You can set the Cosmos ADC to one of the eight input sensitivities using the DIP switches at the bottom of the unit, then go into REW's RTA window, click "calibrate level", enter the input sensitivity that the ADC is set to (e.g. "3.5"), and lastly set the unit in the top left corner of the RTA window to Volt.I want to be able to measure how high of a vrms my system is using, will the cosmos work for that?
It changes the Vrms that has to be present on the Cosmos ADC's inputs to reach 0dBFS output signal strength. In other words: gain.Also, I notice voltage is adjustable on the back, what exactly does changing those do?
Thank you. Is there a standard way to run the 0dbfs test tone?You can set the Cosmos ADC to one of the eight input sensitivities using the DIP switches at the bottom of the unit, then go into REW's RTA window, click "calibrate level", enter the input sensitivity that the ADC is set to (e.g. "3.5"), and lastly set the unit in the top left corner of the RTA window to Volt.
That way, REW will tell you what the signal strength that's present at the ADC's inputs is in Vrms.
One problem: The Cosmos ADC's input sensitivities are not exact. For example, the 1.7Vrms input on my Cosmos ADC is more like 1.811Vrms.
Therefore, if you want precise Vrms readings, you should instead use a multimeter like the Aneng AN870 with a 50/60Hz 0dBFS test tone.
Its measurement error hovers around ±0.3-0.4% in the relevant voltage range:
Additionally, you can use such a multimeter to calibrate REW so that all readings with the Cosmos ADC will display precise Vrms values.
There is none.@staticV3, can you please tell me any reason why a bit-perfect audio player should be used for a voltage calibration of an ADC from the side of an electronic engineer?
True.The Cosmos ADC's input sensitivities are not exact. For example, the 1.7Vrms input on my Cosmos ADC is more like 1.811Vrms.
I don’t think any affordable voltmeter would be more accurate than 0.1 volts anyway tbh.You can set the Cosmos ADC to one of the eight input sensitivities using the DIP switches at the bottom of the unit, then go into REW's RTA window, click "calibrate level", enter the input sensitivity that the ADC is set to (e.g. "3.5"), and lastly set the unit in the top left corner of the RTA window to Volt.
In post #16 of this thread, a customer compared voltage readings of his AN870 to a Keysight U1252:I don’t think any affordable voltmeter would be more accurate than 0.1 volts anyway tbh.
it's way easier to heat things up then to cool them down...there is a temerature dependency of THD measuring with Cosmos ADC too and not all users have the thermostat board installed at their Cosmos ADC. I really dont know why the calibration is done at 27°C environmental temperature, because most users will not have that temperature in their room
You would be surprised how wrong you are abut this.I don’t think any affordable voltmeter would be more accurate than 0.1 volts anyway tbh.
