Bookshelf speakers for low volume & near-field listening?
redshift
Wow! Phantastic looking!
About the speakers? Full-range high-end. Perfect phase behave! ;)
Doge such amaze Hifi.
redshift
Not at all. Surely not as dear as the steampunk above lol.
Here’s my workstation Silver 50 near field setup. One cover removed for your viewing pleasure. The amp? A so-so Marantz.
Doge not sure about painting.
Sakelccc
Sakelccc
wow those in white look absolutely Fantastic!
maybe pretty face is the cure. doesn't really matter if they don't measure that well haha.
kotmj
I'd recommend the Harbeth P3esr. They're a direct descendant of the LS3/5a, and the build quality is heirloom level.
The designer, Alan Shaw, spends several months developing each crossover, making minute adjustments by ear. They are foremost optimised to reproduce the human voice---he uses a CD recording of his daughter's voice for this purpose. He developed the first of the series, the HL-P3, in his attic bedroom. As a matter of policy, his speakers are meant to have a lush, rich sound at relatively low volumes. The P3esr were for near field listening, where "when you could just touch the speakers with your arms stretched out".
redshift
They sound quite good in my deaf ears and halfwitted biological DSP. For sure they can’t measure that bad? Now that I think about it; you’d better listen to them first.
Anyway, your run of the mill software EQ can sort that out in a hurry. I only got a loudness plugin slapped on in the audio pipeline.
I admit I’m getting picked up as a faint signal on the gaydars. Not sure why? Perhaps it’s the color?
:eek:
kotmj
Does Toole have anything to say on desktop, near field speakers for very small rooms?
Grotti
I now those speakers and despite a clear lack of bass they sound nice. A little to expensive for my taste when I compare it to similar sized Genelec and Neumann speakers.
What I don't buy for one second is the story of the engineer, sitting in a lonely lab and soldering crossover after crossover until the voice of his daughter sounds right. Either this is marketing BS (very likely) or he doesn't have the slightest notion how speakers are developed nowadays.
Anyways: sorry for being slightly of topic.
redshift
That’s my definition of near-field. Are those speakers drivers moving in-phase?
kotmj
That's actually how it is. He would unwind a few windings on an inductor and reinsert into breadboard. He would agonise over 0.2ohms on a resistor. He has no deadlines: he's only done when he's done. He asks for nobody's opinion. At a recent fair a female interviewer asked him who listens to his completed speaker first. "You," he said. "You must have confidence in your design."
Model lifecycle at Harbeth is about 10 years.
Do subscribe to the Harbeth Users Group. It's his blog. He documents his life there.
Crossover of the HL-P3.
redshift
It depends if you got a solid reference to compare with. For example a pair of calibrated monitors or decent headphones, switching back and forth.
I’m sure it’s possible to tune them reasonably well by ear if you got a knack for it and some pots ready for trimming.
kotmj
I don't know. The guy currently designing PS Audio's inaugural speakers, Darren Myers, has them on his work desk and is enthusiastic about them.
Grotti
I now this story by heart. Alan Shaw IS Harbeth and the hole story is part of his unique selling point. But I still can't believe, that a graduated engineer like him doesn't make use of all the software out there which helps manufacturers like the before mentioned Neumann and Genelec (or Revel, Kef etc...) to develop SOTA speakers right to taste (Harman curve!) in reasonable time.
It just fits too perfect in the cliché of a small high end manufacturer. If he would be able to reach his goal ("perfect replication of his daughters voice") in much shorter time by using modern development tools: don't you think he will use them? Or actually does in order to get the job done without spending months unwinding coils?
redshift
My thinking is that there is something inherently wrong with a speaker that requires heavy DSP/EQ processing to have a flat frequency response.
A first order jobbie should do the trick to keep it well-behaved within a couple of dB’s within its expected bandwidth. Then the analogue parts could be removed and replaced by an EQ/DSP for the ultimate in flatness.
