[GUIDE] How to use Equalizer APO (PEQ) presets in Linux
thyristor
Here's a guide how to use Equalizer APO PEQ presets in Linux for headphone equalization.
Parametric equalization is applied with PipeWire low-level multimedia framework and EasyEffects application that includes a parametric equalizer that can load APO presets. EasyEffects replaces the old PulseEffects application. In this guide PipeWire is installed as an audio server to completely replace PulseAudio.
This guide is for Arch Linux but can be adapted for other distros. Arch Linux is a rolling release "bleeding edge" distro. Please note that PipeWire is a fairly new software and some other distros may have outdated version of PipeWire in their repo.
Most of the information comes from the Arch Linux wiki.
Installation
First make sure that your Arch Linux installation is up to date:
sudo pacman -Syu
Next we will install the necessary software from Arch repo:
sudo pacman -S pipewire easyeffects
When installing PipeWire you will be prompted with two options as a PipeWire session manager. PipeWire Media Session or WirePlumber. I use WirePlumber.
Then we need to install PipeWire clients that we want. Available packages are:
  • pipewire-alsa to route application using the ALSA API through PipeWire. Remove pulseaudio-alsa package if you have it installed.
  • pipewire-pulse for PulseAudio replacement. Installing this will remove pulseaudio and pulseaudio-bluetooth packages and PipeWire will work as a complete PulseAudio replacement.
  • pipewire-jack for JACK support.
In my case I want ALSA and PulseAudio support:
sudo pacman -S pipewire-alsa pipewire-pulse
And remove the pulseaudio-alsa package
sudo pacman -R pulseadio-alsa
Configuration
PipeWire doesn't need any configuration and should just work. However PipeWire resamples everything to 48 kHz by default. We want to disable resampling and use the sampling rates supported by our DACs.
The PipeWire package provides an initial set of configuration files in /usr/share/pipewire. You should not edit these files directly, as package updates will overwrite your changes. To configure PipeWire, you can copy configuration file from /usr/share/pipewire.
System wide:
sudo cp /usr/share/pipewire/pipewire.conf /etc/pipewire/
Or user location:
cp /usr/share/pipewire/pipewire.conf ~/.config/pipewire
Edit /etc/pipewire/pipewire.conf or ~/.config/pipewire/pipewire.conf. Uncomment line:
#default.clock.allowed-rates = [ 48000 ]
And edit it to include the sample rates supported by your DAC. In case of my Topping D10:
default.clock.allowed-rates = [ 44100 48000 88200 96000 176400 192000 352800 384000 ]
We are now ready to start PipeWire user services. Or you can log out or reboot as PipeWire services are set to start automatically. I recommend a full reboot if you are migrating from PulseAudio to PipeWire. If you make changes to pipewire.conf you need to restart the services.
systemctl --user restart wireplumber pipewire pipewire-pulse
If you are using MPD edit mpd.conf
audio_output { type "pipewire" name "PipeWire Sound Server" }
Usage
In PipeWire end points are called Sinks. PipeWire install will set default ALSA and PulseAudio end point to PipeWire sink.
Start EasyEffects program. Go to PipeWire tab and set your DAC as Default.
Here is an example where I have two programs running that have PipeWire as end points. Firefox using PulseAudio at 48 kHz and DeadBeef player using ALSA at 192 kHz.
Nice thing about PipeWire is that you can apply effects for ALSA, PulseAudio and JACK at the same time! Or even app based if wanted.
We can now go to Effects tab to add effects. Here I've added the Equalizer:
You can now import Equalizer APO Presets with Load APO Preset. Presets can be found from:
The format for preset is a simple .txt file. For example I've created a text file akg_k371_amir_peq.txt
with the content:
Preamp: -4.5 dB Filter 1: ON PK Fc 2200 Hz Gain 1.5 dB Q 1.0 Filter 2: ON PK Fc 3915 Hz Gain 4.0 dB Q 4.0 Filter 3: ON PK Fc 6800 Hz Gain -3.0 dB Q 4.0
For amir's PEQ for AKG K371. Preset loaded to EasyEffects:
So that's it! If you have questions I'm happy to help.
Be sure to also install Linux Studio Plugins (LSP), MDA and ZamPlugins plugins, especially the LSP one since it provides the EQ plugin otherwise EasyEffects won't work. I believe the way pacman works in Arch is that these plugins are set as optional dependencies so you have to manually install them all. I use the flatpak version of EasyEffects, these plugins are installed by default.
I have none of those installed. They are not needed.
They absolutely are. You're most probably have them installed, its in the screenshots you post (bottom right). pacman -Qs | grep lsp-plugins
EDIT: I just checked on my Arch install, it appears that lsp-plugins is listed as a mandatory dependency. That's cool because it used to be optional. I use Debian, it's still listed as optional, so you still have to explicitly install it there.
pacman -Si easyeffects | grep -i depends
Depends On : calf gtk4 libebur128 libbs2b.so=0-64 librubberband.so=2-64 libsamplerate.so
=0-64 libsigc-3.0.so=0-64 libsndfile.so=1-64 liblilv-0.so=0-64 lsp-plugins pipewire-pulse rn
noise rubberband tbb zita-convolver libadwaita-1.so=0-64 libfmt.so=8-64
Ah nice that those are pulled as a dependency now.
Kudos to @thyristor as there are almost no guides for EasyEffects. Nowadays PipeWire Media Session is obsolete, so there's only Wireplumber to choose.
Can you hear differences between IIR and FIR? I couldn't. IIR is supposed to have less latency. Also what about Peak filters? Should I choose Resonance or Bell?
Yeah me neither. I just use the default IIR.
I believe Bell has smooth peak/recess while Resonance is sharp. Bell should be the one you want to use.
More info can be found from the LSP manual page itself.
I recently swapped from Windows to Fedora and getting this working was as easy as opening the app store and installing EasyEffects, since PipeWire is already included by default. I also wanted to mention that you can autoload different presets for different output/input devices just like you can do in APO.
I'm glad to see Linux is starting to take over Windows in functionalities and, most importantly, usability.
Thank you. I found this really useful and it motivated me to try pipewire again. I'd found pulseaudio unsatisfactory and had kept my headless streamers (fanless Intel Atom and orangepi arm64 devices and a server running an old core-i7) running plain alsa direct on the hardware (usb dacs) which is ok but meant using eq and crossfeed, while not impossible, was never slick and simple. On my desktop & laptop I'd been using pulseaudio and not liking it much (in the last year they broke bit-perfect and don't even understand why this is a bug). It was a little frustrating that Neutron Player on my phone was superior, in terms of easy config and ease of use, to what I could do with a latest generation Ryzen 5000 based desktop! Pipewire with wireplumber has proven to be a revelation. I tried pipewire maybe a year ago and it wasn't quite right for me at the time, but the latest stable version (0.3.56) with recent wireplumber is a work of art. Everything works! I edited ~/.config/pipewire/pipewire.conf to specify the sample rates my dacs support and set the bit-depth to 32 and now by default get bit-perfect playback of every stream, on any device I use. Very nice! Easyeffects is a nice enhancement for IEMs and headphones, even on headless systems by using bash aliases: example: I can just type "kato" or "katom" and my output is eq'd for my Moondrop Kato or, respectively, the same eq but with Meier crossfeed first. Switch off all eq and effects? I type "noeq" and hit return. I set up everything on my desktop and found that I could simply copy the config to my headless systems and, following the easyeffects wiki, get everything working identically on those as well. Finally I feel like the sound software architecture is as good as the hardware and I'm loving the convenience and appreciating the music the same way, whatever the device. Great "how to" article!
Unfortunately I have found pipewire still ultimately unsatisfactory and have gone back to plain old alsa, configured via ~/.asoundrc. The reason is audible glitches with streaming audio. I use gmediarender (a UPnP/DLNA renderer) on headless streamers, and kodi and gmediarender on desktop/laptop. I find that pipewire, however configured, occasionally produces a horrible pause or click. It is much better than pulseaudio but not perfect. I've adjusted buffer size, cpu governor etc. I've tried running gmediarender via pulsesink, pipewiresink, alsasink, but on every architecture and different linux distro, different kernel, different OS version, networked audio via pipewire always glitches eventually. When I go back to plain alsa then I get perfect playback every time and on every architecture and kernel version and os version. It's a shame, as I loved the convenience of easyeffects on those systems connected to a headphone amp, but ultimately I prefer zero audio defects over convenience.
edit: I'm keeping pipewire, wireplumber and easyeffects on my desktop and laptop because the important use case there is video and playing nice with multiple applications such as web browsers etc. On devices whose audio output is dedicated to music playback then alsa is still better. Not the most convenient, not the most flexible. But if you want *perfect* audio playback there is nothing to match it (and I am including Windows here; I run both Win 10 and Win 11 for gaming and curiosity).
You seem to know about crossfeed. How would you setup a proper crossfeed on EasyEffects? I never used crossfeed before. Let's say I want to hear IEMs.
I would try the Jmeier setting first. It has least tonal/FR effect but works really well
It seems that crossfeed makes the music more narrow as I hear more frequencies in the middle, but not all of course. I don't know yet if it's better.
On some music a subtle crossfeed will barely make a difference, but sometimes it has a great effect. I use it occasionally, definitely not always. I got interested in binaural music a few years ago and read quite a lot about it. I can't remember which label it was, but a classical one anyway, said that they had been interested in and tried binaural music recording and production (it was very fashionable for about 10 minutes a few decades ago) but the main thing they learned was to be better at producing recordings which sound good both on speakers and on headphones.
Hi guys! I've been working with the Equalizer for a while so I thought you might be interested in some presets for EasyEffects and PulseEffects (especially for listening to music). This is my GitHub repository: https://github.com/p-chan5/EasyPulse I hope you can give them a chance.
Just use JamesDSP (it's available for Android and Linux - both pipewire and pulseaudio). It has built in database of all public eq corrections - just pick your headphones from a list and choose a correction and you are done. There is nothing more convenient than this.
Installation
sudo pacman -Syu
Configuration
System wide:
Or user location:
Usage
with the content:
View attachment 217117So that's it! If you have questions I'm happy to help.
Well done. :cool:
I'm in the process of writing one for Pulse Effects for people who might give Linux a try out.
It's taking longer then I thought.
