Audyssey One - Nexus (Automated hi-res Denon/Marantz calibration with REW/Umik-1/2)
New amps arrived and I first did the stock Audyssey MultEQ App calibration. Results are FAR better compared to stock measurements on the old 26dB gain + 19dB gain amp setup. Now both are 31dB gain and it seems Audyssey really is made for this gain range. The bass and MultEQ are on par with the adaptive loudness module of E-APO. In the next days I will try Nexus again, but I am pretty sure the results will be great.
One question: Instead of the Atmos sweep, can't I just use the REW sweeps at 48 Khz and 0 to 24000 Hz range? I am asking because making many sweeps is a manual process with the provided dolby sweep and with REW I could just set my speaker to, let's say, 64 measurements, walk away, and come back to the job done. Wouldn't that be the same measurement data?
Why would the amp gain matter whether it is 29 dB or 32 dB? Once level matched between channels, it should be fine too if different ext. amps are used.
Dynamic EQ Offset. It expectes a certain reference gain. Meaning, when you have a amp with 10 dB gain you'd have to ramp up the volume on the AVR so much that Audyssey thinks "Man, this guy is listening so loudly, he'll probably way past the point of needing loudness correction".
Dynamic EQ Offset. It expectes a certain reference gain. Meaning, when you have a amp with 10 dB gain you'd have to ramp up the volume on the AVR so much that Audyssey things "Man, this guy is listening so loudly, he'll probably way past the point of needing loudness correction".
Thanks, I didn't notice you were talking about DEQ.
By the way, the trim level settings will also affect DEQ and DV, though a couple dB may not make a noticeable difference but it may, depending on...
Same thing for eco auto.
Nexus final version (3.0) was released a week ago and it seems stable and bug-free now.
It is not the gain alone, but gain + speakers efficiency. Even without external amps, speakers efficiency varies very much, so Audyssey have to compensate for gain. And I haven't heard about DEQ problems because of speakers.
Maybe your problem is not related to amp gain?
Correct, in essence.
  1. The original version (A1 / Evo) used the Audyssey setup process (which EVERYONE with a Denon / Marantz receiver has access to) to run the sweeps and create the .ADY file, which is then processed using the script + REW to calculate levels / distances / crossovers / EQ, which are then stored in the .ADY file and uploaded to the receiver using the iOS MultEQ app.
  2. The latest version (Nexus) follows the same process but uses external (read: longer, more accurate) sweeps and REW + a calibrated mic to create the measurements. Once the measurements are created, the process is basically the same; i.e., the script drives REW via API to do the calculations, creates the .ADY file, which is uploaded to the receiver using MultEQ again.
A1 / Evo is virtually fool-proof to anyone with a minimal knowledge of how to upload / download files, while Nexus requires a bit of additional knowledge / fiddling but the results are a bit better because you're starting with more accurate measurements. OCA has also added some updated logic to the script which he plans to retrofit to EVO after the dust settles from Nexus.
So I should start with A1 EVO to get the hang of it, instead of jumping straight into A1 NEXUS?
How user friendly is all this? And am I correct in my understanding that either version has the added benefit of keeping Audyssey Dynamic EQ/Volume functioning as intended (albeit with better measurements) but with the 6 dB surrounds boost removed?
It depends. If you have a measurement mic like Umik, you should start directly with Nexus. If you don't have one, and use Audyssey's mic that comes with the AVR, you can either do Nexus or A1 Evo Maestro.
I haven't tried Evo Maestro, only previous versions and now Nexus. If you know the basics on how to make measurements with REW, Nexus is quite straightforward, and way easier than what the video makes it seem, specially after you go through it once.
Previous versions required a lot of steps in REW, but Nexus really makes it a one click job, after you've made your measurements, and named them correctly.
Regarding Dynamic EQ, if I understood correctly how the correction system is working, it already compensates for it, and there's an accompanying script to make even further adjustments. I'm currently running it with Dynamic EQ but without the script, and so far so good.
There's only so much level gain 12db available? So if the amp needs more, will have to use the volume control to compensate, and that will affect dynamic EQ level. Now I wish the DynamicEQ reference level setting can go negative dbs :)
Is there a reason that my Speaker Distances would all show 9.1 Feet instead of being zero after uploading and installing the REW Dynamic EQ ady file?
place the mic close to the speaker to speaker see if it does better freq and see if it senses being nearer to the speaker ?
I believe this is actually the default OCA put in the script just as a starting point. There is a reason behind it I don't recall, but he commented on it on the AVSForum thread and confirmed it is irrelevant to the final outcome.
Audyssey One Neuron is coming soon before Christmas. It should bring free Trinnov-level calibration results to D&M AVRs.
A1 Neuron is out now in a preview mode (No DEQ optimization nor automated REW measurements available yet). Some users report very high XO settings for bass-capable floor-standing speakers and some false positive inverted polarity warnings, but most seem to notice an improvement in SQ.
The script can now send the filter to the AVR autonomously. There is no need for the app unless used for taking measurements (not recommended; better use REW with Umik).
Do these work with all versions of audyssey? If so, seems like the budget denons (s760h etc.) got a big upgrade.
Now if there would be a good AV Preamp for also Hifipurpose or as an alternative, an adaption for minidsps. I'm just dreaming.
Might want to check the AVS Forum post. It's explicitly stated that MultEQ and MultEQ XT cannot do LFE+Main mode due to limited sub taps. Comparison of MultEQ versions which shows both are significantly more limited in filters. I suspect based on that information MultEQ is much more strongly constrained in EQ'ing the mains / satellites.
I'm more curious how much the A1 series relies on Audyssey architecture or if it can be generalized to other computationally compatible DSP platforms in the future (e.g. programmable reference boards, MiniDSP hardware). FreeDSP failed as a F/OSS project because the board partners trying to recreate the RPi grift failed to have a usable software front-end in Sigma Studio the way Linux/GNU was for RPi.
Tested it on a 2.1 setup with my Marantz Cinema 70s. It sounds indeed much better than the default Audessy measurements. Pretty happy with the result.
I am just trying to understand the logs, which state that the crossover between Subwoofer and Fronts is at 120 Hz, which seems a bit high. The Speaker can play down to 40 Hz (Elac Vela BS 403), which is also visible in the logs.
I am attaching the log, maybe someone can explain the table to me to understand why it chooses 120 Hz.
