Thanks @pkane, I made the changes and generated the following reports:
AUNBand vs EQApo
ProQ3 vs AUNBand
ProQ3 vs EQApo
AUNBand vs EQApo
ProQ3 vs AUNBand
ProQ3 vs EQApo
One thing you could try, is setup another filter, totally flat - no change, and just apply the same minus pre-amp, and when just switch between those two filters. That should do the trick. As I am writing this, I should try it myselfSorry if the following is a dumb question..I am really new to equalizing headphones.
I installed Equalizer APO and Peace and managed to apply Oratory1990's settings for my headphone. How can I reliably compare the before/after effect of the applied eq? If I just turn it off in Peace the music is louder because then there is no pre amplification applied anymore. If I remove the pre amplication in the eq then that is louder. Should I adjust it somehow to get to approximately the same volume?
Same issue here, glad I'm not alone I guess, I thought I just wasn't doing something right. I have an older windows 10 PC. I had it working for a while and all of a sudden it just wouldn't apply the changes no matter what settings I adjusted.Right, this is madenning now.
I've just hooked up my new EX5 (very nice, BTW). Equalizer APO simply isn't making any difference at all. The player now shows correctly as the EX5.
I've tried the -15dB trick from Page. Nothing. I've tried enabling/disabling exclusive mode. Nothing.
I added links and changed the description. Is that what you want to see?
I didn't see it included before. Not sure if I am understanding you correctly. But it's a free EQ program that works quite well on Mac.I added links and changed the description. Is that what you want to see?
Okidoki. All looks well then. ThankssssI didn't see it included before. Not sure if I am understanding you correctly. But it's a free EQ program that works quite well on Mac.
I added it. Thankssss.Can I add JamesDSP for Linux to the list, I use it for system wide eq, link to excellent website on how to install it.
JamesDSP For Linux Is An Audio Effect Processor For PipeWire Or PulseAudio (Equalizer, Bass Boost, More)
JamesDSP for Linux is an open source Qt audio effect processor for PipeWire and PulseAudio.www.linuxuprising.com
I added MATHAUDIO to the MacOS section. I could not find a download link for iOS/iPadOS.Mathaudio is also available for Apple IOS platforms.
kymatica.com
I added this to the iOS section. Thank you for the link.Here's a post I made recently about using the built in parametric EQ in the iOS AU host AUM https://www.audiosciencereview.com/...ic-headphone-eq-setup-using-old-iphone.27774/
AUM - Audio Mixer
Jonatan Liljedahl at Kymatica AB makes iOS music apps, electronic music, and a little bit of audio hardware.kymatica.com
