Bookshelf speakers, small room, close to wall.
Some suggestions:
- Amphion Argon 1: Made in Finland; approx 1300 € / pair VAT included; 86 dB sensitivity at 8 ohm, so You might get the desired peak volume in a small room.
- Elfton Vigo MK II: Made in Czech republic; approx 1900 € / pair; 91 dB sensitivity at 4 ohm, they go loud and with front facing reflex ports you can place them quite close to wall, size = 485mm x 300mm x 280mm, so they are close to Your limit regarding the size.
I appreciate your response.
Elfton is not readily available in the US.
I am not familiar with Amphion, but also do not appear widely available in the US.
Regarding ATC 7; Your 50W amp may not be enough though. My brother has the smaller 7's but drives them with 150w/ch and he seems to think they sound better now than with his previous Advance Accoustics 100w/ch amplifier
Regarding ProAc Tablette 10 or 10 Signature may be worth a look. They look lovely, never mind the sound :)
Appreciate your response.
ATC is off the list for your stated reason. I have heard that you need more to drive them, as well.
ProAC speakers mentioned have been noted by others to sound thin in mid/bass and a little bright. Not best suited for Rock at higher volumes. So, not for me.
So it looks like my running list is:
Confidently recommended:
Revel Performa M106
Ascend Sierra EX v2
Ascend Sierra LX
Focal Vestia No.1
Kef LS50
Buchardt S400 MKII
Spendor Classic
Something from Dynaudio. Model.
How should these be ranked to accomplish my goals?
Very much appreciate the help from this community. :)
Dynaudio Evoke 10 would work, they come with foam bungs if being placed close to the wall. Not super efficient but are happy to take a lot of punishment at high volumes.
Emit 20s are cheaper, with a bigger woofer, from the base model range.
Dynaudio are generally not fatiguing over long periods and can play loud.
Legacy Audio Studio HD (if can be had second hand at reduced price)
Dynaudio Emit 20 = Made in China, I fear :(
running list is:
Revel Performa M106
Ascend Sierra EX v2
Ascend Sierra LX
Focal Vestia No.1
Kef LS50
Buchardt S400 MKII
Spendor Classic
Running out of ideas :)
As to your list, I don't know any of them but had KEF's LS50 wireless 2. Not for long, dynamically limp but that could just have been the internal Class D amplification (AB to treble).
running list is:
Revel Performa M106
Ascend Sierra EX v2
Ascend Sierra LX
Focal Vestia No.1
Kef LS50
Buchardt S400 MKII
Spendor Classic
Buchardt is China too. Probably Kef LS50 too.
Yes. Almost everything below the Reference series from KEF is produced in China. I believe the new Q Series Meta is produced in Thailand, although I might need to check that.
Hi,
Bookshelf/monitor speaker recommendation under 2k/pair?
Here are the must haves:
Small room requires near wall placement.
For rock/blues music comfortable handle 95db
Nothing made in China
Small footprint, under 20” high
Neutral, not “bright”
Might consider used
Paired with vintage McIntosh 50W
Existing sub
Thank you very much for your help :)
Alright. I asked ChatGPT for a list prioritized and based on fact checking of measurements that are not bright but neutral.
### 1. **Neumann KH 120**
- **Height**: 10.2”
- **Max SPL**: 111 dB
- **Country of Manufacture**: Germany
- **Key Features**: Compact studio monitor with excellent clarity, flat frequency response, and strong bass performance for near-wall placement. Designed to handle high SPL without distortion.
- **Price**: $1400 per pair
- **Why it's suitable**: The KH 120 is a professional studio monitor with robust output and near-wall placement compatibility. Perfect for small rooms where accurate and neutral sound is essential.
### 2. **KEF LS50 Meta**
- **Height**: 11.9”
- **Max SPL**: 106 dB
- **Country of Manufacture**: UK
- **Key Features**: Uni-Q driver array delivers precise sound even in near-wall setups. Compact yet capable of filling a room with rich, clear sound.
- **Price**: $1599 per pair
- **Why it's suitable**: The LS50 Meta has a small footprint, excels in smaller spaces, and handles dynamic rock/blues with ease.
### 3. **ATC SCM7**
- **Height**: 12.1”
- **Max SPL**: 103 dB
- **Key Features**: Known for its neutral and flat response, this speaker delivers great detail and control even in compact spaces.
- **Price**: $1,600 per pair
- **Why it's suitable**: Ideal for small spaces, SCM7 handles high SPL comfortably, providing a transparent sound that suits rock/blues.
### 4. **Dynaudio Evoke 10**
- **Height**: 12”
- **Max SPL**: 104 dB
- **Country of Manufacture**: Denmark
- **Key Features**: Designed for small-to-medium rooms, it offers a balanced and dynamic sound, especially suitable for near-wall placement.
- **Price**: $1,499 per pair
- **Why it's suitable**: Compact with an ability to comfortably handle rock/blues at high SPL while maintaining clarity and balance.
### 5. **Focal Aria 906**
- **Height**: 15.4”
- **Max SPL**: 109 dB
- **Country of Manufacture**: France
- **Key Features**: Combines neutrality with punch, and can handle loud rock music with ease while still performing well in smaller rooms.
- **Price**: $2,190 per pair
- **Why it's suitable**: Handles loud SPL with ease, fits within a small footprint, and works well in smaller rooms.
### Conclusion:
All these speakers are under 20” in height, can comfortably handle high SPLs (over 95 dB), and perform well in small spaces with near-wall placement. The Neumann KH 120 and KEF LS50 Meta are standout options for near-field listening and high SPL requirements, while the ATC SCM7 offers neutral sound for audiophile tastes in small rooms.
Thank you for pointing this out. They are now off the list.
Revel Performa M106
Ascend Sierra EX v2
Ascend Sierra LX
Focal Vestia No.1
Spendor Classic 4/5 or A1
How would you rank them? Which would you recommend for your family member with the stated goals of the first post?
Thank so much for you help in develping this list.
Splendid idea!
Actually, we should ask ourselfes why it had taken that long for us folks here to use that info tool :cool:
Should be used with great care and a critical mind. It is not always right.
Correct. Thanks for your help.
Neumann KH 120 - out because it is an active speaker.
KEF LS50 Meta - out b/c MIC
ATC SCM7 - requires more powerful amp than 50W to drive them adequately
Dynaudio Evoke 10 - out because MIC
Focal Aria 906 - a possibility.
Current list:
Revel Performa M106
Ascend Sierra EX v2
Ascend Sierra LX
Focal Vestia No.1 or Aria 906
Any strong comparative opinions on these for my application?
Current list:
Revel Performa M106
Ascend Sierra EX v2
Ascend Sierra LX
Here are some measurements of the Legacy Audio Studio HD from Stereophile. Doesn't look great to me.
Here are some impressions and in-room measurements of the Focal Vestia No.1 from a member here on ASR. Looks to have the typical Focal tweeter dispersion characteristics which I don't like the look of on a graph but have never actually heard.
The Spendor models have a 6" woofer and a 22mm tweeter with a specified crossover frequency of 4,200 Hz... That will probably result in a large directivity mismatch and poor directivity with that flat baffle. Maybe I am judging a book by its cover but I can't understand why such a mundane design costs so much compared to other options with more advanced engineering efforts put in.
The other 3 options measure very well and personally I would want to hear them in my room to make the best decision. I lean towards Ascend Acoustics over Revel just because I like that they're a small US based company with direct support rather than Revels sparse dealer network.
