AmalfiMan
- Joined
- Jun 2, 2022
- Messages
- 128
- Likes
- 18
Got the k9 fixed. Sounds great. Returning the topping ex5.Dead how lol? It doesn't power on or does it have the red ring of death?
What was the problem?Got the k9 fixed. Sounds great. Returning the topping ex5.
Was using the topping usb b cable i stead of the supplied fiio cable.What was the problem?
Wow, does this mean the device could have problems with any generic USB cables not supplied by Fiio?Was using the topping usb b cable i stead of the supplied fiio cable.
The support site actually mentions to use their supplied cable.Wow, does this mean the device could have problems with any generic USB cables not supplied by Fiio?
That's a bit concerning ... Where on the support site is this mentioned? I'd like to be able to use any USB cables without worrying about their functionality, lol.The support site actually mentions to use their supplied cable.
I have both the AKM and the ESS version of the K9 Pro, and I use an aftermarket USB-B and USB-C cable with both with no issuesThat's a bit concerning ... Where on the support site is this mentioned? I'd like to be able to use any USB cables without worrying about their functionality, lol.
Can you hear the difference in sound between AKM and ESS?I have both the AKM and the ESS version of the K9 Pro...
Where do you get your cocaine?oh yes, there's a huge difference in sound between them
this is what I wrote up to a friend the other day:
The difference between them is as big as the difference between the Holo May and Rockna WaveDream
The AKM is very laid back, the ESS feels like it has a cold edge of in-your-face'ness but comes off as much more detailed
The AKM I can comfortably listen to at a higher volume
My suggestion is basically this: If you get musical enjoyment from detail, use the ESS at a lower volume. If you get musical enjoyment from bass and power, use the AKM at a higher volume
Do you have both units of AKM and ESS as well?Where do you get your cocaine?
No, only the AKM because it seemed to be the cheaper version at the time. Why would they sound different though? I have yet to hear an actual difference between DACs, even stuff that's really cheap sounds the same.Do you have both units of AKM and ESS as well?
That's fine and dandy but since you don't own both version of the Fiio K9 then I'd rather believe the person that own both units, at least I'd give the owner the benefit of the doubt. The owner has sat through perhaps countless hours of listening, played with the units multiple times so by virtue of that has my attention. About volume matching, I'm sure that the owner has played with both units volume umpteenth times to be able to earball what volume is suitable and ultimately find that the units sound different. Doesn't take rocket science to figure this out.No, only the AKM because it seemed to be the cheaper version at the time. Why would they sound different though? I have yet to hear an actual difference between DACs, even stuff that's really cheap sounds the same.
Sighted tests are worthless.That's fine and dandy but since you don't own both version of the Fiio K9 then I'd rather believe the person that own both units, at least I'd give the owner the benefit of the doubt. The owner has sat through perhaps countless hours of listening, played with the units multiple times so by virtue of that has my attention. About volume matching, I'm sure that the owner has played with both units volume umpteenth times to be able to earball what volume is suitable and ultimately find that the units sound different. Doesn't take rocket science to figure this out.
using the source switch on the goldpoint, when you flip back and forth between them the difference is extremely obviousSighted tests are worthless.
Are you not keen to find out exactly why that is? Because it shouldn't be.using the source switch on the goldpoint, when you flip back and forth between them the difference is extremely obvious
