Goldhamster916
- Joined
- Oct 4, 2023
- Messages
- 214
- Likes
- 106
- Thread Starter
- #21
Just output wise (where I don’t need that much power in my room) or rather the impact, especially on the low end?
Both.Just output wise (where I don’t need that much power in my room) or rather the impact, especially on the low end?
www.audiosciencereview.com
Christ man, you asked which has the best performance. That is the PB model.Thank you!
I have seen that chart. The PB2000 will probably be around 10db higher spl at 20hz than the sb 2000pro. But would I even notice that difference in a small room at low listening levels?
It depend on how small and how low.Thank you!
| 20 hz | 25 hz | 31.5 hz | 40 hz | 50 hz | 63 hz |
| 106.8 | 110.6 | 112.3 | 113.1 | 113.5 | 114.5 |
| 95.1 | 100.1 | 105.8 | 111.3 | 111.8 | 112.2 |
Based of the info you just provided about you room and distance, the SB2000 will work fine, may even sound better. You can also send the same info to SVS and ask them. I am sure they will also recommend the SB. If you there is a good chance that you may move to a different room and distance in the not-too-distant future, then the PB may be more future proof.Room is 4x3x3m
this is the data for the pb2000
20 hz 25 hz 31.5 hz 40 hz 50 hz 63 hz
106.8 110.6 112.3 113.1 113.5 114.5
this is for the sb2000 (i cant find data for the pro version, it should probably be slightly better)
95.1 100.1 105.8 111.3 111.8 112.2
listening position is around 1.5 meter
listening level is around 70db i would say
Apart from that what difference would the new architecture of the pro make?
I haven't bought anything from them for a few years so you should contact SVS directly on this, they typically responding quickly.Do you think the new architecture on the pro makes a difference?
According to SVS:I just moved in so will be kn that room for a long time.
I get your points, I just really like good low end performance and primarily watch movies and play games, so I am a bit unsure if I would be missing out on something buying the sealed. However if I can’t tell the difference in my room/with my listening habits I would rather take the smaller one.
Klipsch Subs have a well-deserved reputation for horrific reliability. Perhaps their newer offerings are better, but have yet to face the test of time.Thanks a lot for the replies. I ordered a used Sb2000PRo for 860, immediately got fear of missing out low end power, selled it for 1000 and got, after some research, a klipsch RP 1400SW Ported sub on sale for 1000 (which usually goes for 1300 here). It will arrive tomorow and i couldnt be happier!
Thanks for your time!
You seem fixated on output, I thought you understood depending on your room size and distance, the extra output won't do anything for you. I trust Shady, but he seems to be very generous in his reviews. Anyway, I hope you made a great choice.from everything i have gathered the new models are way better than the old ones from klipsch, also in terms of reliability. the rp 1400 definetely has more output at low
frequencies than the sb2000.
audioholics reviewed the 1600sw and are quite impressed with it. i think perfomance wise the pb2000pro would be equivalent but that one cost 1300 here.
They've only been out a matter of months. The reliability of them is still very much an open question.from everything i have gathered the new models are way better than the old ones from klipsch, also in terms of reliability.
