Try them side by side there is no comparison.A major reason I go the 19s was his review and statement they were the best speakers he'd heard to date in his system. As mentioned, I'd get the ATC SCM40 A happily if not already invested in gear, and may yet still. Having said that, as I mentioned, heard mixed opinions of the 40 passives, not heard a negative for the 19s, and some do view the 19s the sweet spot for the $. Never heard anything but raves for the 40 actives.
The direct in is bypassing a number of circuits it should be cleaner. My old Technics is terrible without direct in.I did not, have no preamp to hook up to it and it didn't cross my mind either.
Switching between the Yamahas power amp and the NC252MP, it became pretty clear that there was a little bit of audible noise when listened to at the tweeter and at full volume of the preamp. The source clearly was the Yamahas power amp section.
That also means that the noise from the Yamaha preamp section is lower than that of the Yamaha power amp, and possibly that of the NC252MP power amp.
But again, gave the NC252MP back, if you can't hear it with music, whats the point.
In my (simple) test above, the NC252MP showed lower noise than the Yamaha A-S1200 power amp, which some would consider a good class A/B.
I think it has high frequency noise that is so low that it doesn't matter to anyone listening with it to music.
Nothing audible from LP ofcourse but if you plan to tri amp the 252 is a waste of money just for tweeters.It is inaudible on the mid though with the ear right at the driver.
