I tried yesterday but i think i am fcing issues.
I wired everything and i added a sone 5000es blue ray on it. The sound was awfull in the beggining. Then i tired other inputs (aux etc) and another cd. Sound was clear but didnt had enough power. I had volume on 50 and i thought it should be much higher.
Earching around and i found that my salons have some bars on the rear, where you connect the wires and it should be removed?
I think i am kinda lost
When you say bars on the rear of your Revel Salon speakers what I think you are talking about is the jumper straps between the high and low frequency inputs no? The only reason to remove those straps is if you are biwiring or biamping your speakers which is unnecessary. However if you already have speaker cables made for biwiring then it may make sense to use them. What do your speaker cables look like? Do they have just one pair of connectors on each end or do they have two pairs of connectors on an end?
Your McIntosh MC501 amplifiers have three pairs of output binding posts. One pair is for 2 Ohm nominal speakers, one pair is for 4 Ohm nominal speakers, and one pair is for 8 Ohm nominal speakers. You should only connect your speaker cables to one pair of these binding posts. You have the Revel Ultima Salon speakers and not the Revel Salon2 speakers correct? According to the Stereophile review of these speakers, their impedance is rated at 6 ohms nominal, 3 ohms minimum. According to the MC501 manual "If the Loudspeaker's impedance is in-between the available connections, use the nearest lower impedance connection." Meaning you should connect your speaker cables to the 4 Ohm output binding posts of your MC501 amplifiers.
If these speaker connections are made properly we will have to look at the connections to and from the preamplifier. If everthing is connected properly then there may be a issues with some of the equipment.
