ASR list of known class D home audio amplifiers.
The McIntosh MI502 amplifier uses Class D Hypex modules (I can't find which), SMPS power supplies and has blue meters. $4500, 22 lbs.
They have 4, 8 and 12-channel Class D amps available also. Blue meters for 2 and 4 channel, while 8 and 12 get LEDs. They're sold as they are meant for install, but use standard home audio connections. I didn't look for pricing on the larger amps.
This is one we gotta get Amir to measure... 500 watts! I mentioned this in the 'Bose buys McIntosh' thread, but thought I'd post it here to get these into the database. :cool:
Which Artera? The Mono and Stereo are both current dumping designs, and the Solus Play doesn't appear to be class D either. https://quad-hifi.co.uk/products/platina-series has no details beyond 'Coming Soon...' and a front panel harking back to the FM4.
Thanks, my bad. The Platinums were their premier solid state from ten years or so ago. I have two of the monos. Current dumping A/B, as you say.
Creek 4040 A - Integrated with DAC. Infineon Merus based power stage with an output filter, unlike some of the Merus based amps. Power output claimed as 55W 8R, 110W 4R - duration and distortion not specified. 5W idle, <0.5W standby.
The now defunct Acoustic Realitymade several ICEpower based power amplifiers. The ones I can remember are:
eAR Enigma Plus
eAR 202
eAR 501
eAR 1001
I'm pretty sure the numbered ones later came in a REF version. From what I can read others said about the REF version is, that the only real difference was the 3x higher price.
I should also have said that I have an analogue Artera pre-amp, which is still marketed, connected to the Platinums.
Let's add 3e Audio A5 / A7 / A7 mono / A5se / A7SE to the list?
The MI502 uses two cards serial "bridged" per channel. This essentially doubles the maximum output voltage thou max current is the same as a single module. It also doubles the allowable impedance load. e.g. two 2-Ohm stable modules combined is 4-Ohm stable. Which may explain the lack of a 2-Ohm specification.
If both modules (and associated pre-amplification circuitry) are not carefully matched it can lead to asymmetry or zero-crossover distortions. I see several potentiometers so they might be for "tweaking" offset/bias/gain.
Add to the Primare AB list: SPA22, SPA23, A30.7, I22 and !32
There is a German company with a power amp with NCore:
Rather expensive at $2500.
Any suggestions are welcome. Post suggestions here. I will gather the details and add them. Thanks. :D This will be organized as results come in.
So give me brand names and model numbers of class D amps and I'll create the list just like the EQ/PEQ webpage @ ASR is done.
3E Audio
260-2-29A PFFB Stereo amplifier Module
480-1-29A PFFB Mono amplifier Module
AMPED AMERICA
AMP 2250 @ 1% THD+N @ 1kHz (with AES17 filter) 250WPC @ 8 Ohm 500WPC @ 4 Ohm
AMP 2400 @ 1% THD+N @ 1kHz (with AES17 filter) 400WPC @ 8 Ohm 800WPC @ 4 Ohm
AIYIMA
A70 2 CH
A07
A07 Pro
A07 MAX
A08 Pro
Apollon Audio
Hypex Based Stereo amplifiers
NC502MP Module Stereo Amplifier Power rating/ch 450W@2ohm 500W@4ohm 350W@8ohm
NC252MP Module Stereo Amplifier Power rating/ch 180W@2ohm 250W@4ohm 150W@8ohm
NC122MP Module Stereo Amplifier Power rating/ch 115W@2ohm 125W@4ohm 75W@8ohm
NCMP2400 Amplifier NCore NC502MP dual mono design 2 CH Power rating/ch not supported@2ohm 1000W@4ohm 1200W@8ohm
NCMP1000 Amplifier NCore NC252MP dual mono design Power rating/ch not supported@2ohm 400W@4ohm 500W@8ohm
NC1200 DM Dual mono Stereo Amplifier 2 CH 1200W@2ohm 700W@4ohm 400W@8ohm
NCx500 ST NCOREx Stereo Amplifier 600W@2ohm 600W@4ohm 380W@8ohm
NCx500 ST Lux Stereo Amplifier 675W@2ohm 650W@4ohm 380W@8ohm
Nilai 500 DM Dual Mono Stereo Amplifier 500WATT@2OHM 575WATT@4OHM 260WATT@8OHM
NCx500 DM Dual Mono Stereo Amplifier 700WATT@2OHM 700WATT@4OHM 400WATT@8OHM
Nilai 500 DM Lux Dual Mono Stereo Amplifier 500WATT@2OHM 575WATT@4OHM 260WATT@8OHM
NCx500 DM Lux Dual Mono Amplifier 700WATT@2OHM 700WATT@4OHM 380WATT@8OHM
IcePower based Stereo amplifiers
AS1200 1200AS2 module -/WATT@2OHM 700WATT@4OHM 620WATT@8OHM
AS2400 4 Channel Amplifier 700W@4ohm 620W@8ohm
Monoblocks
Purifi 1ET400A Eigentakt Mini Monoblock 450WATT@2OHM 425WATT@4OHM 227WATT@8OHM
Hypex NC500MP Module Monoblock 400WATT@2OHM 500WATT@4OHM 270WATT@8OHM
Hypex NC250MP Module Monoblock 180WATT@2 OHM 230WATT@4OHM 130WATT@8 OHM
NC2K SLM Monoblock 2000WATT@2OHM 2500WATT@4OHM 1600WATT@8OHM
NC1200 SLM Monoblock 1200WATT@2OHM 700WATT@4OHM 400WATT@8OHM
Hypex NCOREx NCX500 Lux Mini monoblock 700WATT@2OHM 700WATT@4OHM 380WATT@8OHM
Purifi 1ET7040SA M Monoblock 950W@2ohm 500W@4ohm 250W@8ohm
NCx500 M Monoblock 700W@2ohm 700W@4ohm 380W@8ohm
Purifi 1ET400A M Monoblock 450W@2ohm 425W@4ohm 227W@8ohm
Multichannel amplifiers
Purifi 1ET7040SA Multichannel Amplifier (6-12 Channel) 950WATT@2OHM 500WATT@4OHM 250WATT@8OHM
Purifi 1ET7040SA Multichannel Amplifier (3-5 Channel) 950WATT@2OHM 500WATT@4OHM 250WATT@8OHM
Purifi 1ET400A Multichannel Amplifier (6-12 Channel) 450WATT@2OHM 425WATT@4OHM 227WATT@8OHM
Purifi 1ET400A Multichannel Amplifier (3-5 Channel) 450WATT@2OHM 425WATT@4OHM 227WATT@8OHM
NCMP8350 4x Hypex NCore NC502MP 450WATT@2 OHM 500WATT@4OHM 350WATT@8OHM
NCMP8200 4x Hypex NCore NC252MP 180WATT@2OHM 250WATT@4OHM 150WATT@8OHM
NCMP6350 3x Hypex NCore NC502MP 450WATT@2OHM 500WATT@4OHM 350WATT@8OHM
NCMP6200 3x Hypex NCore NC252MP 180WATT@2OHM 250WATT@4OHM 150WATT@8OHM
NCMP4353W 6 channel stereo 3-Way NCMP4353W Amplifier with 2x Hypex NCore NC502MP and 2x Hypex NCore NC100HF
NCMP4350 4 channel NCMP4350 Amplifier with 2x Hypex NCore NC502MP 450WATT@2OHM 500WATT@4OHM 350WATT@8OHM
NCMP4200 4 channel NCMP4200 Amplifier with 2x Hypex NCore NC252MP 180WATT@2OHM 250WATT@4OHM 200WATT@8OHM
AS4800 8-Channel amplifier with four Icepower 1200AS2 amplifier modules -/WATT@2OHM 700WATT@4OHM 620WATT@8OHM
AS3600 6-Channel amplifier with three Icepower 1200AS2 amplifier modules -/WATT@2OHM 1200WATT@4OHM 620WATT@8OHM
AS2400 4-Channel or true dual mono stereo amplifier with two Icepower 1200AS2 modules -/WATT@2OHM 700WATT@4OHM 620WATT@8OHM
NC500 3 Channel Hypex NC500 550WATT@2OHM 700WATT@4OHM 400WATT@8OHM
HNCx500 Multichannel Hypex NCOREx NCx500 Amplifier (6-12 Channel) 700WATT@2OHM 700WATT@4OHM 380WATT@8OHM
Purifi Eigentakt 1ET400A Multichannel Audio Amplifier (3-5 Channel) 450WATT@2OHM 425WATT@4OHM 227WATT@8OHM
Hypex NCOREx NCx500 Multichannel Audio Amplifier (3-5 Channel) 700WATT@2OHM 700WATT@4OHM 380WATT@8OHM
Hypex NCOREx NCx500 Multichannel Amplifier (3-5 Channel) 700WATT@2OHM 700WATT@4OHM 380WATT@8OHM
Purifi 1ET400A 3 Channel Amplifier 450WATT@2OHM 425WATT@4OHM 227WATT@8OHM
Hypex NC1200 3 Channel Amplifier 1200WATT@2OHM 700WATT@4OHM 400WATT@8OHM
Premium Amplifiers
Purifi 1ET7040SA Multichannel Amplifier (6-12 Channel) 950W @ 2ohm | 500W @ 4ohm | 250W @ 8ohm
Purifi 1ET7040SA Multichannel Amplifier (3-5 Channel) 950W @ 2ohm | 500W @ 4ohm | 250W @ 8ohm
Purifi 1ET400A Multichannel Amplifier (6-12 Channel) 450W @ 2ohm | 425W @ 4ohm | 227W @ 8ohm
Purifi 1ET400A Multichannel Amplifier (3-5 Channel) 450W @ 2ohm | 425W @ 4ohm | 227W @ 8ohm
Hypex NC1200 Premium Monoblock Amplifier Apollon PNC 1200 1200WATT@2OHM 700WATT@4OHM 400WATT@8OHM
Hypex NC1200 Based Premium Dual Mono Amplifier Apollon PNC1200 1200WATT@2OHM 700WATT@4OHM 400WATT@8OHM
Purifi 1ET9040BA Eigentakt Dual Mono Premium Amplifier Apollon PET1200 DM 1200WATT@2OHM 750WATT@4OHM 375WATT@8OHM
Purifi 1ET7040SA Eigentakt Dual Mono Premium Amplifier Apollon PET950 950WATT@2OHM 500WATT@4OHM 250WATT@8OHM
Purifi 1ET9040BA Eigentakt Premium Monoblock Amplifier PET1200M 1200WATT@2OHM 750WATT@4OHM 375WATT@8OHM
Purifi 1ET7040SA Eigentakt Premium Monoblock Amplifier PET950 950WATT@2OHM 500WATT@4OHM 250WATT@8 OHM
Apollon Hypex NCOREx NCx500 Multichannel Amplifier (6-12 Channel) 700WATT@2OHM 700WATT@4OHM 380WATT@8OHM
Apollon Hypex NCOREx NCx500 Multichannel Amplifier (3-5 Channel) 700WATT@2OHM 700WATT@4 OHM 380WATT@8OHM
Purifi Based Stereo amplifiers
1ET400A ST Stereo Amplifier 450W@2ohm 425W@4ohm 227W@8ohm
1ET7040SA ST Stereo Amplifier 500W@2ohm 400W@4ohm 200@8ohm
1ET400A ST Lux Stereo Amplifier 450W@2ohm 425W@4ohm 227W@8ohm
1ET7040SA DM Dual Mono Stereo Amplifier 950WATT@2OHM 500WATT@4OHM 250WATT@8OHM
1ET400A DM Lux Dual Mono Amplifier 450WATT@2OHM 425WATT@4OHM 227WATT@8OHM
1ET7040SA DM Lux Dual Mono Amplifier 950WATT@2OHM 500WATT@4OHM 250WATT@8OHM
ATI Amplifier Technologies
AT52X SERIES Hypex N-Core 200W/ch 2 to 8 channels 7-Year Warranty
AT54X SERIES Hypex N-Core 500W/ch 1 to 4 channels 7-Year Warranty
Atma-Sphere Music Systems
Class D monoblocks, 2 x 100 Watts
Audio Research
DS225 225W/ch@8R 1% THD 360W/ch@4R both channels driven
DS450 450W/ch@8R
DS450M monaural amp 450W@8R
DSi200 Integrated Amplifier 200W/ch@8R 300W/ch@4R dynamic outputs of 400Wpc@8R 800W/ch@4R
Audiophonics
HPA-S400ET
Aurender
AP20 200WPC@8Ω 350WPC@4Ω dual-mono configuration
Behringer
A800
EPQ304
NX1000
NX1000D
NX3000D
NX4-6000
NX6000
NX6000D
Bluesound
POWERNODE
Powernode Edge
boXem
Hypex NCx500
A 5519/N1
A 5517/N2
A 5519/N2
A 5519/N2M
A 5519/N3
A 5519/N4
A 5518/N5
Purifi 1ET400A
A 4215/E2
A 4215/E3
A 4215/E4
A 4215/E5
Arthur 4215/E2
Purifi 1ET7040SA
A 4222/E1
A 4222/E2M
Arthur 4222/E1
Buckeye Amps:
Buckeye Integrated Amplifier, release to be determined.
NCORE
Hypex NC502MP 2 CH
Hypex NC502MP 4 CH
Hypex NC502MP 6 CH
Hypex NC502MP 8 CH
Hypex NC252MP 2 CH
Hypex NC252MP 4 CH
Hypex NC252MP 6 CH
Hypex NC252MP 8 CH
NCOREx
Hypex NCx500 Monoblock
Hypex NCx500 2 CH
Hypex NCx500 3 CH
PURIFI
PURIFI 1ET7040SA Monoblock
PURIFI 1ET400A Monoblock
PURIFI 1ET400A 2 CH
PURIFI 1ET400A 3 CH
Cambridge Audio
Evo 75
Evo 150
Class D Audio
TI-3255 TI-3255 Balanced and Single Ended Amplifier 2x315W4-Ω at 10% THD and 2x150W8-Ω
Mini DC or Battery Powered Class D Audio Power Amplifier 8Ohms15WRMS X 2 4Ohms15WRMS X 2
CDA-250 AUDIO AMPLIFIER 125WX2 8 OHM, 250W RMSX2 4 OHM
CDA-120 POWER AMPLIFIER MODULE 60WattsRMSXTwo Channel Stereo into 8 Ohm, 120WRMSX2 into 4 ohms, and 240WRMS into 8 Ohms in Single Channel Bridge Mode
SDS-550 Amp and Twin Power Supply 250 Watts RMS X 2 into 8 Ohms
SDS-500 Audio Power Amplifier 250 Watts RMS X 2 into 8 Ohm
SDS-250 Audio Power Amplifier 250 WattsRMS X 2 into 4 Ohm, 125 Watts X 2 into 8 Ohm, and 500W into 8 Ohm in Bridged Mode
SDS-120 Audio Power Amplifier 120 Watts RMS X 2 into 4 Ohm, 60 Watts X 2 into 8 Ohm, and 240W into 8 Ohm in Bridged Mode
Mono GaN M Mono-Block Audio Amplifier Gallium Nitride 200W RMS into 8 ohms 300W into 4 ohms
Mono GaN M Mono-Block Audio Amplifiers(2) Gallium Nitride Matched Pair 200W RMS into 8 ohms 300W into 4 ohms
Mini GaN 3 Gallium Nitride 250W Stereo Power Amplifier 8Ohms125WRMS Continuous (400W Peak) 4Ohms200WRMS Continuous (500W Peak)
Mini GaN 5 400W Gallium Nitride Stereo Power Amplifier 8Ohms200WRMS Continuous (400W Peak) 4Ohms300WRMS Continuous (500W Peak)
Crown Audio
XLS 1002
XLS 1502
XLS 2002
XLS 2502
D-Sonic Custom Audio
M3a-6900-9 Nine Channel Amplifier 3X1500W, 6X400W / 8Ω
M3a-4400-11 Eleven Channel Amplifier 11 X 400W / 8Ω
M3a-6100-7 Seven Channel Amplifier 3X1500W, 4X400W / 8Ω
M3a-5400-7 Seven Channel Amplifier 2X1500W, 1X800W , 4X400W / 8Ω
M3a-4000-7 Seven Channel Amplifier 3X800W / 4X400W / 8Ω
M3a-2800-7 Seven Channel Amplifier 7 X 400W / 8Ω
M3a-5300-5 Five Channel Amplifier 3X1500W, 2X400W/8Ω
M3a-3200-5 Five Channel Amplifier 3X800W, 2X400W / 8Ω
M3a-2000-5 Five Channel Amplifier 5 X 400W / 8Ω
M3a-4500-3 Three Channel Amplifier 3 X 1500W / 8Ω
M3a-2400-3 Three Channel Amplifier 3 X 800W / 8Ω
Three Channel Amplifier 3 X 400W / 8Ω
M3a-3000S Stereo Amplifier 2 X 1500W / 8Ω
M3a-1200S Stereo Amplifier 2 X 800W / 8Ω
M3a-800S Stereo Amplifier 2 X 400W / 8Ω
M3a-1500M Mono Amplifier (Per Channel) 1500W / 8Ω
M3a-600M Mono Amplifier (Per Channel) 1 X 800W / 8Ω
Dayton Audio
DTA-100LF Desktop Subwoofer Amplifier with EQ
APA102BT Stereo 60 WPC Bluetooth Amplifier
DA30 2X15W Bridegable Mini Amplifier
DTA-2.1BT2 100W 2.1 Bluetooth Amplifier with Sub Frequency Adjustment
DTA-PRO 100W Bluetooth Amplifier with USB DAC IR Remote and Sub Output
WB40A Wi-Fi Bluetooth Multi-Room 2x20W Amplifier with IR Remote
Denon
CEOL N12
HEOS Amp
Douk Audio
1002P Mini Stereo Digital Power Amplifier MM Phono / Home Turntable Amp 100W×2
A10 HiFi Stereo Bluetooth 5.0 Digital Amplifier USB/OPT/COAX Integrated Audio Amp 120W+120W
A100 TPA3255
A200 HiFi Mono/2.0 Channel Digital Amplifier Full Frequency / Subwoofer Power for Speaker Amp
G3 Mini Bluetooth 5.0 Digital Amplifier Home Stereo Speaker Power Amp 50W+50W
G4 Mono Channel Digital Amplifier Subwoofer/Full-Frequency Power Amp 100W
H7 HiFi Balanced XLR Digital Amplifier Home Stereo Speaker Amp w/VU Meter 300W×2
M1 PLUS Mini Bluetooth 5.0 Digital Amplifier COAX/OPT Power Amp USB Player 100W×2
M1 PRO HiFi Bluetooth 5.0 Digital Amplifier Desktop Stereo Amp USB Player 160W×2
M3 HiFi 2.1 Channel Digital Amplifier with Bluetooth 5.0 Subwoofer Power Amp USB Player
M4 HiFi Bluetooth 5.0 Digital Amplifier Stereo 4 Channel Multi-room Audio Amp 50W×4
Q10 HiFi Bluetooth 5.0 Digital Amplifier Mini AUX/Optical Stereo Audio Power Amp 100W
Q100 Mini 2.1 Channel Bluetooth 5.0 Digital Amplifier Home Stereo Speaker Amp
ST-01/ ST-01 PRO HiFi Bluetooth 5.0 Tube Amplifier USB DAC COAX/OPT Digital Audio Amp w/VU Meter
T6PRO HIFI TPA3255 Bluetooth Tube Amplifier with VU Meter 300Watts x2
Tone HiFi Bluetooth 5.0 Digital Amplifier USB DAC Headphone Amp Stereo Audio Amp
EverSolo
AMP-F2
Fosi Audio
V3 Monoblock
ZA3 Balanced stereo & bridged mono amplifier Home Audio Ti TPA3255 Chip
-With 48V/5A PSU Stereo; 155Wx2 @4Ω; Mono: 235Wx1 @4Ω
-With 32V/5A PSU Stereo; 95Wx2 @4Ω; Mono: 110Wx1 @4Ω
Halcro Logic
MC20 power amplifier 400Wpc continuous into 4 ohms
MC30 3 Channel Power Amplifier 400 watts per channel
MC50 5 Channel Power Amplifier 350 watts per channel
MC70 7 Channel Power Amplifier 350 watts per channel
Heaven Eleven Audio
Billie II integrated amp ICEpower 200AS2 module, 215W 4Ω |120W 8Ω, Class A ECC99 x 2 tube preamp
HiFi ROSE
RS520
RS201E
RA180
RA280
Hifiakademie
PowerAmp P6(s)
Hypex
FA122
FA123
FA251
FA252
FA253
FA501
FA502
FA503
Nilai Series
Nilai500DIY Mono Power Amplifier Kit 500W with 1% THD at 4 ohms PS500 DIY power supply
Nilai500DIY monoblock 500WATT@2ohm 525WATT@4ohm 260WATT@8ohm
Nilai500DIY stereo amplifier 2x250WATT@4ohm 2x250WATT@8ohm
Mains powered NCORE® Family (NCxxxMP)
NC502MP OEM Amp and PS module Stereo 2Ω2x450W (BTL 2Ω is not supported) 4Ω2x500W (1 x 1000W in BTL) 8Ω2x350W (1 x 1200W in BTL)
NC500MP OEM Amp and PS module Monoblock 2Ω400W 4Ω500W 8Ω270W
NC252MP OEM Amp and PS module Stereo 2Ω2x180W (BTL 2Ω is not supported) 4Ω2x250W (1 x 400W in BTL) 8Ω2x150W (1 x 500W in BTL)
NC250MP OEM Amp and PS module Monoblock 2Ω180W 4Ω250W 8Ω130W
NC122MP OEM Amp and PS module Stereo 2Ω2x115W (BTL 2Ω is not supported) 4Ω2x125W (1 x 200W in BTL) 8Ω2x75W (1 x 250W in BTL)
NC100HF OEM Amp and PS module Monoblock
NCORE® Amplifier Family
NC1200 OEM Monoblock 2Ω1200W 4Ω700W 8Ω400W
NC2K OEM Monoblock 2Ω2000W 4Ω2500W 8Ω1600W
NC500 OEM Monoblock 2Ω550W 4Ω700W 8Ω400W
NCOREx® Amplifier Family
NCx500 OEM Monoblock 2Ω700W 4Ω700W 8Ω400W
ICEpower
AUX-PLANT Mono 20W(continuous) 30W(peak)
ENGINE-400ENGINE-400 Output power 1 % THD+N 20 Hz – 20 kHz 400W(4 Ω) 300W(2 Ω)
MOTHERBOARD-1 2x400Wrms(4Ω)
80AM2 2x80W@4 Ω single ended or 1x160W@8Ω bridged (BTL)
250A Output Power per channel 1 % THD+N 20 Hz – 20 kHz 250W(2.7 Ω) 110W(8 Ω)
400SM 400W SMPS
500A Output power per channel 1 % THD+N 20 Hz – 20 kHz 600W(4 Ω) 300W(8 Ω)
500ASP Output Power 1 % THD+N, 20 Hz – 20 kHz 500W(4 Ω) 250W(8 Ω)
1000ASP Output power 1 % THD+N 20 Hz – 20 kHz 1100W(4 Ω) 525W(8 Ω)
1500S – 69V 1500 W RMS power supply
1000S ICEpower 1000w power supply
250ASX2 power supply with audiophile class D amp of 2x250W@4Ω which can be bridged to 1x500W@8Ω
125ASX2 power supply with audiophile class D amp of 2×125W@4Ω, bridgeable to 1×450W@4Ω
50ASX2BTL monoblock power supply 1x170W
50ASX2SE power supply 2 CH stereo 2x50W
200ASC monoblock and power supply 1x200W
2000AS2 HV 2x2000W ICEedge based class D audio amp with ErP and Energy Star compliant power supply
2000AS1 HV audio power amp with ErP & Energy Star power supply 2000W@4Ohm/ch ≤ 1 % THD+N, 1 kHz 1400W@8Ohm/ch ≤ 1 % THD+N, 1 kHz
1200AS2 Single stage PFC converter with 2x1200W ICEedge amp
1200AS1 Single stage PFC converter with 1x1200W ICEedge amp
700AS2 LLC converter with 2x700@4R 350W@8R ICEpower amp
700AS1 LLC converter with 1x700@4R [email protected]Ω ICEpower amp
400A2 2x400W output bridgeable to 800 W and 70V constant voltage output 400W(SE 4Ω) 800W(BTL 8Ω)
300A2 2x300W output bridgeable to 600 W and 70V constant voltage output 300W(SE 4Ω) 600W(BTL 8Ω)
300A1 1x300W Output power/ch 1%THD+N 20 Hz–20 kHz 300W@4Ω 150W@8Ω
300AS1 power supply with a 1x300W amp Output Power/ch 1%THD+N 20 Hz–20 kHz 300W@4Ω 150W8Ω
200AS2 300W fly back power supply combined with 2x215W amp Output Power/ch 1%THD+N 20 Hz–20 kHz 215W@4Ω 120W8Ω
200AS1 fly back power supply with continuous power 160W short-term power 300W combined with a 1x200W amp
100AS2 fly back power supply with continuous power 100 W short-term power of 300 W combined with a 2x100W amp
100AS1 fly back power supply with continuous power 100 W short-term power capacity of up to 300W Mono 100W4Ω 50W8Ω
INTERNET OF MUSIC (IOM)
i250 Ncore 250 watt stereo module with passive volume control and selectable 3 channel input
500 Mono NCx500oem 700W max Hypex SMPS1200A700 power supply
500 Stereo two NCx500oem boards Hypex SMPS1200A700 power supply
500m Hypex, N-Core 2 x 500W
NCore Hypex, N-Core, 2 x 250W
v250 Ncore, 250 watt stereo module
JBL
MA310
MA510
MA710
MA7100HP
MA9100HP
Jeff Rowland Design Group
Daemon Integrated dual Pascal modules 8 Ω: 1500 WPC / 4 Ω: 2500 WPC
Model 125 ICEpower 250ASX2 module 125 watts @ 8 ohms / 250 watts @ 4 ohms 500 watts @ 8 ohms BTL
Model 535 250 watts @ 8 ohms / 500 watts @ 4 ohms 900 watts @ 8 ohms BTL
Model 925 430 watts @ 8 ohms / 850 watts @ 4 ohms
RContinuum Series 2 integrated Continuous RMS 400 watts stereo Continuous RMS 800 watts stereo
Legacy Audio
LIFESTYLE COLLECTION i·V3 3 CH ICEedge® technology 660Watts/ch x 3@4ohms all channels driven 610Watts/ch x 3@8ohms all channels driven
LIFESTYLE COLLECTION i·V5 5 CH ICEedge® technology 660Watts/ch x 5@4ohms all channels driven 610Watts/ch x 5@8ohms all channels driven
LIFESTYLE COLLECTION Powerbloc2 2 CH 325Watts/chx2@8ohms 650Watts/chx2@4 ohms 475Watts@4ohms both channels driven
LIFESTYLE COLLECTION Powerbloc4 4 CH 325Watts/chx4@8ohms 650Watts/chx4@4ohms
MASTERS COLLECTION i·V1 ULTRA Mono Block ICEedge® technology 1600watts/ch@4ohms 1125Watts/ch@8ohms
MASTERS COLLECTION i·V2 ULTRA Monoblock up to 8 CH ICEedge® technology 1000Watts/ch x 2@4ohms all channels driven, 610 watts/ch x 2@8 ohms, all channels driven
MASTERS COLLECTION i·V3 ULTRA 3 CH ICEedge® technology 600Watts/ch@8R all channels driven
MASTERS COLLECTION i·V4 ULTRA 6 CH ICEedge® technology 610Watts/ch@8R 1000Watts/ch@4R
PERFORMANCE COLLECTION Powerbloc2 ULTRA dual ICEpower monoblock 2 CH 325Watts/ch x 2@8ohms 650Watts/ch x 2@4ohms
PERFORMANCE COLLECTION i·V2 2 CH ICEedge® technology 660Watts/ch x 2@4ohms all channels driven 610Watts/ch x 2@8 ohms all channels driven
PERFORMANCE COLLECTION i·V4 4 CH ICEedge® technology 660Watts/ch x 4@4ohms all channels driven 610Watts/ch x 4@8ohms all channels driven
PERFORMANCE COLLECTION i·V6 6 CH ICEedge® technology 660Watts/ch x 6@4ohms all channels driven 610Watts/ch x 6@8ohms all channels driven
PERFORMANCE COLLECTION i·V7 7 CH ICEedge® technology 660Watts/ch x 7@4ohms all channels driven 610Watts/ch x 7@8ohms all channels driven
PERFORMANCE COLLECTION i·V8 8 CH ICEedge® technology 660W/ch x 8@4ohms all channels driven 610Watts/ch x 8@8ohms all channels driven
Lyngdorf
Millennium MkIV
MXA-8400 Purifi EIGENTAKT
SDA 2175
SDAI 2175
SDA-2400
TDAI-1120
TDAI-2170
TDAI 2200
TDAI-3400
Marantz
PM-10
AMP 10
PM-12SE
Model 30
Model M1
Model M4
March Audio
P501-1 MONO-BLOCK POWER AMPLIFIER Purifi 1ET7040SA 2Ohms950Wrms 4Ohms500Wrms 8Ohms250 Wrms
P421-1 MONO-BLOCK POWER AMPLIFIER Purifi 1ET400A 2Ohms580Wrms 4Ohms425Wrms 8Ohms227Wrms
P422-1 STEREO POWER AMPLIFIER Purifi 1ET400A 2Ohms450Wrms 4Ohms425Wrms 8Ohms227Wrms
P262-1 STEREO POWER AMPLIFIER Purifi 2Ohms430Wrms 4Ohms265Wrms 8Ohms135Wrms
P801-1-1 MONO-BLOCK POWER AMPLIFIER Purifi 1ET9040BA Power Output (0.1% THD) 2Ohms1400Wrms 4Ohms750Wrms 8Ohms375Wrms
Matrix Audio
Element P
Element P2
Monoprice
M8250x 8x200 W/ch Hypex NC502MP 8 CH
M8125x 8x100 W/ch NC252MP 8 CH
NAD
M28
M33
M23
M10 (+V2)
C298
C268
C379
C389
C399
C700 (+V2)
C328
C338
C368
C388
C3050 (+LE)
NAD T778
NAD T799
Nobsound
G2 Mini 100W Mono Channel Digital Amplifier Subwoofer/Full-Frequency Power Amp for Home Stereos
G2 PRO Mini 300W Mono Digital Power Amplifier Subwoofer/Full-Frequency Home Audio Amp
Mini 2.1 Channel Bluetooth 5.0 Digital Amplifier Board TPA3116 Stereo Subwoofer Amp Module
M5.1 HiFi 5.1 Channel Amplifier w/Bluetooth COAX/OPT/USB Home Subwoofer Power Amp
NS-01G PRO Mini Bluetooth 5.0 Digital Amplifier USB Sound Card Stereo Audio Amp 50W+50W
NS-03G SUB Mini Mono Channel Digital Amplifier HiFi Home Subwoofer Power Amp 100W
NS-04G Mini TPA3116 Digital Amplifier Class D Desktop Stereo Audio Amp for Home Speakers
NS-04G PRO HiFi 2.0 Channel Digital Amplifier Mini Home Stereo Audio Amp 100W×2
NS-10G Mini Bluetooth 5.0 Digital Amplifier HiFi Stereo Audio Bass Amp 50W+50W
NS-10G PRO Mini Bluetooth 5.0 Digital Amplifier DSP HiFi Stereo Audio Power Amp
NS-13G Mini 2.0 Channel Digital Amplifier HiFi Home Desktop Audio Amp 100W+100W
NS-14G Bluetooth HiFi 2.1 Channel Power Amplifier Subwoofer Stereo Audio Amp
NS-15G Mini Bluetooth 5.0 Digital Amplifier Receiver TPA3116 Stereo Audio Amp 100W+100W
NS-20G Mini Bluetooth 5.0 Digital Amplifier HiFi Stereo Headphone Amp 100W+100W
TA-21 Mini Bluetooth 5.0 DSP Digital Amplifier TPA3221 Stereo Audio Amp Receiver
NORD
DSP-DAC NC252MP Hypex NCore NC252MP twin channel Module DAC preamplifier power amplifier 2x150Wrms 8 Ohms 2x250Wrms 4 Ohms 2x180Wrms 2 Ohms
ONE SE NC1200MB Monoblock power amplifier Hypex NCore NC1200 Module Hypex SMPS1200A700 Power Supply 1200W 2ohm 700W 4ohm 400W 8ohm
NORD ONE SE NC1200DM Dual mono stereo power amplifier 1200W 2ohm 700W 4ohm 400W 8ohm
TWO ICE 1200AS/2 1200W 4Ohms 1 Channel Driven 2 X 600W 8 Ohms 2x 700W 4 Ohms
Hypex and Purifi multichannel amplifiers
ONE NCX500 3CH Power amplifier 3 x Hypex NCore NCx500 Module 3 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE MP NCXXX 9-16 CH Mixed power amplifier
ONE MP NC502 5-6 CH Power amplifier
ONE NC5003CH 3 CH Power amplifier
ONE MP NC252 4-8 CH Multi channel power amplifier 2-4 Hypex NCore NC252MP twin channel module 2x150Wrms8Ohms 2x250Wrms4Ohms 2x180Wrms2Ohms
ONE MP NCXXX 4-8 CH Mixed power multi channel power amp Hypex NCXXXMP series of modules
ONE MP NC122 4-8 CH Multi channel power amplifier Hypex NCXXXMP series of modules 2x75Wrms 8 Ohms 2x125Wrms 4 Ohms 2x115Wrms 2 Ohms
ONE MP NC502 2-4CH Multi channel power amplifier Hypex NCore NC502MP twin channel Module 2x350Wrms8 Ohms 2x500Wrms4 Ohms 2x450Wrms2 Ohms
ONE MP NC252 2-4CH Multi channel power amplifier Hypex NCore NC252MP twin channel Module 2x150Wrms8 Ohms 2x250Wrms4 Ohms 2x180Wrms2 Ohms
ONE MP NC122 2-4CH Multi channel power amplifier Hypex NCore NC122MP twin channel Module 2x75Wrms8 Ohms 2x125Wrms4 Ohms 2x115Wrms2 Ohms
THREE 1ET9040BA DM MKII Dual mono power amplifier 2 x Purifi 1ET9040BA Module 2 x Hypex SMPS1200A180 Power Supply 1400W2ohm 750W4ohm 375W8ohm
THREE 1ET9040BA DM Dual mono power amplifier 2 x Purifi 1ET9040BA Module 2 x Hypex SMPS1200A180 Power Supply 1400W2ohm 750W4ohm 375W8ohm
THREE 1ET9040BA MB MKII Mono block power amplifier 1 x Purifi 1ET9040BA Module 1 x Hypex SMPS1200A180 Power Supply 1400W2ohm 750W4ohm 375W8ohm
THREE 1ET9040BA MB Mono block power amplifier 1 x Purifi 1ET9040BA Module 1 x Hypex SMPS1200A180 Power Supply 1400W2ohm 750W4ohm 375W8ohm
THREE PURIFI 1ET7040SA
THREE 1ET7040SA 4CH MKII 4 CH Power amplifier 4 x Purifi 1ET7040SA Module 2 x Hypex SMPS1200A400 Power Supply 950W2ohm 500W4ohm 250W8ohm
THREE 1ET7040SA 3CH MKII 3 CH power amplifier 3 x Purifi 1ET7040SA Module 3 x Hypex SMPS1200A400 Power Supply 950W2ohm 500W4ohm 250W8ohm
THREE 1ET7040SA 4CH 4 CH power amplifier 4 x Purifi 1ET7040SA Module 2 x Hypex SMPS1200A400 Power Supply 950W2ohm 500W4ohm 250W8ohm
THREE 1ET7040SA 3CH 3 CH power amplifier 3 x Purifi 1ET7040SA Module 2 x Hypex SMPS1200A400 Power Supply 950W2ohm 500W4ohm 250W8ohm
THREE 1ET7040SA DM MKII Dual mono power amplifier 2 x Purifi 1ET7040SA Module 2 x Hypex SMPS1200A400 Power Supply 950W2ohm 500W4ohm 250W8ohm
THREE 1ET7040SA DM Dual mono power amplifier 2 x Purifi 1ET7040SA Module 2 x Hypex SMPS1200A400 Power Supply 950W2ohm 500W4ohm 250W8ohm
THREE 1ET7040SA MB MKII Mono block power amplifier 1 x Purifi 1ET7040SA Module 1 x Hypex SMPS1200A400 Power Supply 950W2ohm 500W4ohm 250W8ohm
THREE 1ET7040SA MB Mono block power amplifier 1 x Purifi 1ET7040SA Module 1 x Hypex SMPS1200A400 Power Supply 950W2ohm 500W4ohm 250W8ohm
THREE PURIFI 1ET400A
ONE NCX500 8CH 5-8 CH power amplifier 8 x Hypex NCx 500 Module 4 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
THREE 1ET400A 8CH 5-8 CH power amplifier 8 x Purifi 1ET400A Module 4 x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
THREE 1ET400A 4CH MKII 4 CH power amplifier 4 x Purifi 1ET400A Module 2 x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
THREE 1ET400A 3CH MKII 3 CH power amplifier 3 x Purifi 1ET400A Module 3 x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
THREE 1ET400A 4CH 4 CH power amplifier 4 x Purifi 1ET400A Module 2 x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
THREE 1ET400A DM MKII Dual mono stereo power amplifier 2 x Purifi 1ET400A Module 2x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
THREE 1ET400A 3CH 3 CH power amplifier 3 x Purifi 1ET400A Module 3 x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
THREE 1ET400A ST stereo power amplifier 2 x Purifi 1ET400A Module 1 x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
THREE 1ET400A MB MKII Monoblock power amplifier 1 x Purifi 1ET400A Module 1 x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
THREE 1ET400A MB Monoblock power amplifier 1 x Purifi 1ET400A Module 1 x Hypex SMPS1200A400 Power Supply 450W2ohm 425W4ohm 227W8ohm
ONE HYPEX NCx500
ONE NCX500 MKII 8CH 5-8 CH power amplifier 8 x Hypex NCx 500 Module 4 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE NCX500 4CH MKII 4 CH power amplifier 4 x Hypex NCore NCx500 Module 2 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE NCX500 3CH MKII 3 CH power amplifier 3 x Hypex NCore NCx500 Module 3 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE NCX500 4CH 4 CH power amplifier 4 x Hypex NCore NCx500 Module 2 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE NCX500 DM MKII Dual mono stereo power amplifier 2 x Hypex NCx500 Modules 2 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE NCX500 3CH 3 CH power amplifier 3 x Hypex NCore NCx500 Module 3 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE NCX500ST Stereo power amplifier 2 x Hypex NCore NCx500 Module 1 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
VALUE-LINE NCX500 ST Stereo power amplifier 2 x Hypex NCore NCx500 Module 1 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE NCX500 MB MKII Mono block power ampkifier 1 x Hypex NCore NCx500 Module 1 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE NCX500 MB Mono block power ampkifier 1 x Hypex NCore NCx500 Module 1 x Hypex SMPS1200A700 Power Supply 700W2ohm 700W4ohm 380W8ohm
ONE HYPEX NC500
ONE NC5003CH MKII 3 CH power amplifier 3 x Hypex NCore NC500 Module 3 x Hypex SMPS1200A700 Power Supply 550W2ohm 700W4ohm 400W8ohm
ONE NC500DM MKII Dual mono stereo power amplifier 2 x Hypex NCore NC500 Module 2 x Hypex SMPS1200A700 Power Supply 550W2ohm 700W4ohm 400W8ohm
ONE NC5003CH 3 CH power amplifier 3 x Hypex NCore NC500 Module 3 x Hypex SMPS1200A700 Power Supply 550W2ohm 700W4ohm 400W8ohm
ONE NC500 ST Stereo power amplifier 2 x Hypex NCore NC500 Module 1 x Hypex SMPS1200A700 Power Supply 550W2ohm 700W4ohm 400W8ohm
ONE NC500MB MKII Mono block power amplifier 1 x Hypex NCore NC500 Module 1 x Hypex SMPS1200A700 Power Supply 550W2ohm 700W4ohm 400W8ohm
ONE VALUE-LINE NC500 ST power amplifier 2 x Hypex NCore NC500 Module 1 x Hypex SMPS1200A700 Power Supply 550W2ohm 700W4ohm 400W8ohm
ONE NC500MB power amplifier 1 x Hypex NCore NC500 Module 1 x Hypex SMPS1200A700 Power Supply 550W2ohm 700W4ohm 400W8ohm
ONE HYPEX MPXXX
ONE MP NC502 Stereo power amplifier Hypex NCore NC502MP twin channel module 2x350Wrms8Ohms 2x500Wrms4Ohms 2x450Wrms2Ohms
VALUE-LINE MP NC502 Stereo power amplifier Hypex NCore NC502MP twin channel module 2x350Wrms8Ohms 2x500Wrms4Ohms 2x450Wrms2Ohms
ONE MP NC252 Stereo power amplifier Hypex NCore NC252MP twin channel Module 2x150Wrms8Ohms 2x250Wrms4Ohms 2x180Wrms2Ohms
ONE MP NC122 Stereo power amplifier NC122MP 75W 8 Ohms
ONE MP NC122 Stereo power amplifier NC252MP 150W 8 Ohms
ONE MP NC122 Stereo power amplifier NC502MP 350W 8 Ohms
VALUE-LINE MP NC252 Stereo power amplifier NC122MP 75W 8 Ohms
VALUE-LINE MP NC252 Stereo power amplifier NC252MP 150W 8 Ohms
VALUE-LINE MP NC252 Stereo power amplifier NC502MP 350W 8 Ohms
VALUE-LINE MP NC122 Stereo power amplifier NC122MP 75W 8 Ohms
VALUE-LINE MP NC122 Stereo power amplifier NC252MP 150W 8 Ohms
VALUE-LINE MP NC122 Stereo power amplifier NC502MP 350W 8 Ohms
VALUE-LINE MP NC250 Mono power amplifier NC122MP 75W 8 Ohms
VALUE-LINE MP NC250 Mono power amplifier NC252MP 150W 8 Ohms
VALUE-LINE MP NC250 Mono power amplifier NC502MP 350W 8 Ohms
VALUE-LINE MP NC52 Stereo power amplifier NC122MP 75W 8 Ohms
VALUE-LINE MP NC52 Stereo power amplifier NC252MP 150W 8 Ohms
VALUE-LINE MP NC52 Stereo power amplifier NC502MP 350W 8 Ohms
VALUE-LINE
ONE VALUE-LINE NC500 ST Stereo power amplifier 2 x Hypex NCore NC500 Module 1 x Hypex SMPS1200A700 Power Supply 550W2ohm 700W4ohm 400W8ohm
VALUE-LINE MP NC502 Stereo power amplifier Hypex NCore NC502MP twin channel module 2x 350Wrms8Ohms 2x500Wrms4Ohms 2x450Wrms2Ohms
VALUE-LINE MP NC252 Stereo power amplifier 2 x Hypex NCore NC252MP twin channel module 2x150Wrms8Ohms 2x250Wrms4Ohms 2x180Wrms2Ohms
VALUE-LINE MP NC122 Stereo power amplifier 2 x Hypex NCore NC122MP twin channel module 2x75Wrms8Ohms 2x125Wrms4Ohms 2x115Wrms2Ohms
VALUE-LINE MP NC250 Mono power amplifier Hypex NCore NC250MP single channel module 1x150Wrms8Ohms 1x250Wrms4Ohms 1x180Wrms2Ohms
VALUE-LINE MP NC52 Stereo power amplifier Hypex NCore NC122MP twin channel module 2x25Wrms8Ohms 2x50Wrms4Ohms 2x40Wrms2Ohms
Nuprime
STA-9
STA-9X
ST-10
ST-10M
IDA-8
IDA-16
IA-9X
AMG One
AMG STA
AMG STA SE
Evolution STA
Evolution Two
Omnia A200
Omnia A300
STA-100
O-Noorus
D1
D3
Onkyo
A-9555 integrated amplifier 85 W/ch into 8 ohms, 4–16 ohms
Orchard Audio
Starkrimson (150W)
Mono Premium
Duo
Trio
Starkrimson Ultra (500W)
Mono Ultra Premium
Mono Ultra Premium LPS
Stereo Ultra
Stereo Ultra DMC
Panasonic
SA-XR10
SA-XR25
SA-XR45
SA-XR50
SA-XR55
SA-XR70
Peachtree Audio
Carina 300
Carina 150
Carina GaN
GaN 1
Premium Audio
Mini GaN 5 Gallium Nitride transistors (GaN)
PRIMARE AB
I15 Prisma MK2 Hypex 2 x 60W/100W 8/4 ohms 2 CH
A35.8 Hypex Ncore 8x 150W 8 ohms / 8x 300W 4 ohms 8 CH
A35.2 UFPD 2 analog class D 2 x 200W 8 ohms / 2 x 400W 4 ohms 1 x 800W 2 CH or Bridged
A35.8 Hypex Ncore 8x 150W 8 ohms / 8x 300W 4 ohms or 1500W stereo bridged bi-amp'd
I35 UFPD 2 power system 2 x 150W 8 ohms / 2 x 300 4 ohms
I35 DAC DM36 UFPD 2 power system integrated amp 2 x 150W 8 ohms / 2 x 300 4 ohms
I35 Prisma DM36 – modular integrated amplifier and network player 2 x 150W 8 ohms / 2 x 300 4 ohms
I25 Modular integrated amplifier 2 x 100W 8 ohms / 2 x 200 4 ohms
I25 DAC DM36 Modular integrated amplifier and DAC 2 x 100W 8 ohms / 2 x 200 4 ohms
I25 Prisma DM36 – modular integrated amplifier and network player UFPD 2 power system 2 x 100W 8 ohms / 2 x 200 4 ohms
I15 Integrated amplifier Hypex 2 x 60W/100W 8/4 ohms
I15 MM Integrated amplifier and MM phono stage 2 x 60W/100W 8/4 ohms
PS Audio
Sprout
Stellar S300
Stellar M700
Stellar 1200
SABAJ
A30a 200 watts × 2
Sharp
SM-SX1
SM-SX10
SM-SX100 100W + 100W
SM-SX200
SM-SX300
Sinclair
X-10 (1964, board rather than a finished amp)
SMSL
A12 (MA12070 chip)
A50 (TPA3116 chip)
A50 Pro (MA12070P chip Infineon chip)
A100 (MA12070 chip)
A300
A300 bridegeable (BTL) Infineon chip
A200 (unspecified Infineon chip)
AD18 (TAS5508C+TAS5342A chips)
AL200 (MA5332MS chip)
AO100 (MA12070 chip)
AO200 MkII (MA5332 chip)
AO200 (2 x MA12070 chip) - still shown as current along with the MkII
AO300 (MA5332MS chip)
SA400 (2 x unspecified chip)
SA300 (MA12070 chip)
SA100 (TPA3116 chip)
Sonoro
MAESTRO Quantum Hypex
Sony
TA-DA9000ES
TA-DR1
TAN-88B (1978)
StormAudio
ISR Fusion 20 ICE Power
Pascal
PA 16 MK3
PA 8 Ultra MK3
SVS
Prime Wireless Pro Soundbase
T+A
A200
CALA CDR
E
M200
R1000 E
PA 1000 E
PA 1100 E
TEAC
AI-303 Integrated Amplifier/DAC
AX-505 Stereo Integrated Amplifier
AP-701 Stereo Power Amplifier
AP-505 Stereo Power Amplifier
Topping
MX3
PA5II
PA5II Plus
PA7
PA7 Plus
RA3
PA3s
VTV Amplifier
GaNFET
D400 Stereo GaNFET Digital Amplifier
Hypex
NC500 NCore with Input Buffer Options 2 CH
NC1200 Amplifier 2 CH
NC1200 NCore Amplifier 1200W with Buffer Options Monoblock
NC252MP NCore 2 CH
NC2000 NCore 2000W with Buffer Options Monoblock
NC500MP NCore 500Wx1 Monoblock
NC122MP NCore 125WX2 2 CH
NC502MP NCore Amplifier 500WX2 2 CH
NC250MP NCore Amplifier 250Wx1 Monoblock
UcD2K UcD2000 Amplifier 2000W Monoblock
NC500OEM module with Input Buffer Options Monoblock
NC502MP NCore Amplifier Wired Bridged 1200WX1 Monoblock
NC502MP NCore Amplifier 500Wx4 4 CH
NC122MP NCore Amplifier 120Wx4 4 CH
NC502MP NCore Amplifier 500Wx8 8 CH
NC252MP NCore Amplifier 4x250W 4 CH
NC252MP NCore Amplifier 250Wx8 8 CH
NC122MP NCore Amplifier 125Wx8 8 CH
NC1200 Dual Mono Design Amplifier 2 CH
NC1200 Amplifier with VTV Vacuum Tube Buffer Monoblock
NC252MP+NC250MP Three Channel Amplifier 3X250W 3 CH
NC502MP+NC500MP Three Channel Amplifier 3X500W 3 CH
NC2000 2 CH
NC502MP+2XNC252MP+NC122MP NCore Amplifier 2X500W 4X250W 2X125W 8 CH
Wired BTL Bridged NC502MP NCore Amplifier 1200WX2 2 CH
NC122MP NCore Amplifier 125Wx6 6 CH
NC502MP NCore Amplifier 500Wx6 6 CH
NC252MP NCore Amplifier 250Wx6 6 CH
NC500OEM 4 CH
NC502MP+NC252MP+NC122MP NCore Amplifier 2X500W 2X250W 2X125W 6 CH
NC500OEM Dual Mono (Two Power Supplies)2 CH
NC500OEM Amplifier with VTV Vacuum Tube Buffer Monoblock
NC500OEM Amplifier with VTV Vacuum Tube Buffer 2 CH
NC502MP+3XNC252MP NCore Amplifier 2X500W 6X250W 8 CH
NC252MP+3XNC122MP NCore Amplifier 2X250W + 6X125W 8 CH
2XNC502MP+2XNC252MP NCore Amplifier 4X500W 4X250W 8 CH
NC252MP NCore Amplifier 4x250W in Rack Mount Chassis 4 CH
NC500OEM Amplifier Hypex 3+2 + Hypex NC252MP 5 CH
2XNC252MP+2XNC122MP NCore Amplifier 2X250W + 6X125W 8 CH
NC500OEM 3 CH
NCx500 Hypex NCore Stereo with Input Buffer Options 2 CH
NCx500OEM Amplifier with VTV Vacuum Tube Buffer 2 CH
NCx500OEM module with Input Buffer Options Monoblock
NCx500OEM 3 CH
NCx500OEM 4 CH
NCx500OEM Amplifier with VTV Vacuum Tube Buffer Monoblock
NCx500OEM 5 CH
NC500OEM 5 CH
NCx500OEM Amplifier Three NCx500OEM + Hypex NC252MP 3+2 5 CH
NC500OEM Amplifier Three NC500OEM + 2xHypex NC252MP 3+4 7 CH
NCx500OEM Amplifier Three NCx500OEM + 2XHypex NC252MP 7 CH
Multi Channel Amplifer
PASCAL U-PRO2S Four Channel Amplifier 4X140 W
PASCAL T-PRO1 Three Channel Amplifier 3X250 W
PASCAL L-PRO2S Four Channel Amplifier 4X800W
Hypex NC502MP NCore Amplifier 500Wx4
Hypex NC122MP NCore Amplifier 120Wx4
Hypex NC502MP NCore Amplifier 500Wx8
Hypex NC252MP NCore Amplifier 4x250W
Hypex NC252MP NCore Amplifier 250Wx8
Purifi Audio 1ET400A Amplifier 3 CH
Purifi Audio 1ET400A Amplifier 4 CH
PASCAL L-PRO2S Eight Channel Amplifier 8X800W
Hypex NC122MP NCore Amplifier 125Wx8
Hypex NC252MP/NC250MP NCore Amplifier 5x250W
Hypex NC252MP+NC250MP Three Channel Amplifier 3X250 W
Purifi Audio 1ET400A Amplifier 3+2 Purifi + Hypex NC252MP 5 CH
Hypex NC502MP+NC500MP Three Channel Amplifier 3X500 W
Hypex NC252MP+NC122MP NCore Amplifier 2x250W 2X125W
Hypex NC502MP+NC122MP NCore Amplifier 2x500W 2X125W
Hypex NC502MP+NC252MP NCore Amplifier 2x500W 2X250W
Hypex NC502MP+2XNC252MP+NC122MP NCore Amplifier 2X500W 4X250W 2X125W 8 CH
Hypex NC502MP/NC500MP NCore Amplifier 5x500W
Hypex NC122MP NCore Amplifier 125Wx6
Hypex NC502MP NCore Amplifier 500Wx6
Hypex NC502MP/NC500MP NCore Amplifier 7x500W
Hypex Audio NC500OEM Amplifier 3 CH
Hypex NC252MP NCore Amplifier 250Wx6
Hypex Audio NC500OEM Amplifier 4 CH
Hypex NC502MP+NC252MP+NC122MP NCore Amplifier 2X500W 2X250W 2X125W 6 CH
Hypex NC502MP+NC252MP+NC250MP NCore Amplifier 2x500W 3x250W 5 CH
Hypex NC252MP/NC250MP NCore Amplifier 7x250W 7 CH
PASCAL L-PRO2S Six Channel Amplifier 6X800W
Hypex NC502MP+NC252MP+NC500MP NCore Amplifier 3x500W 2x250W 5 CH
Purifi Audio 1ET-7040SA Amplifier 3 CH
Hypex NC502MP+3XNC252MP NCore Amplifier 2X500W 6X250W 8 CH
Hypex NC252MP+3XNC122MP NCore Amplifier 2X250W + 6X125W 8 CH
Hypex 2XNC502MP+2XNC252MP NCore Amplifier 4X500W 4X250W 8 CH
Hypex NC252MP NCore Amplifier 4x250W in Rack Mount Chassis
Hypex 2XNC252MP+2XNC122MP NCore Amplifier 2X250W + 6X125W 8 CH
PASCAL
U-PRO2S Stereo Amplifier 2x140W
T-PRO1 Monoblock Amplifier 250W
T-PRO1 Stereo Amplifier 2X250W
L-PRO2S Amplifier 800WX2
L-PRO2S BTL Stereo Amplifier 2X1600W
L-PRO2S BTL MONO Amplifier 1X1600W
Purifi
1ET400A module with Input Buffer Options
1ET-400A Amplifier 2 CH
1ET400A Amplifier with VTV Vacuum Tube Buffer 2 CH
1ET400A Amplifier BTL 1X800W Monoblock
1ET400A Dual Mono (Two Power Supplies) Amplifier 2 CH
1ET400A Amplifier with VTV Vacuum Tube Buffer Monoblock
Eigentakt Stereo Amplifier based on EVAL-1 2 CH
1ET-400A Monoblock
Hypex NC500OEM Amplifier 3 CH
Custom Input Buffer for Purifi 1ET-7040SA HIGH POWER MODULE
1ET-7040SA (High Power) Amplifier 2 CH
1ET7040-SA (High Power) module Monoblock
1ET-7040SA High Power Dual Mono (Two Power Supplies) Amplifier 2 CH
1ET-7040SA Amplifier with VTV Vacuum Tube Buffer 2 CH
1ET-7040SA (High Power) Amplifier Monoblock
1ET400A Amplifier 5 CH
1ET-7040SA Amplifier with VTV Vacuum Tube Buffer Monoblock
FIVE Channel Amplifier 2+2+1 One Channel UcD2K + Two Channels Hypex NCx500OEM + Two Channels NC252MP 5 CH
SEVEN Channel 3+4 Purifi Audio 1ET400A Amplifier Purifi + 2X Hypex NC252MP 7 CH
Purifi 1ET9040-BA Monoblock
1ET-9040BA High Power Dual Mono (Two Power Supplies) Amplifier 2 CH
Purifi High Power Modules
1ET9040-BA module Monoblock
Vera Audio
P400/1000 Hypex Ncore
P150/600 RS Purifi
Wiim
Amp
Amp Pro (coming soon, Q3 2024)
Wondom
BRU5 (TPA3255 + DSP)
Yamaha
WXA-50 ICEpower 125ASX2 70W/ch @ 6 Ohms 2 CH
It might sound tedious but it would be great if this list has hyperlinks on those whose ASR review is available.... for completeness.
NOT NECESSARY though!
These are CRAZY expensive, but they are all NCore NC500 then NCx500
I confirmed this with John Stronczer the founder of bel canto.
It was the amp I heard hooked up to the Audiovector speakers i bought, before I learned of Buckeye.
It looks like it has "safety banana" jacks like on most DMMs.
