If you're just a prime member and not subscribed to the music service you won't get HD,it's not free just because you're a prime member ,you'll have access to about 2 million free songs that's about it.FYI, I am not an HD Music subscriber, just Prime and get the Icon just the same.
In my case, my subscription became Unlimited, all HD and UltraHD logos disappeared and I was instructed to go to my account in the Mother App and upgrade to HD.Um I already had HD,they just drop the price I didn't have to do anything.
Just realized that I was walking and updated the app and may have activated the trial.If you're just a prime member and not subscribed to the music service you won't get HD,it's not free just because you're a prime member ,you'll have access to about 2 million free songs that's about it.
YT Android TV App is an afterthought at best.
Agreed. Except even on mobile app it has the well known shuffle bug where it replays the same 20 songs.For YT the best option is to use the dedicated Youtube Music app, it's not perfect but a lot better than the Android TV app. It has shuffle, playlist, suggestions etc.
Just noticed this yesterday while headphone listening to Stravinsky Firebird on Decca. Although labelled as CD Quality, there was excessive and noticeable distortion on crescendo. I think it’s not worth the extra $ per month compared to Qobuz.Just wondering if any other Amazon Music users are finding that the sound quality seems to be atrocious and getting worse? It sounds like a very low bitrate MP3, made with an ancient codec... I'm sure it didn't used to be this bad.
Amazon costs less than Qobuz now.Just noticed this yesterday while headphone listening to Stravinsky Firebird on Decca. Although labelled as CD Quality, there was excessive and noticeable distortion on crescendo. I think it’s not worth the extra $ per month compared to Qobuz.
Sign up for uncompressed. It's not expensive, particularly if you have Prime.Just wondering if any other Amazon Music users are finding that the sound quality seems to be atrocious and getting worse? It sounds like a very low bitrate MP3, made with an ancient codec... I'm sure it didn't used to be this bad.
To my ears, it sounds thicker than Qubuz.so.. nobody noticed that it sounds sterile?
The most bang per buck today is Apple Music: quality, range and scope are truly excellent. (but the interface could be a little better)Amazon costs less than Qobuz now.
"sterile" and "thicker"? What does that mean?To my ears, it sounds thicker than Qubuz.
Sterile usually means lack of harmonic/intermodulation distortion, thick usually means an excess."sterile" and "thicker"? What does that mean?
exactly what i meant (sterile), it sounds somehow too clean, as if it was AI upscaled.Sterile usually means lack of harmonic/intermodulation distortion, thick usually means an excess.
I can't understand that either.exactly what i meant (sterile), it sounds somehow too clean, as if it was AI upscaled.
the other posts claiming it sounds like low bitrate, i cannot understand. i assume they are listening over the website which indeed sounds awful.
