Denon X3700 and two subs.Can I ask what AVR you are using and how many subs?
[A1 Evo] Should give it a try then.
Can confirm, there really is some weird case of headroom.Went through this hard-to-stand video (youtu.be/lmZ5yV1-wMI?feature=shared) and somehow ended up with two new .ady-files,
multeq1_20241020_1256_A1EvoMaestroMJmaster.ady
multeq1_20241020_1256_A1EvoMaestroMJdEQ0dB.ady
Loaded them up to my AVR, and the result in both cases is that the volume is even lower than with the Audyssey MultEQ Editor app calibration![]()
Timmy, what do you do for a living?That way, the whole thing is really just a frustrating waste of time.
I re-did my first run, but now I ticked the »Force small fronts« check-box. Guess what the result of that is ... Even lower volume than the low-volume result this afternoon ...![]()
Actually A1 Kenobi was considered as a name for Nexus in a forum far away
Does this tool take into account distortion?
If you meant me, I am only talking about Nexus since I didn't try Maestro yet and this thread is about Nexus only (I think?).Again, is this Nexus or Maestro? In Nexus you can adjust your measurement level (AV volume), mic gain, sound card volume among others to remove distortion from your measurements unless of course there's something wrong with the speaker. Is the distortion linear or non-linear? What was the headroom REW showed during their measurements? Was it not in the green? If you are talking about resonances during measurement that's normal with tiny speakers with sweeps, doesn't mean it will be carried to the calibration after they're crossed over with the sub. I have one of the most expensive ceiling speakers from Focal and they resonate like crazy during the lower bass frequencies of the log sweep during measurement.
Evo doesn't calculate full range option if the front mains steady state 12dB/octave roll off is above 40Hz. Nexus will do that for all speakers below 60Hz (I increased that in Nexus because people even with smaller front speakers demanded this mode). So, LFE + Main mode is only for front mains and only if they are proper 3-way floor standers. And it's like adding two more subs in your room when done right.If you meant me, I am only talking about Nexus since I didn't try Maestro yet and this thread is about Nexus only (I think?).
I don't mean the whole distortion spectrum, just the bass range where, for example, a front speaker could play down to 20 Hz but only by giving it bass boost and thus raising the distortion. But now you also have subwoofers who can handle the 120 Hz-20 Hz range with far less distortion. Nexus might prioritize dip fixing and crossover alignment instead of phasing out the distortion of the front speaker, maybe setting it to 40 Hz crossover. That's what it meant.
But as I was writing this it came to me that crossover- and dip-fix optimization might also imply you also minimize distortion anyway...
But as I already mentioned multiple times - I will retry Nexus once the second NCX500 amp is here. With my prior setup Audyssey and Nexus applied these levels:
Front: -9dB
Surrounds: +9dB
Subs: -12dB (even alerting me that it's still too loud even though in REW the sub was significantly below the fronts)
Maybe there is a tip on how to level match your subwoofers before measurement?
I will report back when my amp arrives during this week. Also, thank you for taking your time to make such a tool!
Oh wow, I never thought of it this way. Why just use one low end provider when you can use all of them? It now clicked! Will try that soon with the new amps.Evo doesn't calculate full range option if the front mains steady state 12dB/octave roll off is above 40Hz. Nexus will do that for all speakers below 60Hz (I increased that in Nexus because people even with smaller front speakers demanded this mode). So, LFE + Main mode is only for front mains and only if they are proper 3-way floor standers. And it's like adding two more subs in your room when done right.
The applied levels show some sort of amp gain mismatch but nothing to worry about, as long as you don't get 12dB limit exceeded warning, the correction stays optimal.
WIth Nexus lossless Atmos sweeps, there's still confusion actually about which LFE sweep to use for the sub (that's why there are two SW sweeps with 10dB difference) because some amps seem to apply 10dB boost to LFE sweeps and some just don't if they are full range. I would use SWx.mlp sweep in the video download folder unless you see a reason not to with the level shown in REW during measurement. You can't go wrong twice though as you will hear a 10dB misalignment quite easily.
PS Sub sweeps will always give this warning when they are full range (0-24000Hz) as they don't produce much beyond 200-250Hz and REW detects higher room noise than the sub's output from 250Hz to 24kHz and pops that warning. You can ignore it. Actually, if you don't get it, you are probably measuring your sub too loud. Btw, don't ignore it if it pops after a speaker measurement.
Hi Serko! Thank you for your great work. I was previously running a version of Evo, and recently made my first attempt with Nexus on 1.8. Currently running version 2.4.0dbFS was found too loud by many so I made new ones with -12dBFS which is also REW default and since Mac owners have to use REW's internal sweeps for subwoofer (Macs can't play lossless Atmos sweeps and lossy LFE sweep has a 120Hz internal lpf), it seemed more convenient that way. It doesn't matter whether you turn the AVR volume by 12dB or replace -12dBFS sweep with 0dBFS ones or change external amp gain by 12dB. As long as you measure with REW not warning for negative headroom (turns red) and your speakers don't sound like they are way over their limit, you are fine. It's good practice to use "capture noise floor". High room noise is not a problem so long as REW captures it. These log sweeps are very powerful in eliminating noise from the signal. If REW did not give you a low signal to noise ratio warning, the measurement is good enough for calibration purposes. The importance of AV volume level is to be in line with your preferred target curve and equal loudness. In general the louder the measurement volume, the higher the signal to noise ratio but you have to keep within the efficient limits of your speakers drivers. Measured frequency responses should be more or less identical with just an SPL offset when you increase the volume. If the FR shape starts deviating, that's the volume level you should avoid measuring for that speaker because it means one of its drivers started to give up.
