WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Hi, I'm looking for a good USB audio interface with at least 4 balanced analog outputs, a really good dac, stable drivers and reliable under 600€. Thanks!
Motu M4. Very good performer with four balanced output (TRS) for around $250. Motu M5 Ultralite is an even better performer with 10 balanced outputs for a little over $650.
Focusrite drivers are rock solid. I have been using it for ages with Ableton Live Suite.
But Motu is good too.
Look for Julian Krause on YouTube. He does the best, most objective audio interface reviews next to this site.
Julian Krause (YouTube) might have measured comparisons, but I am not sure, even if it’s 4i4 etc. 2nd vs 3rd Gen.
As far as I remember the 3rd Gen have cleaner preamps, which is less noise when recording, but please check as I am quoting from memory.
The Clarett 2pre also has 4 line outputs that are balanced TRS. It is well within your budget. The Clarett line are a good improvement over the Scarlett line. The Scarlett would be fine, but the Clarett has better specs and is USB-C. It is limited to two analog inputs, though it has an optical input. Make sure you get the USB C version as it can accept both ADAT and SPDIF optical. The Thunderbolt version only accepts ADAT optical. Amazon currently has it on sale for $379 in the USA as it is normally $499.
I might spring for the Motu 5 Ultralite as it has more analog inputs and outputs. Either should do the job for you.
