You can make your own SoundSource EQ text file here:
https://autoeq.app/
It's just a few clicks, super easy. The tool does everything for you.
You should know though that above 1kHz, measurements of the APM vary wildly, so YMMV:
the frequency response of the headphone changes as the seal changes, Dynamic EQ is the strongest feature this headphone has. So basically if you're comparing responses Above 1KHz THEN the seal makes a difference because the Dynamic EQ does not function above 1KHz. So basically just match the...
www.audiosciencereview.com
