Beta Test: Multitone Loopback Analyzer software
Sokel
Felt very useful today so I measured Khadas's filters.
EDIT: to be fair,that's not Khadas's filtrers,it's Ian Canada's filters contained in his controller.Default (and only one Tone1 has without the controller) is Apodizing (the bottom one in timestamps).
pkane
pkane
North-East
You guys are doing such a great job of testing new versions! Let me run one more by you, see what you can find :). Assuming the new features work and I didn't break anything new, this will become the next official release:
https://app.box.com/s/qbrh3czrvudclkqs9n8lm806k3hzmjx5
Changes in this one (v1.0.40):
  • Added support for multi-channel input devices (WASAPI and ASIO) -- please test!
  • Cleaned up multi-channel support in output devices from previous version
  • Added cool-down setting for sweeps and repeated measurements
  • Fixed the waveform plot to scale both graphs correctly when mixing different sampling rates
  • Added settings panels to waveform and frequency response plots
Sokel
Wait for it!
Sokel
Nice round number, no? ;) Looks like ASIO sample conversion is broken. Strange, as I tested it with different ASIO drivers on my side.
Wasapi shared is also VERY weird.
pkane
pkane
North-East
Nope,but after I tested it wasapi shared works!
(ASIO still doesn't)
Yes, I see the issue with ASIO. I changed how sample conversion works to speed it up, but I see I broke it for anything but 32-bit floating point samples. I'll fix ASIO asap.
Sokel
Cool-down works nicely.wave form too.
Pff...nothing broken so far,later!
Grooved
Hi @pkane
just tested, but I don't know if it's the version from this post, or from you're following post and so an updated one.
So, with the same device than yesterday, and ASIO:
- I get it to work on inputs and outputs from CH 1 to 8, with just a strange thing: the warm-up (for 1, 2 or more seconds) is always like this, and the right signal appears just once it says recording
Measurements are OK though
- selecting CH 9 or more (I only had 14 this time instead of 22 because ADAT was disabled) gives this error:
