Slave IV
- Joined
- Oct 11, 2024
- Messages
- 48
- Likes
- 44
- Thread Starter
- #21
lol! I thought something was off with my autocorrect phone typing but obviously wasn’t thinking hard enough on that part.Not mine, I just linked to it since I have used it a lot. The equations are well-known but I am too lazy to dig up my old graduate accoustics book and look them up again.
"Damping"; "dampening" is about getting wet.
We are fairly insensitive to distortion in music, depending on the type of distortion, and unless something is broken the speakers are usually orders of magnitude higher in distortion than the electronics.
Speakers and room most certainly have the biggest influence on the sound, with amplification a distant second unless the amplifier is not up to the task. An underpowered amplifier that is clipping, one with high noise level, or one with high enough output impedance that it changes the expected frequency response of the speakers are common issues when folk really do need a different amplifier.
The answers are usually (should be) qualified by all sorts of stuff I and others have been saying. It is not just power, but the amount and type of distortion, noise level, output impedance, input sensitivity/gain, and less tangible things like build quality, warranty, and so forth all factor into choosing an amplifier. IMO there is a bias here for performance, such as Benchmark's AHB2 and similar amplifiers that exhibit outstandingly low distortion and noise, that clearly outperform any AVR I have read about. But how much of the difference is audible is up for debate; many people would be astounded to discover how little difference in sound there is among competent amplifiers driving typical speakers at levels well within the amplifiers' power range. But there are always exceptions, difficult speaker loads, noisy amplifiers, etc. that lead to marketing that "everybody" has systems that are above average and represent extreme cases requiring only the best (or at least most expensive) amplifiers on the planet.
In practice, the answer to your last question is "yes" more often than people think, even among amplifiers considered widely disparate like tube and solid-state designs (not all tube or SS amps, natch). But I have added amplifiers to an AVR that was clearly not up to the task of driving an array of inefficient low-impedance speakers, and also experienced the case of finding no difference between the sound of a different AVR driving the same speakers with and without an amplifier. Easily measurable in both cases. If one amplifier produces (or is rated for) the same power but >1% distortion whilst the other is delivering the same power at 0.1%, you may tell the difference. Similarly if one amplifier's output impedance is a few ohms (e.g. a tube amplifier) and the other is a SS amp with output impedance <0.1 ohms, again you may be able to tell a difference in frequency response for certain speakers. The problem is figuring out what we actually hear versus what we think or what to hear, and that is where controlled testing becomes so important. I have on many occasions been sure of the difference between two components, only to discover there was none I or others could hear in a blind test. And almost as often discovered differences I did not expect among similar components. Life goes on.
Whatever - Don
This all makes sense and it’s all definitely making me more at ease when it comes to amplifier selection in the future. I know it’s hard to say how much of a difference people can hear and how much it is worth to pay more for an amplifier. I still believe it does make a difference but keep in mind, I didn’t go out and pay thousands of dollars for an amp, which before too long ago, I thought was the only option if I wanted a high quality external amplifier to run my system. Before I did this test with my receiver, I did do some proper a/b testing in another room with another amp and a switcher where I matched levels and was able to seamlessly switch between two different amp and two different speaker setups. To me, the sound differences were so subtle, I could barely tell the difference but there was still something changing. When I brought in my blind tester, they knew nothing other than sitting there listening and they were able to describe changes as soon as I switched anything. Their observations were in line with what I thought could be the differences and their preferences were different depending on the type of music I was playing and these preferences all made sense to me based on which setups should be more ideal for the respective types of music I was playing. I would say that overall, the preference was mostly for the other amp, that is rated at under half the power output of the monoblocks but running with a tube preamp. So anyways, I am convinced that the monoblocks are an upgrade over my receivers internal amps, enough so that they are worth the few hundred dollars they are. I’m also convinced I probably wont ever need to spend thousands on a mega-powered, prestigious name brand amplifier. I’m pretty happy where I’m at now with what I have and will probably pick up one more matching or similar amp down the line so my front three can all be externally powered but no hurry for that. As I said earlier, I’m not going to mess around with this stuff too much anymore until I can commit to a fully active speaker system.
