I'm off to listen to music whilst licking a 9V battery
Does this really work?
Only if it's an audiophile battery.Does this really work?![]()
LOL -That's an ASR description!I thought tinnitus is caused by an absence of signal for that frequency due to hearing loss.
The ear/brain combination has some auto gain control that is now unable to work for these frequencies.
Could be the gain is then turned up so hign we end up hearing a noise/tone for that band of the spectrum.
I could hear the flyback transformer distinctly when I walked into the house, if someone left the TV or TV monitor on with no signal. Up till my early 30s for sure, due to age of my kids. That's 15.734 kHz. Developing a oscillator a few years ago, it was pretty shocking for me to realize how fast my hearing drops off as I get up in that area now (66 in a few days)When I was a kid, I could always tell if a TV was on in a room without even looking. More of a sensation than a distinct tone in my case.
Yeah, old tv's high frequency noise actually deterred me from watching too much tv when I was a kid. I found it uncomfortable. Nowadays I still have the same issue being around VLT's / frequency converters.I could hear the flyback transformer distinctly when I walked into the house, if someone left the TV or TV monitor on with no signal. Up till my early 30s for sure, due to age of my kids. That's 15.734 kHz. Developing a oscillator a few years ago, it was pretty shocking for me to realize how fast my hearing drops off as I get up in that area now (66 in a few days)![]()
This comes from a Journal review ('Into the Depths of Silence' by Ms.Pierson) of the new book "Losing Music" (by John Cotter)."The problems of deafness are deeper and more complex, if not more important, than those of blindness. Deafness is a much worse misfortune. For it means the loss of the most vital stimulus - the sound of the voice that brings language, sets thoughts astir and keeps us in the intellectual company of man.
Mine is mix of tones centered around perhaps 5 or 6 kHz. Mine is always there though I can ignore it most of time. I've had the problem for maybe 55 years, perhaps it's gotten slightly worse over the years. I suspect it was the result of shooting at an indoor range without adequate ear protection.Mine is a constant tone around 8,800Hz. Sometimes loud, sometimes quiet, and always noticeable.
A leading cause of hearing loss in older adult males is indeed the failure of the body to replace tiny hairs in the ear which resonate in compliance with frequencies roughly above 8kHz, if I recall correctly. This kind of hearing loss isn't so common in women, and its severity can vary among males. I could still hear up to 17kHz less thanks 10 years ago and now it stops at about 14kHz. Some 66 year-olds do better or worse.Maybe. I haven't read up on it but by memory I think it's the small hairs inside the inner ear ( the conch shell??) that break off or get damaged. -Or is that hearing loss?
I have. I worked in broadcasting so audio was key to my livelihood, and I was the guy with earplugs, or in a pinch a rolled up tissue in his ears at concerts and dance clubs. Yet, I have tinnitus that's possibly work-related from the TV production environment. None of that had anything to do with relatively low ear hair loss, though. Probably DNA.You hear a lot better than me and I'm 47. You must have looked after your hearing very well!
I had an "episode" a couple of years ago when I was losing high-frequency hearing in my right ear. My physician husband diagnosed ear wax and used a big syringe to blast it out with warm tap water. Sometimes asevere head cold can bring on temporary hearing issues in one ear or both.This may be OT:
I have an old HS buddy (@the other coast) who goes regularly for 'earwax-removal'.
What is the real purpose of earwax?
Is it like Mobil1 for the ears, the cochlea and/or hearing?
Why do some get plenty and others not so much (=me)?
Is it better or worse for tinnitus?
I had been advised by my peers at work that I am listening to music with the high frequency too boosted. I went to the doctor immediately and he did the same set the exact correct temperature of water with a thermometer and then blasted me and it was a rush.I had an "episode" a couple of years ago when I was losing high-frequency hearing in my right ear. My physician husband diagnosed ear wax and used a big syringe to blast it out with warm tap water.
About 30 years ago I noticed that my lifelong friend and mentor in broadcast engineering was adjusting the video on his home TV set with tons of contrast and a bluish white balance/grayscale. Knowing that he knew better, I suggested that he might have developed cataracts. Then, he was diagnosed with cataracts by his physician.I had been advised by my peers at work that I am listening to music with the high frequency too boosted. I went to the doctor immediately and he did the same set the exact correct temperature of water with a thermometer and then blasted me and it was a rush.![]()
Wow... That's a wild thing to happen.About 30 years ago I noticed that my lifelong friend and mentor in broadcast engineering was adjusting the video on his home TV set with tons of contrast and a bluish white balance/grayscale. Knowing that he knew better, I suggested that he might have developed cataracts. Then, he was diagnosed with cataracts by his physician.
I've just had cataract surgery, and the difference in colour is really surprising me, things are much less warm, and cleaner.About 30 years ago I noticed that my lifelong friend and mentor in broadcast engineering was adjusting the video on his home TV set with tons of contrast and a bluish white balance/grayscale. Knowing that he knew better, I suggested that he might have developed cataracts. Then, he was diagnosed with cataracts by his physician.
I have an Android phone app called MyNoise which has a neuromodulator tinnitus preset. I've found it works pretty well if used regularly (i.e., earbuds while sleeping, set to the threshold if audibilty).
They also have a web site if you want to try it out first:
Mynoise.net
Mine comes and goes as well. If I'm busy at work and haven't slept proper in a couple of days the tone volume is louder. So it isn't just that the small hairs have broken off or damaged. More must be at play..
