A good and cheap solution for a remote controlled volume.
gino1961
Hi ! i am looking for a device that lets me control the volume of amps without this feature (unbalanced inputs).
I do not need any gain at all ... i was watching this one :rolleyes:
https://it.aliexpress.com/item/4000100009226.html
I really need a remote control volume control badly. :facepalm:
Thank you all for any suggestion.
Kind regards, gino :)
oivavoi
Oslo, Norway
So what this does, if I understand it correctly, is that the remote is bluetooh-controlled - and allows switching between the input sources and controls the gain of the output as a preamp?
Plcamp
Ottawa
If you mean power amp inputs, the topping e30 in preamp mode is what I use
G
gino1961
Are you looking for a DAC or just a pre-amp?
Hi let me elaborate please ... i have some integrateds/power amps to try out ... no one has a remote control of the volume. And i really need it.
Maybe even a motorized pot of the right value could work
My amps have from 5kohm up of input impedance I know it is very low.
G
gino1961
Hi from what i understand it is controlled by remote The volume setting is done by switching some resistors combination ?
I really do not know anything about how transparent (i.e. low distortion, low noise) it is
It should drive a 5kohm load
G
gino1961
Hi very interesting And with which results ? do you get a good 3D soundstage for instance ? the price is quite right and also the form factor is very nice
Do you have a loss of rez at lower levels ?
To be completely honest i would like to use a L30 i have after the volume control with its volume fully open
The L30 is very fine as unbalanced preamp ... but it is not controllable from remote :(
Plcamp
Ottawa
Hi very interesting And with which results ? do you get soundstage for instance ? the price is quite right and also the form factor is very nice
To be completely honest i would like to use the L30 after the volume control with its volume fully open
The L30 is very fine as preamp ... but it is not controllable from remote :(
I currently use it into an Adcom 535II I just renewed, but it is destined to drive a Hafler DH220C (new driver boards with fet front end) that I am currently constructing. The speakers are Paradigm Studio100v5.
It’s completely clean. No detectable noise. I don’t detect any quality difference at any level, not entirely sure why you think I might?
If I am critically listening, my volume will almost always be in the range -35db to -20db ... I wouldn’t care and haven’t tried to judge things like soundstage outside that range, given the room and environment this system resides.
Maybe you need something different.
G
gino1961
Thanks again. If the volume is digital usually the rez is lower at lower settings ? but i am not an expert
With an analog control is not the case The rez is always constant
I have already this one
https://www.audiosciencereview.com/...measurements-of-weiliang-volume-control.8348/
bought quite long before the test ... of course :(
The unit sounds flat ... i am puzzled
... If I am critically listening, my volume will almost always be in the range -35db to -20db ... I wouldn’t care and haven’t tried to judge things like soundstage outside that range, given the room and environment this system resides....
So in that range it sounds very fine ? thanks and very interesting
I really do not think that there is a real alternative for similar cash .... good remote controlled preamp are very very expensive
I do not understand why preamps must be more expensive than power amps. Strange.
Sgt. Ear Ache
Winnipeg Canada
the E30 is a perfectly neutral dac. It won't do anything to damage or improve soundstage. It won't do anything to damage or improve resolution. It's a great option as both a dac or a pre-amp really, as the remote is a nice feature.
Plcamp
Ottawa
“The unit sounds flat ... i am puzzledl”
Hmm, I had that feeling with the 535II amp I fixed up. I opened it up, cleaned it thoroughly with alcohol and flux remover at spots.
Then I took out the front end differential pair bjt’s and found their gains were moderately mismatched. I pulled the remaining like transistors from the current mirrors and measured all gains. Lucky for me across both channels I was able to find three well matched pairs...I put the highest gain pairs into the diffamp position.
performs great now.
So I opened my second 535II. Someone had opened the feedback loop and inserted an electrolytic/poly cap pair in series. So I checked the diff pair gains...way way out. Fixed that, reconnected it directly and dumped the caps, and it too is great.
I deal with vintage , as you can see.
G
gino1961
Hi thanks a lot Another vote for the E30 then ... good ! Not that i have a very high end system. I will get one then
Even if i am fine with my current dacs.
