most ess implementations will be. any board that uses a single crystal and accepts 44.1 and 48khz will be async. usually they will be 50MHz or 100Mhz etc. vs dual 22.xx/24.xxMHz or 45.xx/49.xxMHz
I have a few of these for I2S testing, as @Skeptischism mentioned they have a single 50 MHz clock and run async. They are super cheap and work OK. The input header is really sad though (only one ground pin, not even a separate one for power). Although they have a MCLK pin it is not required as an input because it runs async. It also looks like they are out of stock although I bet you could find something very similar on ali express.
https://www.audiophonics.fr/en/dac-...-v21-i2s-to-analogue-24bit-192khz-p-8396.html
The DAC linked below is very similar to the one above but a bit more expensive and can act as a RPi HAT.
https://www.audiophonics.fr/en/dac-...c-es9023-raspberry-pi-a-b-20-i2s-p-11215.html
Audiophonics also still has the old miniDSP miniDAC8 in stock which has been discontinued by miniDSP. This would give you an 8 channel I2S DAC.
https://www.audiophonics.fr/en/dsp-...8-channel-24bit-192khz-akm-ak4440-p-9989.html
Michael
