EQ Software for Windows, Linux, macOS, iOS/iPadOS and Android.
LeShog
Any suggestions are welcome. Post suggestions here. I will gather the details and add them. Thanks. :D This will be organized as results come in.
@sweetchaos made a guide for PEQ filter data input and operation.
For crossover software go here.
Windows:
Equalizer APO is a parametric / graphic equalizer for Windows.
Equalizer APO multichannel peakmeter.
EACS - Equalizer APO Config Switcher. A small Windows tray app that allows you to quickly switch between using different Equalizer APO configuration files.
Peace equalizer is a Windows PC interface for Equalizer APO.
Hang Loose Convolver (HLC) is a specially designed stereo and multichannel convolver to compare “level matched” convolution filters in real time with “instant switching” between filters.
REW is free room acoustics analysis software for measuring and analysing room and loudspeaker responses.
Focus Fidelity Designer creating convolution filters for Roon or HQ Player is very convenient, is faster than REW and easier to use.
Cavern QuickEQ an entire 5-microphone measurement can be done in under a minute with evaluation and export, which was unseen before.
PC Equalizer is a Graphical User Interface for "Equalizer APO" which is a parametric / graphic equalizer.
HiFiScan helps equalize an audio system to get the best possible audio quality from it. It can be automatic or manual.
DS WASAPI ASIO Router Mixer is an audio input to audio output router/mixer supporting Direct Sound, WASAPI and ASIO modes. Shareware 25 day trial.
Mega Switcher is an Alternative GUI for Equalizer APO
MusicBee media player with EQ
QRange 12 band EQ, each band can be used as peak, shelf and cut filter.
foobar2000 is an advanced freeware audio player with EQ.
VLC is a free and open source cross-platform multimedia player w/10 band EQ.
MathAudio add-ons Room EQ VST, VST3, AU and Foobar2000 component.
Roon manages the music from all your digital sources: TIDAL, Qobuz, NAS, hard drives, iTunes, live radio and includes a parametric EQ.
Neutron Music Player audiophile-grade platform-independent 32/64-bit audio engine, parametric EQ.
CamillaDSP supported platforms: Linux, macOS, Windows.
Boom 3D Desktop 31-band equalizer, 3D surround.
Realtek HD 10 band EQ for Realtek audio chipset.
FxSound Enhancer uses EQ presets.
Sonarworks Reference 4 calibrates your studio monitors and headphones.
Waves EQ plug-ins
Equalify Pro a 3rd party desktop plug in specifically for Spotify.
ToneBoosters Equalizer 4 all-purpose dyamic equalizer with AI assist functionality.
Toneboosters TB Equalizer v3
Toneboosters Morphit hundreds of headphone profiles
Sonic Studio 3 for ASUS motherboards.
JRiver comprehensive and seamless software available for managing and playing your media.
Voicemeeter Banana virtual mixer with EQ and audio routing capabilities, integration with VST host software.
FabFilter Pro Q 3 up to 24 EQ bands, regarding setting the Q values please refer to comment #305 and #308
EKIO is a comprehensive loudspeaker management application. It lets you customize the sound of your loudspeaker system.
ARC System 3 - Acoustic Correction System 2 types to choose from.
oratory1990 is headphone specific equalization.
AutoEq uses EQ profiles to be used with EQ software.
CanOpener Studio EQ with Crossfeed plugin.
Boom3D and Boom2 10-band & 31-Band Advanced Equalizers.
HQPlayer PEQ, a convolver with impulse response files, cross-feed and multi-channel support/mixing/routing.
rePhase comes as a simple portable executable in a zip file, and does not require installation.
MEqualizer is an extremely easy-to-use and powerful 6-band equalizer.
SplitEQ parametric EQ with 8-bands and proprietary effects.
Element is a VST/AU host and comes with quite a few built in effects as well.
MFreeformEqualizer draw the equalization that you want and the plugin will make it happen.
Linux:
[GUIDE] How to use Equalizer APO (PEQ) presets in Linux.
PulseEffects signal processing tools including parametric equalizer.
PulseEffects has been renamed EasyEffects as recent versions have moved from using pulseaudio to requiring pipewire.
JamesDSP Audio Effect Processor For PipeWire Or PulseAudio (Equalizer, Bass Boost, More).
Camillagui runs in the browser and handles the actual interface.
dsp is an audio processing program with an interactive mode.
Daphile is an audiophile class music server & player OS – targeted to dedicated headless PC.
moOde audio player parametric and graphic equalizers with CamillaDSP and music playback for Raspberry Pi family of single board computers.
Volumio audiophyle music player for Rasberyy Pie.
FusionDsp a Volumio 3 plug in
Voicemeeter audio mixer application w/ virtual audio device used as virtual I/O to mix/manage any source from/to any audio devices or applications.
DSP for Volumio (previously Brutefir3)
BruteFIR - the convolution engine used by daphile, Volumio's DSP plugin, an LMS plugin and probably others, also manually configurable in a custom alsa config, JACK etc. You can also use it to make crossovers.
BrutefirDRC - the LMS plugin that uses BruteFIR running on the server, configurable per endpoint. Archimago has a howto.
Jconvolver - formerly Zita-convolver, the convolution engine used in PulseEffects, which can also be used with JACK.
Alsaequal - an equalizer you can add to the alsa config. Basic usage is a fixed band graphic equalizer, but it can be used to give a control interface to any other LADSPA plugin via the usual alsa mixer interface. The normal alsa config for ladspa plugins only allows fixed configurations, although for something like an active crossover that's probably an advantage.
foobar2000 is an advanced freeware audio player with EQ runs under wine.
Shairport Sync uses DSP to allow the user to manually input the REW PEQ settings and save for later.
Pulseaudio Parametric Equalizer is a python GUI to insert a 3 band PEQ w/ high/low shelves into the pulseaudio audio server.
Pipewire do post-processing of the sound generated by a application, a possible drop-in replacement for both Jack and Pulseaudio.
Calf plugin suite.
LSP (Linux Studio Plugins) is a collection of open-source plugins.
DeaDBeeF is a modular audio player with a 18-band graphical equalizer and other DSP plugins.
Plus there's a whole host of LADSPA plugins you can use via JACK, alsaequal, or with a fixed configuration in the alsa config file. A good example is the PE32LR parametric equalizer from the Linux Studio Plugins Project which provides the parametric equalizer for PulseEffects.
macOS: (System wide parametric EQ solutions on OSX typically rely on separate plugin hosting software and the actual plugin which does the actual equalization.)
Audio plugin hosts include:
MenuBus has a free version but is no longer actively developed.
eqMac parametric EQ and mixer.****
SoundSource w/ EQ profiles for headphones from Oratory, Reference Audio Analyzer, Crinacle, Inner Fidelity & headphone.com & 20 minute trial period.****
Hosting AU with BlackHole (BlackHole: Virtual Audio Driver. Setting up the EQ details for macOS are here.) or Soundflower can be used as a system wide AU plugin host.
EQ plugins include:
Waves Q10 plugin as a PEQ solution.
Voxengo PrimeEQ is a parametric EQ plugin but is not free.
Fabfilter Pro Q3 is another parametric EQ plugin, regarding setting the Q values please refer to comment #305 and #308
LAConvolver plugin is a free convolver EQ which works with impulse response WAV files.
EQE is a system wide parametric equalizer on iOS but requires jailbreaking.
Rogue Amoeba SoundSource headphone profiles from headphones.com and Crinacle + others.
Universal Audio Equalizer for Mac OS X
eqMac 10 band EQ.
Audirvana can do bit-perfect and exclusive access but can't do system level hosting.
Audio Hijack can host system level DSP, including those EQs.
Toneboosters Morphit hundreds of headphone profiles.
FabFilter Pro Q 3 up to 24 EQ bands.
AU Lab the download link is at the bottom of the page.
Soundsource Per-App Audio Effects with the built-in 10-band equalizer.
iOS/iPadOS:
HouseCurve for room correction, adjusting equalizers, setting subwoofer phase, choosing crossover frequencies and more.
SoundID by Sonarworks, uses Reference 4 profiles.
Neutron Music Player Audio player with EQ.
KaiserTone Audio Player +HiRes with up to 30 band EQ.
iPeng for IOS (iPhone, iPad, Apple watch support) as player for the squeezeboxserver/Logitech Media Server.
AUM Audio Mixer plugin host, recorder, and connection hub. Multi-channel interface support, busses, fx sends, built-in PEQs.
Toneboosters Morphit headphones correction plug-in with studio reference equalization.
Android:
Musicolet Music Player up to 31 band EQ.
Audio Visualizer Music Player music player with 31-band equalizer, reverb, echo etc.
RE Equalizer FX 10 ISO faders with one band per each octave w/ Audio Analyzer for real time monitoring.
SpotEQ31 31 Band Equalizer For Left & Right Side. More details ae here.
Neutron Music Player an advanced music player with audiophile-grade platform-independent 32/64-bit audio.
Wavelet is headphone specific equalization or use a 9 band EQ.
USB Audio Player PRO supporting USB audio DACs playing up to 32-bit resolution at any sample rate & MQA decoder, in app purchase available for PEQ!
Music Equalizer EQ 10 band equalizer.
Viper4Android a system-wide convolution based equalizer.
JamesDSP 10 Band Hybrid Equalizer.
Equalizer FX. Pro 5 band EQ with effects.
Neutralizer
Dolby Atmos
Poweramp Equalizer based on Poweramp player.
HiBy Music 10 band graphic EQ, lossless/lossy audio format support.
Raspberry Pie:
Audio Routing Software: For signal redirection between app, DAW, hw input / output.
LoopBeAudio transfer audio between computer programs, digitally, without any quality loss.
ASIO Link Pro
Synchronous Audio Router a Windows audio driver which allows you to route application audio through your digital audio workstation software.
Upgrading Windows Mixer APOs.
Ending the Windows Audio Quality Debate details how the Windows stack can be fixed without bypassing it entirely.
man you saved me. Thank you!
LeShog
Windows:
Waves EQ plug-ins
Linux:
Calf plugin suite.
EQ plugins include:
eqMac 10 band EQ.
iOS/iPadOS:
Android:
Neutralizer
Dolby Atmos
Raspberry Pie:
ASIO Link Pro
Quite confused though: I use Qobuz on iOS and would like a peq or at least a premade headphone correction, toneboosters morphit seems to do it, but I can’t understand if it works with Qobuz or only music productions softwares. Similar thing for Housecurve, you have to pay for the eq, but I dont understand if I can use it with Qobuz and if is it parametric. Any experience in this regard or one of the other apps for iOS? Thanks.
Doodski
Doodski
I have only used and use Windows based parametric EQ software stuff for the desktop PC. So I have no experience with most of the EQ stuff that is compiled @ the EQ webpage.
LeShog
I figured that, but one never knows. Thank you for the help, appreciate it :)
Berwhale
I've used the Tonebooster Morphit plug-in in USB Audio Player Pro (UAPP) on Android phones, it works well. It looks like it works in a similar way on iOS. Apparently you need a AUv3-compatible host app to use the plug-in on iOS. Another alternative (a better one in my opinion) is get a Qudelix 5K and do the PEQ on that (the PEQ will then be applied whatever you connect the Q5K to, wired or wirelessly).
KosherButcher
I believe Morphit on iOS is only available as an AUv3, and can only be used inside an app that can host AUv3 on iOS, such as Cuba's or GarageBand. I do not believe it can work directly with Qoboz, and as of now, iOS still does not allow any apps to control the main audio output of a device. Currently (and unfortunately), the only way to affect the overall audio output of an iOS device is to have some sort of DSP enabled on an additional piece of hardware, such as an external DAC/Amp.
I do believe the Vox Player app for iOS offers EQ and has the ability to link with Qoboz - It could be worth investigating:
CedarX
USA
I also use Qobuz (and Apple Music) on iOS and, unless the EQ feature is integrated in the app itself--Qobuz in that case-- there is no "system-wide" iOS solution as pointed by @KosherButcher :
It looks like Apple is going the path of integrating all the audio personalization onto their audio devices (AirPods...). So, I doubt it'll ever change...
Completely second the recommendation: a HW-based PEQ is the best solution for iOS, and the Q5K is one of the finest example!
CedarX
USA
Should RootlessJamesDSP be added to the Android section?
It is obviously related to JamesDSP but, as its name indicates, does not require rooting the Android device, an important difference. It does however, require Android 11+, and is a little geeky: it needs a companion app called Shizuku (also available on the PlayStore), and enabling some of the developer options. It works "system-wide" but some Android Apps are incompatible..
Like JamesDSP, it has (very!) powerful features. From the App description:
* Limiter control
* Output gain control
* Auto dynamic range compressor
* Dynamic bass boost
* Interpolating FIR equalizer
* Arbitrary response equalizer (Graphic EQ)
* ViPER-DDC
* Convolver
* Live-programmable DSP (scripting engine for audio effects)
* Analog modelling
* Soundstage wideness
* Crossfeed
* Virtual room effect (reverb)
To me, the Convolver (use case example: room virtualization, binaural impulses responses), Arbitrary EQ (direct processing of an error curve from, for example, Amir's measurements or AutoEQ), and LiveProg (an integrated EEL-2 scripting host) is an amazing combination of features...
CMessi
I probably will buy a Bluesound Node playing Spotify. Is there an EQ android app in addition that I can use or is that impossible?
DWPress
MI
You might want to look into an iOS app called AUM, which is a host for AUv3 instruments and plugins. But it has built in effects, one of which is a parametric EQ plugin. AUM can host 10 plugins per chain, which gives you 10 EQ slots if you just use a single chain, but if you send the output of the chain to a mix bus, then use that mix bus as the input to the next chain, you can have quite a few EQ slots running at once.
Credit to @MachOne for discovering this one.
CedarX
USA
LeShog
Yep thank you, I believe that also this one (that seems pretty fancy btw) is not going to work for our purpose. Maybe you can tweak it into doing it in some way, but my experience tells me that if you don’t use these apps for their intended purpose they are going to work bad resulting in crashes or sound deterioration or the phone warming up or who knows.. I bought a Fiio BTR7 and am very happy with its peq :) sure if I had a software one at home I’d use a Topping G5 or maybe even a desktop solution, but that’s just to be dandy and have the best possible, not to address an issue. I listen very well now with BTR7, I wouldn’t be surprised if upgrading would result in inaudible improvement. In fact I don’t even know how can sound get any better than this, to my ear it seems flawless..
