That is not a reason not to tryCheap and SOTA is tricky.
For the streamer, Moode has just been updated to version 7.10 which includes the CamillaDSP fully embedded.
https://moodeaudio.org
This should pretty much tick most of the software boxes and is compatible with a lot of different hardware.
I found this info about it.has anyone used Moode with CamillaDSP?, not sure how to use it!
Adding third party proprietary binaries like Roon Server to a Linux system is bad practice.
Maintaining a Linux Distribution (which this project would be) that includes closed source binaries would be nightmare for the maintainers as it would be impossible to fix the bugs of such programs.
Stand-alone.Can Moode 7.10 run standalone on an RPi like Volumio, or does it need a server?
Stand-alone.
Simple to try as you can just download the image from the website and copy it to an SD card.
Same as volumio and others - once it can be seen on your network you can use a webpage to control it direct and it also appears as a destination target for airplay/Spotify etc if you want to stream to it from another device.
Probably not significantly different - most of them have a very similar underlying base. PiCorePlayer is an outlier and probably much more robust as the core OS runs from RAM once booted, and only writes to the filesystem when you change configuration. It's probably a bit more vulnerable if you're running LMS on it.Well, I'm done with HifiBerryOS. It's now already the third time I had to reinstall it due to corruption after powerloss. These OS'es should really be resilient to these things.
Flashing Moode now.. hopefully, that will be more reliable..
Volumio, Moode and Rune have a common heritage and are all forks of the same original project so there are many similarities. Moode seems to be the most stable and best supported.So, like Volumio, it doesn’t have to be configured via Linux commands?
Try http://moodeaudio.org/forum/index.phpDo you have a good (simple) instruction link?
That's a half truth that ignores the distros like Raspberry Pi OS that include binary packages for proprietary redistributable software, either directly or via separate repositories. Certainly it has its difficulties and limitations, but so does maintaining an open source implementation of a reverse engineered protocol that could change at any moment.Adding third party proprietary binaries like Roon Server to a Linux system is bad practice. There are obvious security concerns and also installing such packages will quickly lead to dependency hell with the package manager of the Linux Distribution used. That's why all major Linux Distributions like Debian and Fedora recommend that the users don't install programs outside of the package manager and will not provide support on the forums for such programs.
https://www.diyaudio.com/forums/pc-...iir-fir-engine-crossovers-correction-etc.html
That's for the 7.0 version - the 7.1.0 release has more in the web gui covered in the followup post.This could be useful as well
Thanks, the mind map is really useful, like so many of your other suggestions.'Prototype' being the operative word I think - optional variations have already been mentioned, so building it into the speaker may not be out of the question. The FA122 is the width of a CD, so building them into a stand is another option. From a value point of view you're getting known good amps plus DSP for crossovers with analog and digital inputs for less than the cost of some of the DACs people are proposing. Add a Pi with a digital output hat and your choice of OS with room correction and we're more or less done. I keep hoping someone will point out a decent, low cost, multichannel (6+) DAC that I've missed, since I've already got more than enough amps, but I'm still waiting. Maybe this will have an easy way to expand the channel count, and avoid some of the noises people still complain about with the BeoCreate.
