So I asked ChatGPT for different opinions on the Meze 109 Pro. Here are its first and second (refreshed) answers. I looks to me like if we loose audio writers, ChatGPT will not have any source material to report:
"As an AI language model, I don't have personal opinions, but I can provide you with some information on the Meze 109 Pro headphones and different opinions from various sources.
The Meze 109 Pro headphones are over-ear headphones designed for audiophiles who want a high-quality listening experience. They feature a sleek, minimalist design with a sturdy metal frame and soft, comfortable earpads.
Some reviewers have praised the Meze 109 Pro headphones for their impressive sound quality, with a detailed, balanced sound that doesn't overemphasize any particular frequencies. They also note that the headphones have a wide soundstage, which creates a sense of depth and immersion in the music.
Other reviewers have criticized the headphones for their fit, noting that they can be uncomfortable for some users, especially those with larger heads. Some users have also noted that the headphones can feel heavy and clamp down too tightly on the head.
In terms of pricing, the Meze 109 Pro headphones are considered a mid-range option, with a price point around $400. Some reviewers feel that the price is reasonable for the quality of the headphones, while others think that there are better options available at a similar price point.
Overall, the Meze 109 Pro headphones have received mostly positive reviews, with many users praising their sound quality and design. However, as with any headphones, there are varying opinions on their fit and comfort, so it's important to try them out for yourself before making a purchase decision.
REFRESH:
The Meze 109 Pro headphones have generally received positive reviews from audio enthusiasts and critics. However, as with any product, there are differing opinions and experiences among users.
Here are some common positive and negative opinions on the Meze 109 Pro headphones:
Positive opinions:
The sound quality is excellent, with a balanced and detailed sound signature that works well across different genres of music.
The headphones are well-built with high-quality materials and feel comfortable to wear for extended periods of time.
The included accessories, such as the hard case and multiple cables, add value to the overall package.
The headphones have a sleek and stylish design that many users appreciate.
Negative opinions:
Some users find the bass to be lacking, particularly in comparison to other headphones in a similar price range.
The headphones may not fit everyone's head comfortably, as the ear cups have a relatively small opening and may not accommodate larger ears.
The headphones are not noise-cancelling, so they may not be the best choice for use in noisy environments.
The price point may be considered high for some users, especially if they are not audiophiles or don't prioritize high-end audio equipment.
Overall, the Meze 109 Pro headphones are generally well-regarded for their sound quality and build quality. However, whether they are the right choice for an individual will depend on their personal preferences and priorities.
