Guddu
- Joined
- Feb 10, 2020
- Messages
- 2,082
- Likes
- 2,193
[Aiyima Decoder Amplifier - TPA3255 based amplifier with ES9018K2M DAC and NJW1194 based volume/tone controls]
Dear FMs,
This thread will capture Aiyima Decoder Amplifier - User Impressions | Owner's feeblack.
I mean to summarize:
> what I get as a buyer or user of Aiyima Decoder Amplifier
> aspects other than measurements that you might be interested in
> testing features & functions to see if there are any issues and how could get around those, if any
> I also hope that this thread could provide some information as to "what to expect" while you are buying this amplifier
*** I hope other Aiyima Decoder Amplifier owners can also sum up their feedback and some work arounds here to help other potential future owners ***
Availability:
I think it is available on Aiyima's portal and AliExpress. I ordered it from AliExpress and received in 8 days to US.
It can be ordered with or without PSU, PSU options are available 32v, 36v and 48v.
I ordereded with 48v PSU, and received their 48v GaN PSU (wasn't expecting GaN version though) which is also sold with Aiyima A70.
Product Summary
Type: Stereo amplifier with DAC, volume control and tone controls with remote
Amplifier Chip: TPA3255
DAC Chip: ES9018K2M
Input Sensitivity: 0.775v
Digital Control: NJW1194, it performs:
- Volume Control: +31.5 to -95.0dB / 0.5dB step, MUTE
- Input Selector: 4 in / 1 out
- Tone Controls: Bass & Treble: 0 to ±10dB / 1dB step
EQ: It has 4 different EQ modes, with bypass or restore to no EQ
Digital Inputs:
- USB (type:B) / Coaxial / Optical SPDIF: 24bit/192KHz
Note: USB connection to windows 11 was plug & play, no additional drivers needed
- Bluetooth: version 5.1, Chip: Qualcomm QCC3031 (technically supports 2 Mbps data rate and Qualcomm® aptX™ and aptX HD audio)
Analog Input: Single Ended RCA
Outputs:
- Speaker Out: Standard binding posts, more suitable for 4mm banana plugs for safer connectivity
- Aux Out: 3.5mm aux out, 2.3v max, output is controlled by amplifier's volume
Power Input: Label says 24v - 48v,I will try a tear down later to confirm but it might have 50v caps than 63v
Confirmed- it has 50v caps
OPAMPs, default: NE5532
Look & Feel:
I must say that the unit looks stunning, more so when in operation with warm yellowish VU meter and bigger volume display.
Case feels well built, front panel has display, Control Knob and a VU meter.
> Size wise, it is bigger than other Aiyima amplifiers and it might be contributing to better heat dissipation
> here is quick look with A07 Max vs this Decoder Amplifier
> Case has ventilation holes on bottom as well as both sides
> Low profile makes things really easy for placement however speaker cable termination requires some considerations
> No matter how hard I try to ignore but the speaker binding post is small, its same as used in several other amplifiers and 4mm banana plugs are best suited for connectivity
Remote Control:
>Decent quality, plastic made
> works very well, totally responsive
> My Topping E50 is pain in the neck, compared to this one
> There are loads of different settings provided on remote, specially tone control, EQ, bypass and front display brightness control & turn off
Power Supply:
> I ordered with 48v PSU, and received their 48v GaN version
My Setup, Connectivity and Pairing devices:
PC & nVidia Shield Pro (source) >>>> Topping E50 >>>>RCA out>>>> Aiyima Decoder Amplifier >>>> ELAC DBR62 Speakers and Ascend Acoustics Sierra-LX
nVidia Shield Pro (source) >>>> Optical/SPDIF out >>>> Aiyima Decoder Amplifier >>>> ELAC DBR62 Speakers and Ascend Acoustics Sierra-LX
PC (source) >>>> USB out>>>> Aiyima Decoder Amplifier >>>> ELAC DBR62 Speakers and Ascend Acoustics Sierra-LX
Subjective Impressions to me after listening for few days
*** Feel free to ignore this section if you like as it is purely based on my setup, in-room response and my likings ***
I ran this amplifier in my main setup, along with Aiyima A70 & Topping PA7.
Highlights, to me:
- No hiss, noise or anything from speakers when nothing is playing even if amplifier power is set to 99 (full). It is dead silent.
- Clean and powerful sound, as it should be, like any other similar amplifier
- One thing that jumped out clearly to me was strong stereo channel sepration
- Optical out from TV: I think it is very well suited for direct TV optical input, it worked very well without any issues. I liked using tone control with TV input, slightly elivating the base made low level listening amazingly good. After switching between Optical out to Topping E50 vs direct to Decoder Amplifier, I felt I wasn't getting any much benifit from E50 for that purpose.
A quick REW sweep - PA7 vs Aiyima Decoder Amplifier - more or less similar!
Idle Power - Powered ON but no sound
> Measured on 20a smart plug
> When Powered ON but No music playing: approx. 10W
Amplifier Case Temperature & Thermal Performance - Extremely Good
> In normal operation, the case remain negligible warm to touch
> Even on pushing it UP, case remained negligible warm to touch
> Whatever it is, this one has got least case temp than all the other TPA3255 amplifiers I have tested so far and I hope you know that I have't left any Aiyima or Fosi amplifier alone
To Summarize, Positives for me:
> No heating issues at all
> No hiss, noise or anything. Amplifier is dead silent on full volume when nothing is playing
> No popping out on power ON/OFF. YES, NO POPPING sound at all
> Remote control has all the controls and works very well, very convenient
> Front display could be turned OFF by remote
> No strange sound if TV is accidently set to Pass Through or Dolby Digital on Optical out
> VU sensitivity is controlable
> Looks so beautiful sitting underneath TV
What's missing for me:
> Dedicated sub-out, even though it has pre-out
> Auto ON/OFF, could be pretty useful if using with a TV
Some considerations, could be helpful for planning:
Speaker cable connectivity:
> Banana Plug is the safest option for these amplifiers considering spacing between binding posts and PSU connector.
Connecting PSU cable
> Don't connect PSU cable on amplifier when PSU is plugged in and powered ON, it may generate spark on connector
While I plan to add on more details later as I observe, capture or measure something that could be useful for myself or others, I am wrapping it up here with a note that this one is probably better DAC/AMP I have owned so far in almost every aspect.
Dear FMs,
Availability:
Product Summary
DAC Chip: ES9018K2M
Digital Inputs:
Outputs:
Look & Feel:
Remote Control:
Power Supply:
Highlights, to me:
