CD player vs. DAC sound - can you hear a difference? (listening test)
Can you hear a difference between the files?
  • Yes
    Votes: 3 18.8%
  • No
    Votes: 13 81.3%
  • Poll closed .
pma
Prague
To contribute a bit to discussions on digital sources sound, I have prepared a test. The same song is recorded with ADC once from a CD player analog output and also from a DAC analog output. Two files, level matched before recording by a good quality analog pot and time aligned are uploaded here:
https://drive.google.com/file/d/137lGBoMJF2eZjmJhIeu2jP4rQeBBealv/view?usp=sharing
So if you are interested, please download the file, unzip, listen to the music files and let me know your thoughts. As always, foobar ABX test record would be appreciated.
Blumlein 88
Some interesting things in the results using Deltawave. I'll give it a listen tomorrow, and see how audible it is.
abdo123
Brussels, Belgium
my best chance was with the CD player having more crosstalk but that wasn't the case.
it's pretty transparent.
Reactions: pma
charleski
Manchester UK
As usual, on first listen I thought the second sample (beta) had a slightly better frequency balance. But no, going back and forth I couldn't replicate that. Do a frequency scan and beta (in green) has very slightly more top-end from about 5kHz on.
Trying to null out the samples leads to the usual problems with sub-sample phase alignment. I found that adding a 1-sample delay to beta resulted in a slightly better null.
Nulled as-is:
Nulled with a 1-sample delay to beta:
Reactions: pma
Blumlein 88
Nulled as-is:
Get Deltawave it's free and does sub sample alignment for you. Do a search for deltawave and pkane who is the author.
artburda
Switzerland
foo_abx 2.0.6d report
foobar2000 v1.6.4
2021-07-12 14:47:15
File A: alpha.wav
SHA1: 2edddc4333a3ee2f43f3d2c02602433f5b09f783
Gain adjustment: +2.25 dB
File B: beta.wav
SHA1: d6e8965b8daaeb938d38f415a952adbd5bd8df00
Used DSPs:
FabFilter Pro-Q 3
Output:
ASIO : MOTU M Series
Crossfading: NO
14:47:15 : Test started.
14:48:08 : 00/01
14:48:38 : 01/02
14:49:04 : 02/03
14:49:11 : 03/04
14:49:17 : 03/05
14:49:24 : 03/06
14:49:33 : 04/07
14:49:42 : 04/08
14:49:51 : 04/09
14:50:37 : 05/10
14:50:37 : Test finished.
Total: 5/10
p-value: 0.623 (62.3%)
-- signature --
bcaa1ad04f8c481ea27fb820fde19a1bf210ba65
Reactions: pma
pma
pma
Prague
Nulled as-is:
Thanks for trying the test. I think you got it quite right, the biggest difference is in filters. Though the "alpha" has minimum phase filter, "beta" has steeper linear phase filter. There is a difference at the highest frequencies, audible in a difference file, but most probably inaudible in the ABX with complete files.
The linear difference in amplitude/phase response is a part of the transfer function and possible audibility and should not be removed with diffmaker or deltawave - this is a message to @Blumlein 88 .
pma
pma
Prague
foobar2000 v1.6.4
2021-07-12 14:47:15
File A: alpha.wav
File B: beta.wav
Used DSPs:
FabFilter Pro-Q 3
Output:
Crossfading: NO
14:48:08 : 00/01
14:48:38 : 01/02
14:49:04 : 02/03
14:49:11 : 03/04
14:49:17 : 03/05
14:49:24 : 03/06
14:49:33 : 04/07
14:49:42 : 04/08
14:49:51 : 04/09
14:50:37 : 05/10
Total: 5/10
-- signature --
Thanks for trying the test!
artburda
Switzerland
What CD-Player, DAC and ADC have you been using btw? Or will you reveal the used devices as well as alpha and beta only after the poll has closed?
pma
pma
Prague
Yes, later. It is not very important.
I will reveal at least something now. The sound source is CD. Once it was taken directly from the balanced output of the CD player, to the balanced preamp which served to equalize volume. From the preamp balanced output the signal went to balanced input of the sound card.
In the second recording, the coaxial SPDIF output from CD went to DAC input. From DAC balanced output to the same preamp and ADC as described above.
pkane
North-East
View attachment 140677 View attachment 140678
Why would phase difference be removed? DeltaWave does not do any filtering on the files unless you ask it to, and then you have a choice of linear-phase or minimum-phase filters.
Here's the phase difference between the two files:
3125b
Germany
The differences aren't really audible (certainly not just played back to back with foobar).
Not the most comprehensive tool, yet Dynamic Range Meter does show them to be slightly different.
charleski
Manchester UK
Yeah, if you lin-phase upsample the files you have more resolution for aligning them, which is what I assume Deltawave does. But I can't get Deltawave to produce a difference spectrogram with a log frequency axis, which makes it harder to see what's going on.
pkane
North-East
No, the files are not upsampled unless you specifically ask for this. All the processing occurs at the original sampling rate.
Tatr76
I use foobar2000 so will have a go once figure out abx test. Just to add an only anecdotal observation is when Playing CDs in the past and had someone switch inputs on my amp between dac input fed by optical in from CD or straight from CD player via rca could not really tell when it was done let alone discern any difference in musicality.
pma
pma
Prague
Here is the more thorough result shown with Adobe Audition. IMO not bad taking into account the fact that the level matching was made purely in the analog path by means of blue Alps volume pot.
pkane
North-East
By the way, thanks for reminding me! This is something I planned on adding more than a year ago, but couldn't find the time. Should have this added later today :)
charleski
Manchester UK
So how are you doing sub-sample alignment? Does it interpolate between samples?
That will be great.
