This the very reason I've decided to use min phase version of the microphone calibration. At least mic phase effects will not show up in excess phase graphs.this might make the linear phase ideal in the bass ilusional
The filter you produced here should have caused a light pre-echo effect according to my theories but it doesn't. I literally convolved it and played an echo crazy track and there was none of it.Maximum Q=4 for an APF is probably is still "acceptable" -- any more than that I wouldn't use...
Hello,
Getting back to you with some insights (& sample of measurements!)
STEP1:
Post IIR tuning, I performed multiple measurements in the LP area, which allowed my to get an average SubLt+SubRt
Following @ernestcarl advice I average SubLt+SubRt and applied the inverse phase method (@dasdoing , @ernestcarl ) which was straightforward using REW 5.20.13-14, and the snapshots in this thread; the resulted FIR was applied using EQAP.
Last, Remeasured SubLt, SubRt (separately).
Simulation was accurate! the Sub delay was reduced to create a nearly perfect spectrogram.
When listening to selected tracks, pre-ringing was not noticed, sound was tight, and the 3D image was laser sharp, and seems like detached from the speakers. Thanks for that friends!
(see part 1)
STEP2:
Nevertheless, As can be seen by the measurements there is still a delayed sounds in the100-250Hz region,
Curious to understand that, I run few preliminary checks, which clearly pointed out that it is not related to the sub (changing sub crossover & Sub was bypassed (part 3) but most likely a cluster of modal peaks caused by non-ideal, untreated room :/ (== life).
Changing the speakers position obviously influence (part 2) but not to a degree that notably reduce it, I am thinking now to run measurements on alternative LP to get to a possible better sweet spot (maybe a room for another thread in the Room correction forum )
Last,
I also approached Wharfedale service to see whether they have some quantitative inputs on the possible delay caused by active amplification of the sub (where I suspect the main chunk of delay comes from) - no answer yet but submitted my question only 2d ago, so I guess they will get back to me in few days.
I guess this 'bulletin' may bring question which I am willing to answer. vast data can also be shared (currently working to arrange it to be more self explanatory).
what is the worst thing in that IR? it is an anoying resonance at 379Hz.
see if you hear it. if not I can provide examples of before and after.
the thing is, i atenuated it 50q and 6dB it it was still not gone.
had to atenuate 12dB.
I see this as an disturbing example of how the standard procedures might not be enough. because I don't think any EQ correcting method could figure that out. or could it?
can you guys hear it?
You have to know the details about the measurement procedure performed (including reliability and repeatability) and other setup minutiae.
I am also in favor of the step-by-step approach (audiophile endless journey )Did not the think too much about all that other stuff as primary question was with the sub’s response. There’s so many variables why room measurements are so far from ideal — but, I think that’s the norm — better to isolate one by one the different possible sources and have another reference to compare.
I haven’t really tried convolving the OP’s IR so I can simulate hearing his speakers for myself. You have to know the details about the measurement procedure performed (including reliability and repeatability) and other setup minutiae.
I think we can agree that what we are doing here is more theoretical than practical.
Neveetheless @dasdoing , it seems like you believe that that 400Hz resonance is more influential?
As a first step, and for your own reference, find out how a "clean" (anechoic or very nearfield and/or filtered/gated and well away from boundaries) measurement of your speakers looks like compared to a sweep at the real MLP.
Rythmik F12 subwoofer manufacturer measurement vs in-room
*red trace taken only few cm (5? or something) from cone surface
Main studio monitors
View attachment 301101 View attachment 301102 View attachment 301103 View attachment 301104
[ErLan] And - expecting a similar room influence on them - should I use them for some sort of normalization? Or are they more for a semi quantitative reference that demonstrates the topmost potential of the results I can get with that speaker?
Some of your USB mic measurements also look "glitchy" (can happen in the beginning, middle or end of the sweep). XLR mics that share the same clock sync as the outputs don't normally suffer from this kind of issue.
[ErLan] I guess it requires a dedicated audio interface?
Looking at my spectrogram, I thought next step should be the 100-350Hz resonance(?) That may smear the sound in that range. Neveetheless @dasdoing , it seems like you believe that that 400Hz resonance is more influential? (If so, why?)
what I heard in the first left IR you posted is following:
here is the drum intro of Billie Jean convolved with the IR, and than it repeats but with a single notch filter engaged:
hopefully it becomes clear how much this filter cleans up the audio
use headphones https://drive.google.com/file/d/1-pHLLrkzCRQw2cOTPK3jfC_DzuuFy2-W/view?usp=sharing
now I don't know if this is really that dramatic in the real room.
that first MDAT was single measurement?
the second MDAT averaged?
I hear another high pitched resonance at another part in MJ's voice
