TechnoTroll101
- Joined
- May 8, 2024
- Messages
- 32
- Likes
- 5
Hello,
I've just bought the Klipsch R-41M for my Desktop. I was using a Teufel Concept E Magnum (2.1) before and I'm amplifying the Klipsch with the Teufel Subwoofer. I've bought the Edifier R1850DB before and was not satisfied, so I ordered the Klipsch. I like them more, but still think that they are not what I really want. (in my living room I've got a full Heco Celan Hometheatre with Heco 800 fronts and 102f as rears).
The Klipsch can make a lot of fun, but they are lacking the punch when it comes to mid-bass and the overexeggerate the highs, as many other listeners agree. The reason I bought them was, that I was able to get them for 149€. (I'm from Germany).
Could you please give me some alternative in the same price-range, which you'd suggest me to test?
When it comes to the inteded use, it's listening to music in near-field surrounding (small room and sitting close to the speakers, subwoofer is under the table). I mostly listen to EDM, house, techno and hardstyle, but also like old tracks from the 80s...so the whole range, except classical music. ^^
Most important to me is the kickbass, which cannot be taken over by the subwoofer completely. (Think of the bass drum in Metallica - Nothing Else Matters, or Modern Talking - You're my heart, you're my sould, for instance)
Unfortunately the popular Pioneers are no longer produced and nearly impossible to get here in Germany.
I don't mind if they're active or passive, but guess that the latter would result in better sound quality as I don't need any additional features.
So, which bookshelf speakers would you suggest me to test? They mustn't cost more than 200€ and should not be significantly bigger than the Klipsch.
Thanks for your tips!
TechnoTroll101
TechnoTroll101
