Bargain DAC Suggestions?
AsapH
@Jimster480 Unless I'm missing something the THD is lower than the Taishan and various other "adequate" DACs (e10k which I also own). I need something to connects my Samsung TV, with optical out only, to external amplified stereo speakers. The output of these TVs is almost always 48khz, on which the Taishan performs poorly.
I'm curious about what exactly wrong with the specs though.
Jimster480
Tampa Bay
The claimed specs are actually very similar to the E10K.
How do you know the Taishan performs so poorly at 48khz?
dpuopolo
I have confirmed that the Dayton DAC01 and the FX Audio FX-01 DACs are identical. Both have the SA 9023 USB tranceiver and the Burr Brown (TI) PCM 5102A DAC. They both also have 100 uf electrolytic capacitors in series with the outputs that I bypassed with a pair of .22 metal film caps. Improved the highs noticeably. One more thing - the two come up in Windows as different models. The Dayton comes up as a DAC01 and the FX as DAC012. This means you can run two of them simultaneously on the same computer (and I do).
captain paranoia
I'm going to reverse things here... I hope no-one minds.
I bought one of these RCA to optical/coax SPDIF ADCs, for a laugh (and £7.74 delivered):
https://www.ebay.co.uk/itm/Analog-R...-Digital-Optical-Coaxial-Toslink/253319988668
It uses a TI/BB PCM1802 ADC, and an unmarked device which may be a DIT4096 digital audio transmitter. I need to sniff around the circuit to confirm that, but it's the right number of pins, and the right function...
It works (as in it converts analogue to SPDIF that an SPDIF DAC will replay...), but it's fixed at 48kSa/s. I might play with adding select switches on the sample rate select inputs of the chip. At the moment, it's sitting in the pile of cheap Chinese audio toys...
alperu
This will be my first message in this site! Great site and great discussion, thanks Amir!
I suggest to review LG B&O Hifi plus AFD-1200, when it was released the price was around 100 USD now you can buy used ones for 20 USD and new ones for 40 USD from ebay
I use it with windows 10 (needs driver) and macOS you can connect with USB Type C. DAC chip ES9028C2M and ES9601c amp and yes DSD support!
tecnogadget
Madrid, Spain
Anyone in the US willing to loan Amirm for testing any of this 2 highly praised top performers, now a little bit old so the price has dropped considerably.
iBasso DX90, reference DAP for the time (circa 2014/2015) uses dual mono ES9018K2M chip, OPA1611, dual buffer BUF634, LINE OUT 1.761 Vrms @0.0011%
Yamaha RX-Z9 (USA) / Yamaha DSP Z9 (Europe)
, 2004 released, Top Of The Line (TOTL), “Uber” A/V multi-channel amplifier costing the whopping US $4,500-$5000....pretty much the very best amp made by Yamaha
Now selling between 500-1000$....
*Class-leading low-flux, 1,500 VA Toroidal Power Transformer.
*A pair of high-grade Nichicon 28,000uF/ 80 volts power capacitors.
*The absolute best quality Nichicon Fine Tune capacitors specifically designed for high-end audio are used in all circuit boards.
*Speaker relays with gold plated crossover connections and shielding.
*24-carat hard gold plated extruded, large 2-way speaker terminals.
*Use of super-expensive, ultra exotic, best at the time Burr-Brown DACs on all channels. PCM1792 DBR
xthechar
Another one I'm interested in as a direct competitor (albeit about 2x the price) to the Fiio D3 is the Hifime SPDIF (https://hifimediy.com/SPDIF-9018-DAC). It has pretty much the same feature set but hopefully will work better for 48khz and other frequencies. I'm personally interested in a 32khz solution for pairing with an old gaming console that has this frequency as its native signal. Amir is there any chance to see the Fiio D3 chart for 32khz?
I would also be curious to see how a $5 D3 clone fares too: https://www.aliexpress.com/item/Dig...nal-to-RCA-R-L-Audio-Decoder/32835764071.html.
I am a longtime lurker, thanks for your amazing work Amir!
edit corrected typo Fiil -> Fiio
Ron Texas
To go back to the original question, several sub $300 dac's have been tested here with excellent performance. Topping, D10, D30, D50, Khardas and the SMSL SU-8 to name a few. Sorry if I left your favorite off the list.
xthechar
Yes I mean that one, sorry for the confusion. I'd like to see a graph for 32khz sampling, whatever tone you think would be most indicative. Just want to get a sense if the problems at 48khz are present at 32khz as well.
There is a new version of that Fiio D3 as well, not sure how different it is: https://www.amazon.com/FiiO-Essential-Digital-Analog-Converter/dp/B07L61JPQW
Veri
Supports all popular sample rates including 32kHz
I believe it will be just fine for an older game console :)
bigx5murf
Yamaha RX-Z9 (USA) / Yamaha DSP Z9 (Europe), 2004 released, Top Of The Line (TOTL), “Uber” A/V multi-channel amplifier costing the whopping US $4,500-$5000....pretty much the very best amp made by Yamaha
Unlikely, those units are too expensive to ship 2 ways, so unless someone local offers to loan one, don't expect to see it measured. I have a number of TOTL AVR from that era, including the RX-z7. That really was the golden age of AVR, in terms of build quality they blow away the new units today.
headwhacker
This board is really lacking measurements for DAPs. If I only live in US, I could have sent my collection. I have a few (AK240SS, AK120II, QP1R, QP2R, iBasso DX200Ti, Lotoo Paw Gold etc.) which I am curious to see measurements done by Amir.
So far I see measurements done in Stereophile for AK240 and QP1R which matches or very near what the manufacture's claim. The rest I can't find reliable measurements and mostly just subjective impressions which ime are pretty much useless.
xthechar
I'm quite curious about the Hifime DACs since they are quite compact and affordable. If I decide I need the SPDIF one, I would definitely send it to Amir first if he'd be willing to test it. Don't hold your breath though! I found a cheap $15 D3 clone at an electronics store here and it's doing fine for my modest use case...
tecnogadget
Madrid, Spain
Yes Z7, Z9, Z11 were total beasts TOTL UBER Avr's. Being the Z9 the one that sports a massive toroid transformer (newer Z11 downgraded to standard E-Core but:rolleyes: included HDMI) and the only AVR Yamaha included in their own hall of fame timeline of products (120 years).
It would be nice to measure devaluated TOTL AVR's to verify if they can make a run for the money vs same or x2 price separates. I understand that most forum advises going separates and entry/mid-level AVR's are no competition. But they never consider this category of AVR that once were 5k/10k and now available for 1k/2k (still way cheaper than "good" separates).
I think we are all together in the pursuit of debunking the high-end snake oil market and finding pure engineered products ;).
slazyel
Guys,
Mainly for desktop use, like 90% of the time, would you recomend money wise: Smsl idea for $62, Sabaj DA3 for $82 or NX4 DSD for $122?
This is really driving me crazy. I will pair it with a Shp9500 and a takstar pro 82, both 32ohm.
So, money wise, would be better to go idea, a little more for sabaj or the double for nx4 dsd?
@amirm , maybe you know? I see you have tested all 3, so money wise wich one do you think is a better bargain?
Guys,
If size is not an issue, my choice would be NX4 DSD.
