Best spec ADC Chip currently.... ??
MC_RME
In your AliExpress store there are three bundles available, without any further explanation :facepalm:
I guess bundle 1 is no bundle, bundle 2 includes the headhone load PCB. Bundle 3 greyed out.
So I ordered bundle 1. Will be interesting what I get additional to the ADC itself...
MC_RME
No, it is not. In all translated languages the first three lines above the pic are removed. I just changed to english to magically see them pop up. Seriously, the common workaround for AliExpress' limited choice selection is to use 'Color' for different models, not the even more misleading 'Bundle'. And one can easily add the description for the choices directly there as well...
MC_RME
That would be a useless task. Until one gets replies all ADCs are sold out already - QED :)
staticV3
On mobile at least, the bundles' explanation is right there.
Bamboszek
Oh, that's right. Just checked and it disappears in different languages. I really hate auto-translated version of Aliexpress, and too bad it keeps automatically changing from English.
staticV3
Like this?
I've asked Sunny if she can change it. Will update once I know more.
Rja4000
Liège, Belgium
Some measurements of my Grade A - "128dB"
Mono mode, 4.5V range
ASIO4ALL v2.15 Beta 2
ARTA 1.9.4.1 ("Mic" FR Compensation file to limit to 20Hz-20kHz)
Virtins Multi Instrument 3.9 (20Hz-20kHz)
On the left with MI, on the right with ARTA
Open loop
48kHz Sampling rate
FFT with Rectangle windowing, 32k FFT Window size
Above, A-weighted, below un-weighted
Noise is at
-127.7dBFS(A)
(both tools give the same value)
or
-125.6/-125.7dBFS (<0.1dB difference between the 2 tools)
192kHz sampling rate
128k FFT Window size
All the rest, same as above
Above Un-Weighted, below A-Weighted
Noise is at
-127.9dBFS(A)
or
-125.8/-125.9dBFS (<0.1dB difference between the 2 tools)
With a 150 Ohm load
(shared accross the 2 inputs), at 192kHz, for both tools
Noise is at
-127.7dBFS(A)
or
-125.6dBFS
Rja4000
Liège, Belgium
I'll re-try with your ADC.
With the RME ADI-2 Pro fs R, I never experienced a mismatch.
But that's with RME native driver.
What I see with ASIO4ALL are some strange behavior though, with both softwares:
At some point, it's limited to <90dB
At some other points, It's blocked at <118dB instead of >125dB (un-weighted)
Then I play a bit (restart the software, un-plug the ADC,...) and it all gets back to normal.
I think it's rather a problem with Windows, the windows driver and ASIO4ALL than with a specific software.
But I'll continue checking.
By the way, at what Range (max V) do you check the noise ?
And do you shortcut inputs ? or keep then open ?
staticV3
@Rja4000 have you experimented with the Cosmos Tweak program yet? Specifically the ADC_INT_SEL values.
In my case, those improved my SNR:
L: 123.4 -> 123.9
R: 124.5 -> 124.9
Mono: 126.9 -> 127.4
So a .5dB improvement across the board.
Rja4000
Liège, Belgium
I now have REW working at 384k FFT window size with FlexASIO :)
Multi Instrument runs at 384kHz as well.
I did play a bit with ADC_INT_SEL, but I didn't get any improvement.
What does it change ? And how did you improve ?
