No spdif on the shield, but I have Behringer UAC202 connected to it with a spdif out. But with that I only get stereo or DTS, I need PCM instead. Maybe there is some way of getting HDMI in? Though I guess this is a bit offtopic so better not dive too much in to this here@Tell, your nvidia shield have spdif out. so use spdif to usb adapter to get sound with camilladsp
if you want multichannel, use avr, is more simple.No spdif on the shield, but I have Behringer UAC202 connected to it with a spdif out. But with that I only get stereo or DTS, I need PCM instead. Maybe there is some way of getting HDMI in? Though I guess this is a bit offtopic so better not dive too much in to this here![]()
returns it...Nice. I have just, like JUST A FEW DAYS ago, ordered a MiniDSP Flex HT to get 8 channels for about ten times as much money.
Anyway, i ordered one, could come in handy later.
Nobody is offering yet a multichannel input hat for the rpi5 you are good with the minidspNice. I have just, like JUST A FEW DAYS ago, ordered a MiniDSP Flex HT to get 8 channels for about ten times as much money.
And AVR is not simpler because it doesn't do crossover, room correction, loudness volume etc etc the way I want it to.if you want multichannel, use avr, is more simple.
this 8 channel dac for rpi is best for crossover and room correction
look at MiniDSP Flex HTAnd AVR is not simpler because it doesn't do crossover, room correction, loudness volume etc etc the way I want it to.
But yeah, there must be some way of getting multiple channels over PCM into the pi, and if it doesn't exist then this ain't a simple solution either![]()
Interesting! Never heard of this before, will do a bit of researching on this. Thanks for the tip!Doesn't the Shield act as USB host? Couldn't you use a raspberry pi in USB gadget mode with the Hifiberry DAC 8x? Looking at old screenshots of the Shield menus it looks like you should at least be able to set USB output as 5.1.
Michael
What kind of output connectors are those?
Thanks Michael. Any comments on the results?Here are the measurements. As a disclaimer HifiBerry sent the DAC8x to me for free, although it seemed to be a normally packaged retail version.
All tests done with a Cosmos ADC Grade B set to 1.7 V input voltage using Channel 1 of the DAC8x. Signal path was MacBook Pro 2015 optical output -> S2 Digital -> CamillaDSP routing (no rate adjust or resampling or other processing enabled) -> DAC 8x -> Cosmos ADC. MacBook Pro, CamillaDSP and DAC8x running at 44.1 kHz. Cosmos ADC running at 192 kHz. All channels were driven while testing. THD+N and dynamic range tests used 20-22K bandwidth and are unweighted.
-60 dBFS 1 kHz tone, 7.5 uV residual noise, dynamic range = 49 + 60 = 109 dB
-145 dBFS 1 kHz, 4.1 uV residual noise (this shows analog mute functionality when no signal is present)
2 V 1 kHz tone, -91 dB THD+N
-10 dBFS 32 Tone 1/3 Octave
-10 dBFS White Noise
J Test
Michael
