BitPerfect_
- Joined
- Jul 11, 2021
- Messages
- 189
- Likes
- 45
Hi,
Let’s suppose we have an amplifier with Speaker A and Speaker B outputs, rated for A+B operation at 8–16 ohms. We are using the Speaker A output to feed the LF section and the Speaker B output to feed the HF section of a pair of L/R speakers (8 ohms each), which constitutes Passive Bi-Amping.
I am already aware that Bi-Wiring, in general, is purely marketing driven by cable companies, and Passive Bi-Amping is essentially the same as Bi-Wiring, as I discovered while watching the educational videos. However, I am still interested in understanding these aspects because I’ve come to this realization after years of using my speakers in Passive Bi-Amping A+B mode, I have purchased these different cables. Thanks,
- Using two different cables (e.g., 3 meters L/R of 2.5 mm² silver-plated for HF and 3 meters of 4 mm² OFC copper for LF), could this still bring measurable or audible improvements compared to standard single wiring using only the Speaker A output with the bridges mounted on the speakers?
- In Passive Bi-Amping, with the speaker bridges removed and the xover network fed separately for HF and LF, is the amplifier susceptible to impedance mismatch due to the speaker components (HF: 3 ohms, MF: 4.4 ohms, LF: 10.8 ohms) not having the same impedance? Or do we consider the nominal impedance, which is 8 ohms?
