bennybbbx
after many tests i find the only perfect
solution on a asymetric room that sound really perfect on desktop and nearfield. Use a little reverb with LPF filter at 180 hz on the side that is near to wall. seem because you get from the side that have more distance to the wall the bass reflections much later as on right side it sound always as more bass reverb is on left side and give such a strange feeling as change polarity of woofers . cannot correct this with room damping or EQ. I use melda mconvolution on right channel with this settings so that reverb on bass sound on both sides simular , the mconvolution reverb have a lowpass filter inside. this i use. see screenshot . I use the builtin algorithmic reverb. for me higher frequencies as 180 hz need not reverb. it is only in the low bass range where need reverb on right side. i attach a for async room version and original drum loop. so everybody with a async right speaker near wall left far from wall can test himself if it get better or not.
