I share
Robbo99999's opinion: K702s' soundstage is great - that's why I also prefer them clearly over the HD600s (which I also have) - after an extensive love affair with Fidelio X2HR (which also has quite a nice open soundstage, I recently came back to the K702 as my favourites: they are clearer, have a better resolution than the Fidelio (but want high quality recordings 'cause they expose mercilessly every weakness in a recording).
Both of them like a bit of eq'ing: adding a bit bass in the K702s, lowering the sometimes too boomy bass in the Fidelio - and lowering K702s treble. Fidelio plays with more 'authority' - 50mm (!) angled drivers.
That is , if soundstage is important for you, go with the K702s:
"The AKG K702 have excellent sound quality for neutral listening. They're comfortable and reproduce tracks with great fidelity. Bass mids and treble are well balanced, and the well-designed, large, and open ear cups give them a spacious soundstage. They'll sound great with high-res audio and an amp." [1]
"Like most closed-back headphones, the AKG K371 have a sub-par soundstage. Although there’s a lot of pinna interaction, it isn’t really accurate. While this results in a relatively large soundstage, it feels unnatural and inside the listener’s head." [2]
Always consider wearability: you adapt much easier to certain frequency responses than to a phone which is aching after a quarter of an hour. Sometimes you can bend the headband to lower pressure. Or, you can ziptie the leather headband of the K702s to the metal strings above it (what I do - but I only listen in relaxed lying position). The size of your ears plays an important role. If you've got big audiophile ears - the K702s are very comfortable.
"The AKG 702 are very comfortable headphones. The large ear cups easily fit around most ears, and the headband design doesn't put much pressure on the head. They might be a little too large and bulky for some listeners, but they deliver a comfortable listening experience that doesn't cause soreness even on long listening sessions." [1]
The AKG K371 are comfortable over-ear headphones. They have plush ear cups with thick, soft padding and they don't squeeze too tightly on your head, so you're able to wear them for long listening sessions without feeling too fatigued. That said, if you have large ears, they can touch the drivers inside the ear cups, and become uncomfortable over time. [2]
Don't forget built quality & enjoy!
[1]
https://www.rtings.com/headphones/reviews/akg/k702
[2]
https://www.rtings.com/headphones/reviews/akg/k371
