Audyssey One - Nexus (Automated hi-res Denon/Marantz calibration with REW/Umik-1/2)
Hi Serko! Thank you for your great work. I was previously running a version of Evo, and recently made my first attempt with Nexus on 1.8. Currently running version 2.4.
I did get some strange SW distances from Nexus 2.4, more precisely 5.37m if I leave all checkmarks unticked which sets Front speakers as Large and therefore LFE+Main, and 6.09 meters if I check "Force small front speakers" option. Subwoofer is physically placed 2.35 meters from MLP.
After reading this comment, I do wonder if this could be related to the sweep I've used for measurement, as I was able to play the LFE atmos mkv sweep through VLC on a Mac connected to the AVR via HDMI, using Denon X3800h (encoded) – which I believe is passthrough – as the audio device output.
Do you believe I should remeasure using REW's sweeps? I don't actually need atmos sweeps as my system is 5.1.
Thank you!
No, sub distances are supposed to be longer than actual physical distance due to delays from filters in their circuits. There's v2.5 now and if you have dolby enabled speakers in the system, you should use that one. I suggest you listen to your system with the default options first before using any options.
Got it! Thank you.
Currently got both uploaded to the AVR so will spend some time listening to them, on both music and movies.
Attached some after cal measurements
Nexus 2.4 unticked (1_LFE+Main.jpg)
Nexus 2.4 Force Small (2_Small.jpg) – Calculated crossover at 80hz
EDIT: Not sure if this is the right way to measure the results, but I did so with the same volume set on the AVR I had when making the pre calibration measurements.
Reactions: OCA
New amps arrived and I first did the stock Audyssey MultEQ App calibration. Results are FAR better compared to stock measurements on the old 26dB gain + 19dB gain amp setup. Now both are 31dB gain and it seems Audyssey really is made for this gain range. The bass and MultEQ are on par with the adaptive loudness module of E-APO. In the next days I will try Nexus again, but I am pretty sure the results will be great.
One question: Instead of the Atmos sweep, can't I just use the REW sweeps at 48 Khz and 0 to 24000 Hz range? I am asking because making many sweeps is a manual process with the provided dolby sweep and with REW I could just set my speaker to, let's say, 64 measurements, walk away, and come back to the job done. Wouldn't that be the same measurement data?
Yes, you can, if you don't use more than a total of 8 speakers that can be "seen" by REW (for example, via HDMI).
My setup, for example, LCR + surrounds + tops + sub channel = 8 channels, all addressable by REW. Anything more than that, though, requires using the provided sweeps and a compatible OS / player.
@OCA
Hi again Serko. Couple of questions I'd like your advice on best procedures:
1. I have significant master volume variations when listening to music (mostly streamed, via Spotify/Tidal connect) and movies (source is android tv box).
Usually AVR is set between -40db to -35db for music, and between -24db to -19db for films. I've measured speaker responses at -19db. Is that the best practice or should I change it? Or Should I try making measurements at different volumes for Music and Films (sub only has a physical gain knob for volume, so probably would need to compromise one or another, or both)?
2. I've been getting inconsistent results regarding SW polarity across different versions of nexus. Version 1.8 asked to switch polarity, 2.4 to keep it as is, and 2.7 to switch again. Any reason for that?
Thank you!
EDIT: Dynamic EQ is on for both measurements and playback.
Alright, I did a little more testing.
It all falls apart when I disable my E-APO Loudness Correction. But NOT because of Nexus, but because of the limitations of Audyssey.
When I rely solely on Denon Dynamic EQ, even already paired with the 10dB Harman Bass Boost - it's as if there is no bass.
I tried exporting different calibrations, even setting different volume offsets when Nexus asks for them before optimization but it's all the same.
Nexus can't fix the very stiff and unflexible Dynamic EQ.
Dynamic EQ will be disabled or at least unnoticable past -10dB Denon Volume Level. This is why I am pretty certain that the issue lies in:
a) Nexus lowers the volume significantly for the optimizations to work
b) my amp is set to 19dB and I am 90 % sure Audyssey expects an amp with about 30dB gain (denon has 32dB, I think)
These two factors mostly cause a bypass for Dynamic EQ, which is essential for having that warm, bass rich sound even at normal listening levels.
To be clear, not even the stock Audyssey Dynamic EQ works with a regular calibration. So I guess the crucial part is the gain.
I think this is pretty important since most never amps only achieve their +100dB Sinad performance with gain in the range 10-20dB, which already troubles Audyssey a lot.
BUT one very important disclaimer. WHEN you use tools like E-APO loudness correction instead of Dynamic EQ, even when you have a troublesome setup (weak gain), Nexus is GOAT. But it limits you to PC-only. When using consoles (PS5, XBOX) and maybe a streamer, the above mentioned problems arise.
Edit: I will try one more thing and see if this works. It will make a custom "flat" house curve (Nexus enforces a EQ curve even if you just want it flat, not sure why) and see if it avoid lowering the volume and see if MultEQ works then.
Edit 2: Nope, no improvement. But it shows that applying a EQ Curve seems to make no real difference in case it.
Edit 3: Fork it, I am ordering a second NCX500 stereo amp from Audiophonics and setting both amps to 29dB gain.
Denon and Marantz AVR's - Power amplifier channels
29dB gain
1V in, 100W out into 8 ohms.
A fair number of people here eschew AVRs. Not to mention DSP.
Old school audiophile prejudice at work. Gotta have separates! Or even separate monoblocks! And no goldarned DSP to mess with my precious (2 channel!) signal chain!
(Or : gotta have my TOOOBS, man)
That said, the author of EVO has been a bit salty here on ASR.
I have many separates, run an amp per passive sub (and have been running subs since the late 1970's, one way or another), have frequently used EQ (sometimes analog parametric with a separate analog bass/sub-parametric) in processor loop before it leaves the pre-amp, X-over the frequencies before they get to the amps.
And I want stand alone DSP.
I've had quad & 5.1, one of which I abandoned when it became difficult to find source material and 5.1 (that I had doing 5.2), I ran for about 10 years and abandoned before 2000.
I no longer have space for multi-channel, so until (if ever, but I am hopeful that I will in a few years) I move to a larger place (similar to what I had before, much larger), I'll likely stick with 2 channel & a pair of downward firing (ported) 12"subs (built by me with an FR of 20 Hz to 80 Hz [yes, they are NOT small and take up a bit of space]).
If anything, I'd like to have 1 or 2 more subs.
And in recent times, they have come up with some DSPs that are suitable & it is said: relatively easy to implement in 2 channel with a pair (or perhaps more [hopefully more]) subs. When, (if) I do get a bigger place, I will be looking for (not an AVR) but that rare breed, a multi-channel processor. Yes, I know and understand why they are more expensive than an AVR but that is what I want, NOT an AVR.
I intend to personally have some of this (2 channel & subs DSP) in my system at some point to try next year.
It has always been that I march to my own drummer inside my head and it will always be so.
Tubes, never had them, never will! Perhaps (for me) more than their sound quality issues, (to me) they are just a pain in the butt to mess with.
But, to each their own
Some folks like continually messing with things. I like to get it "close enough", enjoy it and use my time to listen to my system (and/or) do other things.
I very rarely am not moving around doing something (why I haven't had cable or a TV since 2007). But I have an oPPo 205 UDP and a 32" monitor so that I can watch 30 or so minutes at a time of a DVD/Blu Ray or 4K disk (I can't sit still much longer than that) until I finish what I am playin).
Most times, it's a live concert and even being not in the room with it is not an issue (volume up, I can hear it in the yard or just use my (bought in 2010) Sennheiser TRS180 headphones (which have a 100 meter range [because they are on a robust set of Carrier frequencies from 2.4 – 2.48 GHz {good for when I am mowing the lawn})].
Okay, I tried it again with the new amp setup (2x NCX500 Stereoblocks) in my usual 4.2 surround setup.
First of all: Yes, the "weak" Dynamic EQ problem was really caused by prior low gain amps. With two 32dB gain amp Audyssey Dynamic EQ now applies noticable bass boost depending on volume but also still works at higher volumes, which is good.
With Nexus 2.7 I did 16 sweeps per speaker, correlated and vector aligned them. Then I launched Nexus and let it do its thing on all default settings. The results are there, there is no denying it. But even with the Harman10dB target curve and Dynamic EQ on 0dB the bass still feels weaker compared to Audyssey. This is measured with ASIO and the AVR on -25dB volume.
I am not sure why the bass is unsatisfying with Nexus but I thing it's the dip around 100 Hz, making everything lack punch. I will attach the log file so you guys can see maybe I did something wrong.
Edit: OHHH I set the LFE to 250 Hz instead of 150 Hz like instructed in the guide (since it was always 250 Hz before). I will try that now. I made sure to flip the polarity tho.
Edit 2: The above fix had no effect whatsever, but I noticed my latest calibration set all speakers to 2,90m distance, which is probably and error. I removed the measurements images to avoid confusion.
Log: https://pastebin.com/J9aVVByG
There's no way all speakers end up having the same distance. It'll sound pretty bad. There's a known bug with some AVRs not setting distances after the ady transfer and need a power cycle. Could be that.
I forgot the timing reference in REW o_O:facepalm::facepalm:. I used the built in sweep for more comfort during the measurements but I had "no timing reference" the whole time. Ugh. Gonna redo everything, sorry for the confusion.
Get ready for a pleasant surprise then. Without acoustic timing reference Nexus is just as good as random PEQ
Audyssey stock:
Nexus V2
The timing reference here seemed to work now since all speakers got reasonable distanced and levels but I am still not sure what Nexus is trying to do here. Both subs were set to 6.53m both and one was said to need polarity flip (blue control measurement). The orange one is the same but I flipped the sub back to 0°.
If you want to analyze this maybe I can provide you the Post-Nexus-REW mdat file or the logs.
Sub vs fronts is optimized for FL & FR together. You probably have asymmetry there. Also same distance for both subs with one polarity inverted during multiple sub optimization seems like a "required delay over limits" problem (or a measurement error). You need to turn off whatever processing is being done in the subs if any. They might be delayed too much or you may be not be measuring them properly with one turned off at each sweep. It's also imperative to use the REW measurement mode ady file and set sub mode to LFE to get the full sweep response or else measurement will be capped with a 120Hz lpf.
Sorry to bother you again, but I still want to get this working, now since I have the new amp that enables the use of Dynamic EQ even more so.
My process was:
- Upload .ady example file
- Download .ady measurement file with DynEQ
(note that for this I always kept using the same both files since my setup did not change, please tell if this is wrong)
- Set Sub to LFE only and 250 Hz so the "Large" speakers and subwoofers don't play sweeps at the same time
- Ensure suitable volume on AVR and gain on mic preamp so SNR and THD are in safe ranges, keep REW at -12dB and use FlexASIO at 48 Khz
- Measure stock REW sweep with acoustic time reference on FL, sweep range 0 to 24 Khz using 64k size and 16 sweeps
- Delete the first measurement of each speaker to avoid stuff like "auto mute" or me introducing noise while walking away from room during measurement
- Cross correlate and vector align all speakers into their final target curve and take Harman8dB as target curve
- Enable API in REW and hand it over to Nexus in default settings, clicking YES on the DynEQ question and inputting -25 Volume (which was my measurement level)
- Adjust the polarity and avr settings as told and upload the file via MultEQ to the receiver
I doubt that the sub processing is the cause since during my very first measurements everything was fine too.
But my hunches:
Wrong setting of acoustic timing reference (not only FL)?
64k size too low for Nexus to work with?
When Nexus tells me the measurement level was too loud I just add and SPL offset of -10dB to SW1 and SW2. Could this be wrong since "LFE -10dB" during measurement behaves differently? But it's just a level thing, not delay or phase, right? When using "LFE -10dB", the measurement SNR gets unneccesarly worse in my opinion.
My process was:
But my hunches:
No problems I'm here to help. Most your steps are correct, measurements should be 256k long though (64k could cause issues with some calculations and they have lower snr tatio), subs should be measured by lfe-10 sweeps and if that gets a too loud warning from Nexus then they should be dimmed down physically. PS you can choose delayed sweep start function since you're using REW'S own sweeps, you will not have to delete first measurememts.
@OCA
Hi! Here to ask for some advice again. I'm remeasuring my system, starting from scratch. On the very fist measurements to fine tune microphone position between LR speakers, I've noticed what seems to be different polarity on L and R. I did check and recheck the wiring and all seems to be good (though I never exclude human error).
I'm attaching some screenshots of the impulse overlays of the sweeps (also mdat), red is Left, green is Right. Timing reference is set for Left speaker. Can you, or anyone help me understand what's going on, and how can I fix it? Thank you!
  • FR_impulse.mdat.zip
    FR_impulse.mdat.zip
@OCA
I think the impulse sound/graph isn't suitable for checking polarity since it's usually high frequency stuff where polarity doesn't matter really. If you want to check polarity, look at the phase behaviour in the bass range.
I believe OCA mentions in the Centering Mic section of the tutorial video that if each speaker is reaching the 100 mark on different (positive/negative) parts of the chart, they have different polarity. I've anyway done the battery test on both, and both turned out correctly, so shouldn't be a problem. Thank you.
Impulse peak directions can be deceiving although rarer with front mains but still possible if one speaker is much closer to a wall surface than the other. A better way is to compare their phase responses in Overlays, preferably 1/1 smoothed and invert one of the fronts phase with REW (it's in most right click menus) and check which polarity matches the other better.
Speakers (front ported) are roughly the same distance from backwall, though yes, FR is 60cm from side wall, while FL has a piece of furniture around 40cm from it. Anyway, I was wondering if this was the reason why I was getting inconsistent sub polarity settings through different version of Nexus, and now, on 2.9, it's again suggesting to keep polarity as is. Thank you again for your time and constant support of Nexus and its users!
