRiver does do anything weird!
So your post
finally got me to rewire the system so I can use the OktoDAC8's remote control for volume.
(Which involved switching the Venu360 bi-amp mixer/controller from AES fixed level inputs to Analog, so all 7.1 channels are now controllabe via the OktoD's tiny apple remote.
I'd had the box of 'spare' canare xlr cables sitting up there for almost a year - can
finally put them in storage!)
And yes, there are other ways to do this (or not), and my dac/preamp
already has volume control but I just couldn't use it, so technically a bit off topic.
Anyway - yes, it works fine, and no, I can't really tell any huge difference in background noise or anything else, tho reconfiguring the Venu caused me to have to re-run the autoEQ function, so of course they 'sound better'.
However, now I face (temporarily?) the dilemma of 'which remote (Mouse or Tiny remote) to dive for' when I need to change volume or select different tracks on JRiver!! Oh dear.
So, while it's DEFINITELY an improvement of '
elapsed time to Mute' speed, it's offset a bit by 'choosing which to go for' - and more 'choice complexity' in everyday use (trackball for track change/selections vs. tiny remote for volume changes, tho I can still do that via the trackball).
Probably the biggest 'gain' (hah) is for Movie Night, when I don't have to have the PC display up and have to mess with the trackball to adjust volume levels when one of the movie goers complains about 'too loud' or 'too soft'.
So, to my point - having a 'ready to hand' volume/mute remote, while adding some mental task complexity, sure removes any concern about Windows/JRiver Slapping to Full gain risk.
(PS. Final thought. I've found there's a good 10-15db variation in volume levels across the 4Gb of music files I have, so setting the gains for 'worst case' will reduce my dynamic range - I think - too much. I am trying out JR's adaptive vol control, tho, and while I don't trust it all that much, for casual listening it seems to work fine.)
Jeeze, all this just b/c I can't trust the OS or app to not go batty on me!
Time was it was all just knobs and switches and dials, and stuff just
Did What it Was Supposed to Do (until it Broke, of course).
I sometimes wonder if the 'advent' of software based "control apps" has reset kids' expectations about what 'reliable' means - with consesquent social implications?
"Sometimes the app just doesn't work" "Ok".
No.
NOT OK.
Grumpy Out.
