HooStat
This has already been done. Search is your friend: https://www.audiosciencereview.com/...-would-also-be-offered-for-measurement.13437/
It’s now time to pull the trigger and buy the Genelecs that you already know that you want. You won’t be disappointed, but there is no benefit to delaying the inevitable.What would you say are the best speakers regardless of type (passive or active or active monitors) on the market for up to $10K?
Can you give some insight on why below Schroeder it does not matter? Will there be any difference in room mode between directivity control and control below Schroeder frequency? Thanks in advance.M2 will be constant directivity down to about 800 hz, Kii and Dutch until about 100 (below Schroeder it doesn't really matter anymore).
Because modal room/speaker/listener relationship dominates over speaker designCan you give some insight on why below Schroeder it does not matter? Will there be any difference in room mode between directivity control and control below Schroeder frequency? Thanks in advance.
The best descriptor of how we perceive sound in the room's resonating area is the frequency response of sound energy built up over some time (steady-state), and given that the speakers have stopped producing any sound (and therefore also the directivity control) before all the bouncing around of sound waves in the room to achieve that steady-state, it goes without saying that whether or not there's any directivity control won't matter much.Can you give some insight on why below Schroeder it does not matter? Will there be any difference in room mode between directivity control and control below Schroeder frequency? Thanks in advance.
From my understanding, it still does something, as the on-axis / omni volume ratio is still a lot greater for those frequencies, meaning less energy "dumped" into the room to achieve the same volume at listening position.The best descriptor of how we perceive sound in the room's resonating area is the frequency response of sound energy built up over some time (steady-state), and given that the speakers have stopped producing any sound (and therefore also the directivity control) before all the bouncing around of sound waves in the room to achieve that steady-state, it goes without saying that whether or not there's any directivity control won't matter much.
In typical small rooms this is usually the case, but in larger rooms it may not be an accurate statement. While I don't have it on my phone, I have measurements of Kii vs Phantom and M2 placed about the same place that shows Kii has no advantage over the others until around the Schroeder frequency in my room.
Room decides steady-state response below Schroeder, not speaker.
i think kef r3 + 2 x rel t7i + 1k-1.5khz amplifier + mini dsp + miniDSP UMIK-1 USB is all you needProblem is you need some super expensive amp for them.
How wide is your room? Nice setupSet aside $1k for treatments. Improved every aspect of my room and the experience. Mid-bass especially.
Thanks. 12.5' wide, with speakers 9' apart and to me.How wide is your room? Nice setup
