It gets as high as it can get given whats your network impedance is and the input impedance of the amplifier is when there is no energy in its storage capacitors .but if u are not lucky ... how does that affect Inrush current?
For the first miliseconds i would guess (peak voltage)/(the dc resistance of the wiring plus the DC resistance of the transformer.) but the inductance of the wiring and transformer might add some impedance so it might not be that bad .
I would just pick something with a slow characteristic and not overthink , but I have no clue about local rules .
I would consider if the amps is broken if started to behave like this ? or has it always been like that ?
Are there a lot of other stuff on the same fuse ? you might also start up things in sequence turn off other stuff while powering up the amp ?
