Tripp Lite Isobar 6 vs Furman PST-6
Pancreas
Which is better? They cost very similar, but I think Furman one has serie mode combined with MOV
I have the SurgeX sa-1810 standalone with 10 outlets for my desktop setup, but I've been thinking about replacing the other surge protectors in my living room and bedroom with something better than what I have now which is Defiant and Tripp Lite regular surge protector.
I rarely use my living room setup which is cheap, just an old TV and some cable box lol mostly want to replace with better protectors for safety
Pancreas
Pancreas
any help?
I just realized the Furman PST-6 is just MOV, only the PST-8 is both MOV and series mode
GD Fan
NY, NY USA
My stuff is all plugged into Isobar 6 units. No problems to report thus far, but can't say if that's the Tripp Lites or just good luck. The indicator lights are a handy touch too.
Furman is a new name to me. But their claim that the strip also offers 'unrivaled power purification' seems like a bit of an eye roller. I think I know which I would pick.
AlfaNovember
Bay Area, CA
@GD Fan - I can't recall a cite, but I dimly recall that Furman was one of the companies that grew out of the Alembic / Rick Turner / Hard Truckin' crew of industrious Bay Area hippies.
Edit - Found it!
GXAlan
Furman dates back to the 1970s
Tripp Lite is part of Eaton now.
Furman is part of Nice, which is an Italian company, now.
Furman’s lead power guy is the current Audioquest power guy, so they definitely dabble in the power conditioning which may not translate into actual performance realm. That said, the series mode protection is great and is backed up with MOVs. The SurgeX/ZeroSurge stuff is off patent…
Prana Ferox
NoVA, USA
Furman's products have always had that hint of snake oil to me, something just a bit too gimmicky. I think part of that is their marketing to musicians who are notoriously superstitious.
For what it's worth, Tripp-Lite is part of Eaton, who is serious business in the world of power delivery including big time industrial surge arrestors and UPS, while Furman is... part of Nice, which used to be Nortek, who is... not.
GXAlan
Eaton makes the power electronics for just about everything. Chances are that your home’s circuit breakers and junction box are made by Eaton. They build and modernize actual power plants
They are not like “Anker” or “Belkin” when it comes to power. They are the true industrial power company.
But for what it’s worth, I own Eaton, Tripp Lite, and Furman and they are all good products. (edit: And SurgeX too.)
robwpdx
I would look at the specs. There should be an EMI noise rejection in dB over a frequency range, and a Joules surge absorption rating. Sometimes the warranty period can be an indicator. I'm an Isobar fan, but I would guess they are both good.
Maybe there is a scientific test site for power conditioning!
GD Fan
NY, NY USA
Edit - Found it!
That's good stuff, thanks for sharing.
Her story about Steve Miller was amusing. I just saw him at one of my local go-to restaurants this week - seems to have mellowed out a bit since then.
Pancreas
Pancreas
Well, only the Furman pst-8 has series mode, but it also has MOV, is not purely series mode. It doesn't compare to zerosurge or surgex.
Chrispy
PNW
Do you have whole-home surge protection? With many other products you just need to rotate them out as they get used up....
GXAlan
It has the same series mode, but then they add a MOV to it afterwards. It’s the proverbial belt and suspenders.
I think we had this discussion on a similar thread before.
ZeroSurge was the original and SurgeX licensed the IP.
Once the patent expired, anyone is free to copy it.
GD Fan
NY, NY USA
That's certainly good news - the price for Zero Surge sure ain't cheap.
Pancreas
Pancreas
Problem is the mov there is the weak link
Why put mov in series mode makes no sense
GXAlan
I have a Tesla Powerwall, AFCI breakers and the aforementioned products.
I admit I like the Furman since they have been the most sensitive with their over voltage protection which triggers at 137V. Annoying since it requires a manual power cycle to reset.
But that is a slow over voltage.
The series mode is needed when you have 6000V going in and your probably send electricity faster than the overvoltage relay can click off.
In the link I showed, Furman talks about their Series Mode performance
“The circuit’s measured clamping voltage is 188 Vpk (this is equivalent to 133 Volts RMS, which is only 11% above an optimal 120VAC line) at 6000V/3000A input”
BUT, what happens if 7000V goes in? 10000V? Higher amps?
That’s where the MOV sacrifices itself to protect the downstream challenges.
Martini
Here's a rather thorough tear-down & review of the the Tripp-Lite Isobar - https://www.tomshardware.com/picturestory/684-tripp-lite-isobar-tear-down.html
I've have/had a few of them. I wanted to replace the MOVs on an older one, but the way the outlets are attached to the board, it wasn't worth the hassle or time. The Tripp-Lite are used on stuff that I have lesser concern about and basically consider the older ones as just power strips, now. I rent, so am not able to install whole house protection at the meter or breaker box; so for my main system and my office system I use ZeroSurge.
Pancreas
Pancreas
Then what about product like zerosurge and surgex why dont they add MOV to their series mode
GXAlan
The Furman, Zero Surge and SurgeX handle the IEEE standard of 6000V/3000A for 0.05 milliseconds.
The Furman doesn’t need any MOV’s if you are below that threshold. Beyond that? That’s a different question.
The Zero Surge is also designed to handle a surge and keep providing power. The Furman is designed to handle a surge and disconnect either via the relay or sacrificially via the MOV.
Suppose you have a surge, and the voltage hits 140V for a fraction of a second. Your gear doesn’t love 140V all the time, but it’s well engineered and the voltage regulator just heats up a bit and goes back to normal.
On the Furman, the whole thing will be powered down until your power cycle the Furman product. It has gone into over voltage protection. The ZeroSurge keeps on running. If you are powering a mission critical something, the ZeroSurge makes more sense. You are going to see more minor surges than major surges. You cannot turn off the Furman’s auto switching.
The combination of US manufacturing and affordable pricing makes ZeroSurge a strong winner for mission critical electronics that need to keep running. They are great. You can use them for audio too.
The Furman is a pretty cheap alternative which is made overseas, but still has HQ in the U.S. and is now owned by an Italian company. But it’s definitely cheaper. It’s great because it will sacrifice itself to protect whatever you connected. For home entertainment, I am OK with the power being disconnected completely until I physically reset the whole thing.
But think about a laptop or Linn product with switching power supplies that can handle 220V routinely, the Furman will be powering down unnecessarily when it could have kept going on. As U.S. spec Furman will always trigger over voltage at 137V and you cannot turn the feature on or off. It will always disconnect power at that level.
Speedskater
Cleveland, Ohio USA
Oh dear, that's a very negative response from Zero Surge! He could have written the same information in a positive way.
Like how it takes a specialized lab set-up to test for surge protection and another to test for noise reduction.
Martini
Well, I'm sure as the company pres. his juices got flowing to defend his product. I also think that Jim could have come across more positive if he took a breath (or couple days) before responding and then focused on filling in Amir's testing, since it was focused on the units impact on the audio signal. Amir did mentioned that he did not have the facility to test the surge protection, do to the dangereous currents involved.
