Connecting One Audio Interface to Another
Altioc
Hello,
I have a MOTU 828es connected to one computer and I would like audio from another computer to be connected to it as well. To that end I have a UMC202HD that is connected to that second computer. From there I connected the two interfaces via a 1/4" TRS cable however the MOTU 828es shows no audio coming from the connection. Is connecting these two interfaces in this way just not something that I can do with this setup?
The computer recognizes the UMC202HD interface as its output and input devices and If I unplug the TRS and instead plug my headphones directly into the output from the UMC202HD then I hear audio. The connection between the first computer and the MOTU 828es works fine. I have attached a diagram of my setup currently.
Any help would be greatly appreciated.
Blumlein 88
Should work that way. I don't know why you want the Motu output to the 202 however.
A
Altioc
The other computer needs the microphone input from the Motu
