boXem | audio, you are right, APU is an extension for really high-precision measurements of DACs. APUs notch has 10Vrms max input level, LNA max level = 10Vrms/100 if +40db gain or /1000 if +60db. So you can measure the noise level of power amps with LNA but for the full-scale power amp output you need some 1/3 resistors divider(I make such things inside of cables) before the notch. However, power amps usually aren't so low-noise and low-distortion devices as modern DACs. BTW, the notch has a 2-positions switchable post gain 0/6db. Cosmos ADC is the plain ADC/USB interface, that's it. We preparing the Cosmos FFT software as well, simple but correctly measuring Cosmos_FFT.exe. The SW will able to control THD compensation coefficients of ES9822 2nd, 3rd, and 5th harmonics, so you can compensate your own Cosmos ADC unit at 10kHz(optimal 1kHz THD compensation isn't matched to 10k) for the minimal distortions, using Cosmos DAC +LPF_10k as a reference sine tone. By that way you can see power amps harmonics of 10k signal, taken from the Cosmos DAC+LPF10k at level -135db, that's not too bad huh? Some thech guys asking me to make Cosmos ADC/DAC/APU in a single housing to make it synced etc but I think, I have much less risk to produce 1KU Cosmos ADC for 120-130 dollars and 1KU APU separately.
