Bookshelf speakers, small room, close to wall.
Current list:
Revel Performa M106
Ascend Sierra EX v2
Ascend Sierra LX
Focal Vestia No.1 or Aria 906
Spendor Classic 4/5 or A1
Legacy Audio Studio HD
I also tried ChatGPT, now with this list. See the result:
Let's sort the listed loudspeakers based on the three criteria:
1. Minimum SPL 95 dB with a 50-Watt amp:
This criterion evaluates sensitivity or efficiency, which determines how loud a speaker will get with a certain amount of power. Speakers with higher sensitivity ratings (typically above 87 dB) will be better suited for this.
2. Fit for Near Wall Placement:
Speakers with front-ported or sealed cabinet designs are generally better suited for near-wall placement as they minimize bass boom and room interaction.
3. Availability in the U.S.A.:
Brands with a strong distribution network in the U.S. or ones that are made in the U.S. will score better on this criterion.
Sorted List:
  1. Legacy Audio Studio HD
    • SPL: 94 dB (high sensitivity; can reach 95 dB with minimal power)
    • Placement: Front-ported, good for near-wall placement
    • Availability: Made in the U.S., widely available
  2. Ascend Sierra LX
    • SPL: 91 dB (good sensitivity for a 50-Watt amp)
    • Placement: Front-ported, suitable for near-wall placement
    • Availability: U.S.-based company with strong availability
  3. Focal Aria 906
    • SPL: 89.5 dB
    • Placement: Front-ported, decent for near-wall placement
    • Availability: French brand, but widely available in the U.S.
  4. Revel Performa M106
    • SPL: 87 dB (lower sensitivity; requires more power to reach 95 dB SPL)
    • Placement: Rear-ported but has boundary compensation, manageable near-wall placement
    • Availability: Well-distributed in the U.S.
  5. Focal Vestia No.1
    • SPL: 90 dB (better sensitivity than Aria)
    • Placement: Rear-ported, less suited for near-wall placement
  6. Ascend Sierra EX v2
    • SPL: 89 dB
    • Placement: Rear-ported, not ideal for near-wall placement
    • Availability: U.S. brand, good availability
  7. Spendor A1
    • SPL: 84 dB (low sensitivity; not ideal for a 50-Watt amp to reach 95 dB SPL)
    • Placement: Sealed design, perfect for near-wall placement
    • Availability: U.K. brand, moderately available in the U.S.
  8. Spendor Classic 4/5
    • SPL: 84 dB (low sensitivity, requires more power)
    • Placement: Sealed, good for near-wall placement
Summary:
  • Legacy Audio Studio HD is best for reaching high SPL and works well near walls, with excellent availability in the U.S.
  • Ascend Sierra LX is a good second option with reasonable sensitivity and near-wall placement capability.
Sorted List:
  2. Ascend Sierra LX
  3. Focal Aria 906
    • SPL: 89.5 dB
    • SPL: 89 dB
  7. Spendor A1
Summary:
The Legacy Audio has a sensitivity of 86dB according to John Atkinson's measurements and the Ascend Sierra-LX has a sensitivity of 82dB according to their spinorama. They are also both rear-ported, not front-ported. Can't trust that robot.
I confronted the »robot« with this :cool: ... It then changed the ranking:
Corrected Sorted List:
  1. Focal Aria 906
    • SPL: 89.5 dB
    • Placement: Front-ported, well-suited for near-wall placement
    • Availability: Widely available in the U.S.
  2. Revel Performa M106
    • SPL: 87 dB
    • Placement: Rear-ported, but includes boundary compensation, somewhat suitable for near-wall placement
  3. Focal Vestia No.1
    • SPL: 90 dB
    • Placement: Rear-ported, less ideal for near-wall placement
  4. Ascend Sierra EX v2
    • SPL: 89 dB
  5. Legacy Audio Studio HD
    • SPL: 94 dB (high sensitivity)
  6. Ascend Sierra LX
    • SPL: 91 dB
    • Placement: Rear-ported, not suited for near-wall placement
  7. Spendor A1
    • SPL: 84 dB
    • Placement: Sealed design, great for near-wall placement
    • SPL: 84 dB
    • Placement: Sealed, excellent for near-wall placement
Summary:
  • Focal Aria 906 now takes the top spot due to its front-ported design, making it the best suited for near-wall placement while still meeting SPL requirements.
  • Rear-ported speakers like Ascend Sierra LX and Legacy Audio Studio HD rank lower due to their placement limitations, despite good sensitivity.
  • Sealed speakers like Spendor A1 and Classic 4/5 are best for near-wall placement but have lower SPL, making them less suitable for high SPL demands with a 50-Watt amp.
  1. Focal Aria 906
    • SPL: 89.5 dB
    • SPL: 87 dB
    • SPL: 90 dB
    • SPL: 89 dB
  6. Ascend Sierra LX
    • SPL: 91 dB
  7. Spendor A1
    • SPL: 84 dB
    • SPL: 84 dB
Summary:
Hmmm...
I appreciate the help for sure.....but, the 'machine' still not without errors.
Vestia is front ported, for one.
The SPL for Spendor is a concern with a 50w amp. I think we can cross those off the list for that reason, right?
Current list: (In order, based on my summation of this thread so far?)
Revel Performa M106
Focal Aria Evo X No. 1
Ascend Sierra EX v2
Ascend Sierra LX
Question: With speaker placement close to the wall, what does the science say regarding the expected measurementsand performance for front ported vs. rear ported with plug ?
You can find Spendor A1 in open-box or demo status for $1900. Neutral, made in England. I don't understand 95 dB in a small room.
95 dB above the subwoofer band is very loud and only tolerable for showing off a movie scene IMO. Generally you want to listen between 75-85 dB and have the subs putting out 85-95 dB.
Agreed.
This is why I specify peak. I would like them to play up to 95db comfortably. That does not imply I listen to that volume regularly. I don’t want them to distort below that volume, is my thinking.
A speaker placed from a wall at a distance equal to the diameter of a round port has negligible impact on port tuning.
If the port is plugged, it won’t matter where it’s located since it no longer works.
To copy/paste what I said on pg1 just as a reminder,
“Anything can be used close to the wall with proper room treatments and EQ.”
That should be any traditional boxed speaker. Not just anything.
Revel Performa M106
Ascend Sierra EX v2
Ascend Sierra LX
Looking at some pics of those speakers I was surprised to find none of them really looking nice enough for me to want one. The looks of some of those speakers even emit a DIY aura, especially their backsides.
Well – to me, speakers not only have to sound good but also have to look good. Remember: The look is always present, even if the speaker is silent :cool:
You often look at the back side of a speaker after it's set up? Only speakers I can even see that complaint being valid against are the Ascend Sierras anyway. All the rest look quite nice and professionally made. Nothing more subjective than aesthetics, though.
A port's a port, but the binding posts do not look great, that's for sure. Perfectly functional, but clearly a cost savings area. Which is fine with me, spend on the drivers!
Aesthetics are very much subjective, but I do think people should consider that, since not liking what you see can be a bit of a downer
In 20 years, my natural finished laminate bamboo cabinets will look exactly the same, even if they need some scratches touched up. Veneer? Maybe not. That construction was one of the reasons I went with the LXs, admittedly low on the list, but it was on the list. Do I think other speakers look better? Sure, sonus faber makes some absolutely beautiful speakers, the lumina 2 amator is certainly attractive.
Ugly frequency response, but pretty to look at.
Do we have the measurements of SF Lumina II Amator available somewhere? I have only seen the test results of the older Lumina II version.
My bad, it was the earlier one I was looking at the frequency response for, not the Amator.
From my personal experience, rear-ported speakers just don't work well near a rear wall. You need a sealed or front-ported speaker.
Here is a comparison of Spendor's specs between the A1 and the A1.2.
