AOSHIDA SMSL C200 Review (DAC & Amp)
Rate this DAC & HP Amp
    Votes: 9 2.7%
    Votes: 3 0.9%
  • 3. Fine (happy panther
    Votes: 58 17.6%
    Votes: 260 78.8%
ampguy
US
@Boxermotor ... nice new toy congrats!!
Is the line out fixed output only (DAC mode)?? Is there a Pre-Amp mode for volume-controlled lineout?? Both line RCA/TRS output at the sametime, right??
I'm also curious about this. Couldn't find mention of the output behavior fixed or variable in any reviews
Boxermotor
Indianapolis, USA
I can increase and decrease the line out levels. I’m currently using the balanced outputs, but I’ll try outputting through the RCA’s at the same time and report back. There isn’t a menu choice for that, so I’m guessing yes.
ampguy
US
Thanks for testing this, I'm fine with it being the ho gain not affecting the outputs. Weird that it's not documented, but sounds like you get some minimal preamp functionality with volume control mgmt there
avoidwork
Ottawa, Canada
I've been using one since Thursday and its dropped the audio signal on the optical & coax inputs multiple times each day with no obvious event happening, e.g. no surge, no audible noise, no cell phones or other random radios near by. I think the xmos controller is having trouble; the signal is 96khz or 192khz when it stops sending to 'Ho'. Trying 44.1Khz now because it just dropped in the middle of a movie I was watching (sigh).
When the audio disappears the signal is still present & requires the unit to be power cycled to start send to 'Ho' again; cycling the settings shows 'Ho' is still the active output & the input doesn't change.
Sound wise it's very similiar to the H200; it'd be fantastic if it didn't drop the audio - it's tiny!
ampguy
US
Did you try playing with that jitter setting, or go to usb2 mode?
avoidwork
Ottawa, Canada
I hadn't; out of the box it was on 'dp4' which seemed reasonable. the 'usb2' mode was also enabled out of the box, but I'm using that for a roon bridge. I'm using the coax + optical with an smsl po100 which is stable.
avoidwork
Ottawa, Canada
It seems to be fine with 44.1khz over coax + optical; can't tell if it's the input signal or just thermals that triggers the issue. issue happens with 44.1khz as well.
curly747
Have you tried setting it to dp7 and see if that works and then work your way down from there to highest stable setting.
avoidwork
Ottawa, Canada
no. i set it to 'dp1' yesterday when i had replied about 'dp4' default setting. i'm assuming i have a lemon, but if other people get simliar behavior it's probably the xmos controller; it's behaving like the i2s signal isn't being sent internally.
curly747
I would set it to the highest dp setting. Dp9 I think it is. The higher settings are more forgiving of the input signal. Check if that works. If it does then adjust setting down. If your input is a tv it may have a poor signal.
avoidwork
Ottawa, Canada
nah, it's definitely not worth further effort. i put my vmv d3 back in it's usual spot on my desk. it's definitely faulty hardware, but is it in the thermals or the xmos? i'm really thnking it's the xmos, but maybe heat is a factor into it misbehaving, either way the jitter setting is not going to make a difference here because if it did that'd be a firmware flaw and there's no upgrade port on it... and smsl doesn't really do user upgradable firmware anyways.
Laurent
What makes these DACs so well engineered? I'd be curious if @amirm could put it into words or even an article. If you were looking at a teardown of something 120 db SINAD vs 100 (although not bad) or 80 or 60. It can't all be about the components on the board - we're talking a lot of cheapy DACs on here. What are these engineers doing to attain such measurements? :D
Good design is the answer. I suspect some of those engineers have experience with high frequency stuff like mobile phone signals etc, which makes designing for audio frequencies relatively easy.
Merkurio
This C200 could potentially drive the DCA Aeons with ease, 4X more voltage than the DX3 Pro+ at 12 ohms, according to the output voltage chart.
Is there any other AIO with the same performance at low loads, regardless of price?
SlamTaz
Jumped on one of these at Amazon after reading the review. Got it yesterday and absolutely love it - drives my headphones much better than the Topping EX5 using the hight gain function. Coupled with my SMSL DA-9, drives my Elac DB6's with plenty of volume to spare. Thanks for the review!
did you use rca cables or trs to xlr cables in connecting the c200 to the da-9?
Wolven
I got a similar question. I just bought smsl c200 and kali in-8v2 both on the way.
C200 has trs I think 1/4 inch
Kali has trs i think 1/4 and XLR
Should I buy 3 or 6 ft cable Trs to Trs
Or
Should I go Trs to XLR?
stallion317
Or
Same question I have.. got a jbl lsr 305 which has both xlr and trs balanced. Which cable is ideal for it..
Bal trs to bal trs or bal trs to xlr ????
Thanks
Regards..
Wolven
Thanks
Regards..
I have been googling this and it looks that it doesn't make much difference. I'm just going with trs - trs.
