A while back I asked if there was a DAC that had multiple outputs versus inputs, thanks to the group I was introduced to the Topping D10S which is a nice device. I was wondering if anyone knew of any others that follow this feature.
Parasound P6 has USB input. I'm not sure why the snark.You guy's are killing me, Just looking to see if there is another USB DAC (because my main source is my PC) this will feed the Anthem MRX
I've changed the title so there is no confusion on what I am looking for.Parasound P6 has USB input. I'm not sure why the snark.
Why do you want digital outputs from a DAC?I've changed the title so there is no confusion on what I am looking for.
EQ and crossover functions aren't capabilities of most DACs. I'm asking why one would want the digital outputs from a DAC.The Topping D10s can also serve as a USB bridge at a very reasonable price if you have another DAC you want to use. It is especially useful if you are dealing with an active speaker system such as those designed by Siegfried Linkwitz which require EQ and crossover functions that go along with DAC functions. If miniDSP units such as the 4x10HD or the 2x4HD are used in Linkwitz or other active multiway designs, they have been found by measurement to have better performance using their digital inputs as opposed to their analog inputs.
I recently ordered the D10 balanced. I have one computer, two alternate systems. One is the unusual class D amp with only SPDIF input. I'll use the pass thru on the D10 for that. The other is a balanced pair of powered monitors. The two systems are physically near each other, so I can use the one computer and that one device to provide source material for both systems. It is an odd situation, but for the price of the Topping it isn't too dear for the functionality I get.O-H!
Yeah, but I'm still a bit confused. I understand why one purchases a multifunction device in order to accomplish many things; that's the fundamental reason we have products like integrated amplifiers, AVRs and combo DAC-headphone amps. And I understand why you would want a miniDSP (I think of them as DSPs first and foremost). But bypassing the excellent DAC section of the D10s is what is puzzling to me. I don't understand why anyone would bypass that DAC in order to feed a different DAC via a digital signal output.
I'm not trying to be argumentative here, and if you want to quit the interaction out of frustration with my inability to understand, I won't be offended.
My Current AVR MRx740 is all Digitial inputs. Meaning there is no way to bypass.Why do you want digital outputs from a DAC?
