Clearly it’s no better than other DACs:take gustard a26 pro with ultra-low noise K2 module
so the result will be different to much better
but I also use mutec ref10
www.audiosciencereview.com
If the listeners knew which set-up they were listening to each time, the tests were meaningless.maybe
mutec ref 10 have jitter 22fs 1hz and 10hz 5fs
it makes a big difference in the sound, a-b test, gustard a26
on my studio monitor neumann 310a.
we were 5 people, they could clearly hear a difference
change 30sec in a-b test
used sacd
pink floyd dark side of the moon
dire straits brother in arms
rammenstein Mein Herz Brennt without compression
You're not going to like it.If the listeners knew which set-up they were listening to each time, the tests were meaningless.
Degradation of what performance? It's still measuring an irrelevant parameter on a network cable...A German fellow measured the Ref10 with a EtherRegen and discovered a degradation in performance:
I guess you're referring to "common mode interferences" when you write "irrelevant parameters on a network cable" (you may want to be more explicit when you wish to experss your opinions).The common-mode interference has also increased by more than 10% compared to operation with an internal clock.Degradation of what performance? It's still measuring an irrelevant parameter on a network cable...
You're the one talking about "performance" without specifying it... I'm just asking you to specify that that is... now I have to be more explicit? This is the world upside downI guess you're referring to "common mode interferences" when you write "irrelevant parameters on a network cable" (you may want to be more explicit when you wish to experss your opinions).
And this is relevant how to audio playback? What actually degrades when I play a song?At any rate, the author also comes to this conclusion regarding jitter level:
"Jitter value of 360pS . Jitter value with internal clock for comparison (see above): 320pS
Ie an increase in the jitter value by over 10%" Degradation or not?
I don't see how me being any kind of grape has any relevance.Ain't you a sour grape?
We're talking about jitter on a network cable. Tell me again how this is relevant to audio playback? The clock of the network data is totally decoupled from the DAC clock. They have nothing whatsoever in common. If you think they have you are welcome to explain.If you believe, like many others here, that any DAC blocks any incoming jitter, then it has no relevant to the playback.
It's no dogma, it's common knowledge.I'm no subscribed to your dogma, so let each person live by their own credence.
Nobody has proven this in any controlled and peer-reviewed tests, so until that happens, I'm good, thank youAnd before you jump on your high horse, establish your "jitter-is-not-relevant" paradigm through proper ABX, not by what your theoretical understanding.
I have.
"Common knowledge? Nobody?" That's appeal to authority. No thanks, I'll do my own experiments.It's no dogma, it's common knowledge.
Something bleeds through the network wire that you so belitte. I did ABX with ER before my streamer, and it certainly distorts the sound in my system.
What authority is that? And if there were any, why would you need to blindly trust it? Knowledge gives you all the tools needed to access the situation an come to a logical conclusion. You can even verify this."Common knowledge? Nobody?" That's appeal to authority. No thanks, I'll do my own experiments.
We’re not talking about noise here. We’re talking specifically about clocks for clocking network traffic. Define “something” and how this has any relation to the network clock and how that would impact the audio clock. Random hand waving does not make for a good hypothesis.Something bleeds through the network wire that you so belitte.
The ear is a pretty bad instrument. Even if it were good, your brain constantly decided to change what the ear delivers. You better know how to separate the two or you are constantly facing false conclusions.the fine instrument sits, is your ears
Anyone who denies that they have thought their system sounded outstanding one night, and then like "something's off" on another night, where nothing at all has in fact changed in the set-up, is a liar.The ear is a pretty bad instrument. Even if it were good, your brain constantly decided to change what the ear delivers. You better know how to separate the two or you are constantly facing false conclusions.
As @amirm said, your ears are not a reliable measurement instrument, and there are numerous scientific papers to back that up. So, again no explanations whatsoever, other than “trust me, I can hear it”…the fine instrument sits, is your ears
you can measure a lot.
but the listening impression you get, how good your hifi system is.
with and without 10mhz master clock.
micro-detail, micro-dynamics, overall definition, and soundstaging
listen to saxophone or trumpet that's the point
that it sounds right with timbre
https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/This is a review and detailed measurements of the Cybershaft Platinum (Palladium) OP16 clock with its optional Ultra Pure Power Supply. It is on kind loan from a member. The clock costs US $1,457 and power supply, US $347.
While "DIY" in nature, I still like the look of these cases. Replacement spikes are provided for the feet as well as necessary cabling:
Normally audio DACs extract the DAC clock from incoming S/PDIF or Toslink inputs. But for asynchronous USB, use their own internal clock. In professional setups with many devices over large distance, a "master clock" is used to synchronize various ADC and DAC devices. At home we don't have such a use but somehow the application has morphed into "better clock" than what is inside your DAC. Some DAC companies provide their own external clocks. Here, we have an independent Japanese company providing it with various grades ("OP16" is one -- it ranges from OP11 to OP19).
I had a hard time finding reviews of this product but did run into this forum post:
I am amazed that his system was not relaxed before arrival of this unit. Wonder how he tolerated it that way....
This device was sent to me by the owner of SMSL VMV D3 so I chose to test it with that DAC.
Cybershaft Clock Measurements
Manufacturers of these clocks like to rave about the accuracy of the clocks in them. But we don't listen to clocks, we listen to analog output of the DAC and that is how I am going to test the effect of these units. Let's first test the VMV D3 with USB input and hence its own internal clock:
Now let's switch to using external Cybershaft OP16 clock:
I can't find any difference whatsoever other than minor run to run variations. Noise, distortion, etc. all seem the same. So we need a more precise test focusing on clock accuracy which is jitter. Let's again run the D3 with its internal clock:
Now let's change to Cybershaft:
As I suspected, performance gets worse, not better! We now have new jitter components we did not have before. Zooming into them we can see better:
How can this happen? Well, I don't care how good your clock is. When it has to travel over a cable and get extracted inside the DAC, it is liable to be worse than the one inside the DAC sitting close to where it is needed. Remember that I said the notion of a master clock was to get synchronization, not better fidelity and we see this here.
Discussion and Conclusions
It is amazing how our lay intuition leads of astray. We assume these clocks are like watches where more accuracy is better. Turns out we are not at all sensitive to absolute pitch as if we were, no one would be listening to analog sources! I can play my music 1% slower or faster (all the time) and you wouldn't know there is anything is wrong. What we care about is consistency of "speed" or clock. This type of variation causes jitter. So the fact that an external clock is "oven controlled," stable over time, etc. is of no value. What matters is that it doesn't vary over time. As I explained above though, best way to get consistency is with an internal clock right close to the DAC, not one across feet and meters of cabling. At best, such an external clock can match what is inside. At worst, it will make it perform worse as we see in the case of D3.
I run my jitter test in every DAC I review. Should that show clean spectrum, which it does in countless high performance DACs, then you don't need or want another clock. All you are doing is wasting money and possibly getting worse objective performance. Fortunately the levels of jitter created here is well below audibility so it doesn't do any harm other than to your pocketbook.
As to people thinking it sounds better, well, that is improper subjective testing for you. They connect the clock, focus into their music and all of a sudden hear detail they had not "heard" before. The combine it with wrong impression of what this device does to fidelity and they convince themselves of the improvement they provide. They need to do a simple AB test by switching the internal DAC and external DAC 10+ times blind and see if they get at least 8 right. Without it, they create folklore which causes people to waste money.
I should note that in the English translation of the Cybershaft webpage I did not find much of any reference to making things sound better so in that regard, I appreciated it but of course, the intent is obvious.
Needless to say, I don't recommend anyone use external clocks with their DACs unless they need synchronization with other devices.
I can't recommend the Cybershaft OP16 clock.
Amir, in my case the external clock improves the sound significantly. It‘s much more natural, more air, darker background and sparkling soft treble. The sound is very much closer to the live act using the external clock. It‘s a difference like night and day. No blind testing needed.
