- Joined
- Feb 20, 2023
- Messages
- 5
- Likes
- 2
Hi everyone,
There may be an identical question asked elsewhere, but I couldn't find it so hopefully you can help me out. I'm looking for some small bookshelf speakers for near-field listening with high sensitivity. I'm located in the UK so that may affect recommended brands/options.
3 4 potential options within my price range while also being less than 230mm deep. I could find reviews/measurements of some of the larger models but I'm not sure if it's safe to assume they scale down and I can expect similarly good performance for the smaller version.
Thanks,
John
- Maximum speaker depth of 230mm (9"), preferably around 200mm (or ~8") to fit on the monitor shelf on my desk
- Room is approximately 3.0 x 3.0m (10 x 10ft) with my desk up against one wall
- My amp is rated to 10W at 8Ohm so ideally it would be an 8Ohm rated speaker with >86dB sensitivity
- Price in the range of £200-300 (or $250-400) ideally
- Bonus points for being visually appealing though this is secondary to the audio qualities
- Wharfedale Diamond 12.0 available for £199 -> 12.1 model measures well (Amirm's Review / Erin's measurements)
- Mission LX-1 Mk2 available for £184 -> LX-3 model measures reasonably well but needs EQ for best performance (Amirm's Review)
- Dali Spektor 1 available for £179 -> Dali seem to be well liked but this model didn't measure very well (Amirm's Review)
- Polk XT15 available for £139 -> Added to the list following staticV3's suggestion. Cheaper option that also measures well (Erin's Measurements)
Thanks,
John
