Amir
reviewed the NX4. It looks ok for use as line out -- the noise is great, but there's a little L/R imbalance. Just keep it on low gain.
I'm not an expert on all the different hypex and purifi amps. There's a lot of them. They should all perform about the same if they have the same chipset (e.g. ncx500 or nc252 etc.). There's not a lot for an integrator to muck with, apart from power supply and maybe input buffer and wiring topology. You could search ASR for recommendations on class D amps.
If you're willing to step down from the NCX500, there's a lot of lesser expensive options. The NCX500 is their flagship model, so it will be at a premium. The NC500 is still excellent, and then there's all the NCxMP, like the NC500MP or NC502MP (both are still 500W into 4-ohm). Those are all still very good amplifier modules.
Apollon is a European hypex/purifi/icepower amp manufacturer. I've heard very good things about their build quality, but they are not a budget brand.
There's also boXem, outlaw audio, buckeye, ati, and many more. You could look at the recommended amps at
https://www.audiosciencereview.com/forum/index.php?pages/Reviews/.
I'm sure there's other threads with recommended class D amps.
