I have a Marantz 8802A with Audyssey MutltEQ X32. I've done the calibration and it has 'fixed' the output from my speakers. IE, the dB graph correction brings a nice flat curve from 60 Hz to 20 kHz on a speaker that has a pretty big roll off above 2k (Zu Essence).
Here's the question - do I need a 'good' speaker with a relatively flat output across the frequency response - or can I own a 'bad' speaker and let Audyssey correct it?
IE, if I take the measurements from Stereophile for the Essence, and overlay the Audyssey correction graph - it generates a pretty straight line - I'll figure out how to post pics to show this. The speakers sound good after correction. IE, can I use Audyssey to 'correct the room' but also 'correct the speaker' by amplifying the low dB output of the higher frequencies?
I'm sure the answer is no, you can't rely on correction software - but why?
thanks
thanks
